Question about Nokia 7370 Cellular Phone
Some buttons dont always work
The phone is new, it got a bit wet sometime back, seems to be ok now except the 1 and 4 buttons only work if you press really hard, i want to open and clean the contacts, how do i do this please?
Thanks
Malcolm
  • 94 Answers
Just try open the phone and at front side aboveur keypad their is one strip which press butten of ur keypad remove it and wash it with white petrol and fix it its 100%going 2 work.
Posted on May 27, 2008
  • 103 Answers
go to your phone or contacts and go to delete all to remove all your contacts from the phone.
please rate me. thank you.
My keys aren't working on my phone, except for the power button. sometimes, it will work when I push other keys, but not often, and the only one that always works is the power button. I thought there was...
Same has been happening here. I don't really know what was the matter with it, I got my keypad wet after my shower, but it was just a few drips, if anyone knows what to do, please tell us.
Sep 02, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
Memory full .... how to clear the memory
First, you need to turn on the service bit: 1. Press the down arrow button, #, then * 2. The machine will display SOS1/SOS2. Press 'OK' on SOS1. It should be set to 00100001. The cursor will be blinking under the first '0'. Press '1' to change it to a 1. Press OK. 3. Hit the red cancel button (the one with the upside down triangle in a circle). The Printer will go back online (or to the memory error).
Next, to clear the memory, press down arrow, #, 8. This will clear out any documents in memory.
Now, go back and and set the service bit back to 0, just like before, except changing it to '0' instead of '1'. If you don't change it back, you will have issues when you go to change toners.
Jul 28, 2010 | Oki Electric Industry MB280 MFP 22PPM...
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
I dont know what button i pressed my phone is on car kit mode andi dont know how to change it
Sometimes it is from moisture damage in the adapter but try this. Go to your menu, hit 0 and it will bring up service code enter 000000, hit 2 which is field tests, hit 4 which is clear errors, select yes, hit clear one time, hit 1 which is service prg., then hit ok until your phone shuts off, and after that turn your phone back on and it should work for you.
Sep 18, 2009 | LG VX6100 Cell Phone
Phone got wet, still turns on, works, but seems that power button
If the phone just got a little wet, you better remove the battery and blow dry thru' all the vents in the phone. Wait for atleast an hour and blow dry again. Now connect the battery and test it. If it still turns on automatically, the water is out of your reach and the phone HAS to be opened to dry properly. Please donot work with in this condition or you could lose your phone.
Jul 30, 2009 | HTC Touch HD Smartphone
Phone got wet...says download on the screen
Try turning ON the phone in recovery mode - Press and hold the volume UP and DOWN buttons while pressing the power button. It worked on my phone. Good luck!
Jun 06, 2009 | Samsung Propel A767 Cell Phone
Razr button doesn't work
you need to replaced the flexcable and also have the phone service professionally from a mobile service center.
Aug 18, 2008 | Motorola Mobility RAZR V3
Samsung a920
on your a920
press the menu button,
scroll down and select settings,
press 8,
press 1,
select on,
select 2,
select always visible,
press the back key twice,
which will bring you to the menu
select tools,
press 1,
Note: make sure that your motorolla h500's bluetooth is active and visible to other bluetooth devices
then select add new.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 07, 2008 | Samsung MM-A920 Cellular Phone
Left colum of buttons wont' work
There may still be some water or moisture under the keypad. The water may leave some conductive residue. The phone should be taken apart and properly cleaned and dried. It is also possible there there may be water damage and parts will have to be changed.
Jerry G.
Jun 11, 2008 | Samsung SCH-u340 Cellular Phone
DS Lite shuts off when I press the B button, and at random.
that happens when i click my laptop buttons too hard... i think u should try to wet it a bit and dont press TOO hard
Sep 30, 2007 | Nintendo DS Lite Console
Nokia 7370 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
