Question about Hotpoint RVM1435 Microwave Oven
Microwave Oven not Hot
My microwave oven is turning, everything is ok except that its not hot.
What could be the problem?
  • 2 more comments
  • jimmytvi Nov 23, 2008
    my microwave is not hot, everythng is ok.?????
  • shawna273 Dec 25, 2008
    microwave was working fine for the last couple of months, now everything seems to be working fine, except it does not heat anything.
  • kollsherif Jan 02, 2009
    hi.
  • earl111 Jan 24, 2009
    My hotpoint microwave has stopped heating. Is there a 'reset' proceedure?
    Genius:
  • Hotpoint Master
  • 1,689 Answers
Common faults or combinations of faults:
Main processor board is defective.
Control devices, thyrisistor or relay on the processor board has failed, and or the drive components to this device.
Defective safety switches.
High voltage power supply failure. Usually the high voltage rectifier, and or the power transformer, and or the main high voltage capacitor, and or the magnetron.
I suggest that you DO NOT mess inside your microwave oven. This is probably the most dangerious appliance in the home next to the TV set. There are very high voltages employed. If you do any maintenance on a microwave oven and if something is not right there is also risk of high frequency EMF radiation exposure.
After opening a microwave oven and doing service on it. We always did a ratiation test to make sure that there is no leakage while it is in operation.
I suggest you do some reading at the links below.
Microwave Oven Safety:
http://www.hps.org/hpspublications/articles/microwaveoven.html
http://www.fda.gov/cdrh/consumer/microwave.html
http://www.selfgrowth.com/articles/Microwave_Oven_Safety_Tips.html
Excellent article about microwave ovens:
http://en.wikipedia.org/wiki/Microwave_oven
Jerry G.
Posted on May 26, 2008
Everything works ok on my Ge microwave oven JVM1650 except it will not heat up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;';';'
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works ok except the turntable. It does not turn. Food still cooks, and is very hot as it should be.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except for the fact that it will not cook or make anything hot---every thing comes out luke warm--- it's only a year old---
Basic
heatman101
Dec 25, 2010 | Frigidaire PLMV169DC Microwave Oven
The microwave turns on but does not get hot. The light is on, the the clock, the timer and everything works, except that the food does not get hot. I tried to heat up some water and doesn not change its...
you need to remove the outer cover,then carefully discharge the high voltage capacitor with 2 insulated screwdrivers or an insulated jumper wire,then test this and the high voltage diode and the internal ceramic fuse for continuity
Nov 15, 2010 | Amana ACO1860 Microwave Oven
Nothing is hot - everything is on
Check the door safefy interlock switches before you plunk your $ down.
If you open your oven to check the contents without turning the oven off first ... the tiny switches arc and start to burn ... once they cannot make contact ... the oven doesn't know if the door is open or closed so it will not turn on the heat.
It is worth checking ...
Jun 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything seems to be working except food won't get hot
your 5kv fuse connected to the magnatron is probably blown..it looks like a white casing with two wires coming out of it..fuse is inside this..be careful please
Apr 21, 2010 | GE XL1800 1100 Watts Microwave Oven
The Microwave run but not hot.
There is a 90% chance you have a magnetron fault.
Feb 17, 2010 | Whirlpool MH1170XS Microwave Oven
My microwave still does everything except make things hot. It is a Galaxy model number 721-80002401. Any ideas?
Chk these
  1. Check timer and clock settings
  2. Reseat the element
  3. Test the element
  4. Test the element connectors
  5. Test the oven temperature control
  6. Test the oven selector control
pls rate my suggestion.
Jun 24, 2009 | Microwave Ovens
Hotpoint RVM1435 Microwave Oven Logo
584 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
