Question about Generac Guardian 200 Amp Transfer Switch NEMA 3R
Hello, I have a 20KW Generac Quietsource, my problem is simply I can't seem to get the battery charge to work. I figured out that I needed to run a 120v line for the battery charger and I connected it to the 'line' and 'grn' screws leaving the 'neu' disconnected. The battery will now charge to ~5.80 volts and no more. The diagram in the manual shows the connection should be to 'line' and 'neu' while the schematic shows the connection to be 'line' and 'gnd'. If I keep swapping lines around I'm afraid I'm going to melt something. Not sure what to do. Hopefully the above is clear enough, if not I can elaborate.
  • 1,476 Answers
Justlaffs,
Follow the instructions in the diagram in the manual. You cannot have a complete circuit with the neutral disconnected and the unit would be dangerous as the external metal surfaces could be at 120 vac and be a shock hazard. I do not understand why you have two different hookup instructions but you definitely need to hook all three wires up, black, white and green.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Oct 02, 2010
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Generac troubleshooting
Your battery is dead..If the controller has a visible display your battery charger is most likely OK. Just put in a new Group 26R battery and set the time etc.
Sep 07, 2014 | Generac Guardian 20kW Model : 5875
Have air cooled 20kw generac cranks but does not start
THERE SHOULD BE A LOW OIL SENSOR ONTHE SIDE OF THE MOTOR PLEASE MAY CAUSE THE MOTOR NOT TO START YOU SHOULD BEABLE TO JUMPER THE TWO WIRES ON THE SENSOR AND SEE IF THE GENERATOR WILL START
Apr 07, 2013 | Generac Guardian 20kW Model : 5875
Have a generac generator 20kw air coolded, automatic standy model 60511 that the battery goes dead all the time
how old is the battery? charge the battery then remove the negative cable place a test light between the battery and cable if the light is on you have a draw unplug things til the light goes out thats your draw
Oct 06, 2012 | Generac Electrical Supplies
Generac Model 5525-1 20kw air cooled standby generator Question: How do you access the battery? I think it is behind the front panel, but can't readily see how to open/remove the front panel. Thanks!
2 bolts on top of the front panel. Take them out and then just puul up and it come off. you can then easily remove the battery but make sure the leads dont touch as they still have charger power running through them.
Dec 04, 2010 | Generac Power Systems Generac 5525 20 Kw...
Battery does not stay charged on my 20kw generac generator
WAS A 110 VOLT CIRCUIT RAN TO IT FROM THE NORMAL UTILITY POWER OF HOME OR BUILDING IT FEEDS?
NORMALLY THIS IS DONE IN A SEPERATE CONDUIT FOR CONTROL WIRES.AND THE FEEDERS ARE IN ANOTHER CONDUIT.
WITH A DIGITAL TEST METER,CHECK FOR 120 VOLTS AT THE BATTERY CHARGER IN THE GENERATOR CABINET.USUALLY THERE IS A RECEPTICAL TO PLUG THE CHARGER INTO.
IF VOLTAGE IS PRESENT AT THE BATTERY CHARGER AND INDICATOR LIGHTS ARE ON, CHANGE METER TO DC AND CHECK FOR 13.8 VOLTS OUTPUT FROM THE BATTERY CHARGER.IF YOU HAVE OUTPUT VOLTAGE TO THE BATTERY,AND IT IS DEAD,CHANGE THE BATTERY..
HOPE THIS HELPS YOU,BEST OF LUCK.....
Nov 01, 2010 | Generac Guardian Model 5784 20 Kw...
I hava a 20kw NG guardian gen. When it does its weekly 12 min. test run it most always runs rough and seems to be choaking itself to death.
I have a 400kw unit that does the same thing, I found the regulator needed to be execersized. when the unit starts I shut the isolation valve ahead of the regulator and then when it almost shuts of the gen. i open the valve back up and then everything is ok, hopefully after awhile it will work right.
Jun 28, 2009 | Generac Guardian Quietsource 25,000 Watt...
Quietsource 25kw Staring problem In auto mode or manual
Sounds like the you have no spark since when you force the engine to crank it never fires. The low battery light come on because the 2 sec of cranking lets the voltage get lower than the alarm threshold.
I'd connect a spark tester to either of the plugs and try a manual start, if you see sparks replace the plugs, if you get no sparks then you've got to troubleshoot the ignition modules and the kill wire that comes from them.
Regards,
Carl
Feb 23, 2009 | Generac Electrical Supplies
20KW Guardian Generac does not produce 12 volts to run engine
The problem is that the printed circuit board inside the generator draws a little current from the battery even when the generator is not running. Over the course of a few days this can make the battery weak enough to be unable to get recharged by the built in running charger which results in not enough power to run the electronic governor on the generator. Usually the spark plugs will work even with a fairly low battery.
Most of the Generac generators come with a built in trickle charger that runs off of the transfer switch load terminals. If your built in charger isn't doing the job it's either broken or you have the wrong sort of battery installed in the generator.
Regards,
Carl
Jan 11, 2009 | Electrical Supplies
Generac Guardian 200 Amp Transfer Switch NEMA 3R Logo
425 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
