Question about NAD C542 CD Player
Display...are nearly dark.. - NAD C542 CD Player
Display turns dark pink for few minutes and goes
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 23, 2013 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
Dark shadow shown on the bottom of screen
Could you be more specific? all i can think of is you made physical contact with the display(hit it by mistake etc) or someone put a magnet near the screen.
Dec 30, 2012 | Samsung Computers & Internet
My ns-lcd42hd09 insignia tv only displays the right side of the screen clearly until the tv is on for about an hour then it will display both sides correctly. Today it never cleared up, stays really dark...
Having same problem. Smacking it or applying pressure often works. Extremely annoying (inconvenient) that a nearly $1000 machine breaks down very soon after one year ( how long the warranty is, of course)
Feb 15, 2011 | Insignia 42" LCD Flat-Panel HDTV
Screen is coming on and immediately turns dark -
i had the same problem. i had it plugged into my mac book pro. i used the "detect displays" and it fixed the problem. switching b/n dvi & vga seems to require the use of detect displays.
Aug 22, 2009 | Computers & Internet
My nokia 6085 mini display wont light . You can see the time displayed but it is dark.
change the display IC near the main board strip connector, there r two ICs the one on the right side is for mini display , re heat it if it doesn't work after changing the IC ;)
Jun 06, 2009 | Nokia 6085 Cellular Phone
Dark display
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 11, 2009 | Computers & Internet
Dark monitor screen with hidden display in the dark.
Apr 07, 2009 | Acer Aspire 5040 Notebook
Display panel stays dark.
this might be due to the fault of the cable attaching to display panel, check it by some hardware engineer near you
Sep 28, 2008 | ASUS Eee 4G Notebook
Two different Canon A520 problems.
hey guys. there is no solution that you can do it for yourself. the best solution i can give for you is take it to service centre. here in india we get charged nearly 1800rupees for servicing the lens portions.
Nov 21, 2007 | Canon PowerShot A520 Digital Camera
NAD C542 CD Player Logo
47 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
