Question about Kitchen Ranges
Blown compressor - Kitchen Ranges
  • Kitchen Ranges Master
  • 43,501 Answers
Not sure exactly what you are looking for, but hopefully you will find this helpful...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 01, 2010
Top section fan was held up by a jar of food I suspect the fan motor being blown or is it possible that the refrigerator section compressor being blown
sorry to tell you there is only 1 compressor and that is for the freezer the fridge section uses cold air circulated to the top
Feb 17, 2015 | Sub-Zero 650 / O Bottom Freezer...
A/C compressor not coming on
Fuse blown therefore no power to compressor. With the vehicle off try to turn the compressor clutch (the part in front of the a/c compressor pulley) just to ensure it is not locked up if it is it would draw more amperage which would result in a blown fuse. If locked up it will require replacement.
Jun 29, 2012 | 2003 Pontiac Vibe
Compressor will not go on. not sure if its a blown fuse in the compressor or if the compressor has blown out and is now junk.
Hi, my name is John. Welcome to FixYa. Make sure you are getting power to it. May be you cigarette lighter plug has blown fuse. Thanks for choosing FixYa....John
Nov 29, 2010 | Slime COMP04 Portable 12Volt Air...
If my compressor only puts out 30 p.s.i., could it be a blown head gasket?
If it was a blown head gasket you would hear or feel air coming out of the cylinder. more than likely its the air regulator, try adjusting it back and forth to see if there is a change. if you can adjust it lower then its the regulator.
Oct 23, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Compact refrigerator Model 88031-1.8 cubic feet Not cooling, blown fuse in trouble shooting page, where is it located if that is the problem?
If your compressor is running there is no chance off any blown fuse but a weakness of the compressor or low gas pressure.
You can shut down and switch on after about few hours, if it cools then you must check the thermostat and the auto defrost section. If not the compressor/gas can be the suspect.
If compressor is not runningg check behind on the lower section for the relay mounted on the compressor.
Sep 24, 2010 | Refrigerators
A/c inop squeal from engine compartment
A high-pitched squeal could indicate a blown A/C clutch or a seizing compressor. Also, check adequate coolant pressure/amount in the system. The a/c gagues are inexpensive and available at auto parts stores and some Wal-Marts. I assume the blown fuse was for the compressor switch, this could be caused by either a temporarily seized compressor (ie: clutch) or inadequate coolant/lubricant in the system.
Mar 09, 2009 | 2006 Chevrolet Malibu Maxx
Craftsman air compressor, oil build up in the air line
worn compressor rings, not a real issue, I assume it is more of a build up over time, say a gram of oil is blown into the lines every year, well one gram would not be noticed nor two but since it soes not evaporate it builds up to the point that you can see it, some oil is blown by brand new compressors and over time gets to be more and more, but as long as you are still getting full pressure you do not have to service the compressor, but since this is being used on water pipes I would install a trap inline to catch the oil
Oct 13, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Neither fan or compressor will com on
You have a short circuit in the system at some point. A blown fuse on the circuit board indicates a short in the control circuit. Tripping of the breaker indicated a high voltage draw from the compressor. Check the compressor motor terminals with the wires removed and the power off. Use an Ohm meter from a terminal to ground. You should have no reading. If you have any reading the compressor motor is shorted out and the compressor is done.
Jun 17, 2008 | Dometic Rooftop RV Air Conditioner
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
