Question about Home
I have a Leroy Brooks faucet (LB1230) the cold water side when turned off still leaks from the spout. I need a kit to repair this. Roy Wolter, mtnhighroy@yahoo.com
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
rockitman187
  • 2559 Answers
SOURCE: pegasus faucet problem
The part you need can be purchased at Home depot
Posted on Jan 07, 2009
  • 34 Answers
SOURCE: Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Posted on Feb 05, 2009
  • 659 Answers
SOURCE: Leaking kohler faucet
Where the spout pivots on the main body, there are a couple of washers, you can replace these washers pretty easily by removing the handle and then the "cover" from the unit. The water has to be shut off before you do this. I would take this oppurtunity to replace all the washers.
Posted on Mar 19, 2009
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Posted on May 23, 2009
Spout
Because there are so many manufacturers each with dozens of styles of faucets, and you didn't mention any of that information, replace the faucet. takes about 15 minutes with the right tools, including a basin wrench.
Aug 23, 2014 | Plumbing
Tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 | Plumbing
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
Vegetable Sprayer leaks when faucet is turned on....is there a repair kit for it??
there should be, probably a diverter problem inside the spout assembly. It is stuck between settings letting water travel through the hose and out the sprayer. It is not returning fully to resting position.
Oct 24, 2009 | Delta Faucet Delta 172-SSWF Waterfall...
When i turn the spout water is dripping out from
There are "o" rings between the spout and the body of the faucet that are getting worn and causing the leak. You need to replace the "o" rings. Shut off the water supply (both hot and cold), remove the handle, and then the spout should slide off exposing the "o" rings. You can get replacements at the hardware store. Put some vaseline on the "o" rings when you reassemble the faucet to keep the "o" rings from curling up and moving out of place. Good Luck.
Oct 22, 2009 | Plumbing
Repair leaky handle
Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
Apr 21, 2009 | Plumbing
Kitchen faucet Remove
All faucets have a hot and cold line input. The single handle units have a mixing valve within the handle. Aside from removing the water lines there is usually some type of connecting bolts for the base plate as well that will need to be removed prior to removing the faucet. Do not forget to turn the shut off valves off at the wall before you remove the water lines.
Good Luck
Dec 03, 2008 | Plumbing
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
