Question about Smeg FR148A Refrigerator
My door hinge has snapped, how can I buy a replacement ?
    Brigadier General:
  • 3,513 Answers
Please check the bellow link to order your parts:-
http://www.repairclinic.com/
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 01, 2010
How do you install an Ikea kitchen cabinet door hinge?
The new Ikea Sektion door hinges mount in 2 holes that are horizontal. The dimensions for the hole placement are 62 mm up from the outside bottom of the cabinet where the bottom edge of the door will be. The first hole is 20 mm in from the front edge and the second hole is 33 mm from the first hole or 53 mm from the front edge. The holes can be drilled with a 3/16" bit to a depth of 9/16". After the holes are drilled, the plastic plugs on the back of the hinge mounting plate are pushed into the holes with the orientation triangle "arrow" stamped on the front of the mounting plate pointing toward the cabinet opening. After the mounting plate is flush with the surface, the two wood screws are tightened in the plastic plugs to expand the plugs and secure the mounting plate. The door hinge mounted to the door is then clipped onto the mounting plate by first engaging the "hooks" near the door end of the hinge then snapping the back end of the hinge into the clip at the rear of the mounting plate. The location of the door once mounted can be adjusted by turning the three screws on the hinge. The front screw moves the door right and left when closed. The center screw (recessed in the hinge) moves the door up and down. The back screw moves the door closer or farther from the cabinet when closed. The hinges "snap" the door closed, so if the door is too close to the cabinet the hinges can't snap it closed and the door remains ajar. The trick is to adjust the inner screw to move the door farther from the cabinet until it snaps closed. The snap can be strong, and the little bumper plastic disks you can stick to the door to soften the bump work to some extent. The best solution is to install one soft-close Utrusta piston per door. The piston clicks onto the hinge and slowly closes the door the last bit without a bang.
Jan 31, 2013 | Hardware & Accessories
The gasket on the right hand French door is slightly torn, so I bought a replacement gasket. It's arrived, but I have no clue how to replace the gasket.
The gasket is easy to replace. Remove bins and shelves set them aside. Next at the top right hand corner remove the door trim cover pull it straight out and set it aside. Note the tabs on the inside of the trim are fragile. Peel back the gasket at the top forward edge and bottom frward edge and you will locate a hinge. Use a small screw driver to pop these hinges out. Pull out the gasket on that side first and the whole seal comes on out of there. The hinge slides out of the old seal. Just snap yer new back in. Do on door at a time. The trim pieces for each door are different. Snap your door trim back and check for propah opening and closing of door. Then party on!
LG french door service manual
Aug 13, 2011 | Refrigerators
How do I remove the oven door
Welcome to FixYa.
Most if not all Thermador owners manuals have this outlined in them, however, here you go.
Removing the Oven Door
  • Fully open the oven door.
  • Raise the U-clip over the hook on each of the hinges to the "locked" position (see illustration below). This will prevent the hinge from snapping closed when the door is removed.
  • Grasp the door by the sides toward the back. Raise the front of the door several inches (there will be some spring resistance to overcome because of the hinge being locked). When the front of the door is high enough, you will be able to lift the hinges to clear the indents.
  • Pull the hinges out of the slots in the oven front frame.
To Replace the Oven Door
  • Grasp the sides of the door at the center and insert the ends of the hinges into the slots in the oven front frame as far as they will go (see illustration below).
  • With the door open all the way, lower the two locking clips.
  • Raise the oven door and make sure that it fits evenly with the front sides.
DOOR HINGE WARNING:
**CAUTION** With the door off, never release the levers and try to close the hinges. Without the weight of the door, the powerful springs will snap the hinges closed with great force.
Let me know how you make out or if anything is unclear. Thanks for choosing FixYa.
Good Luck,
Macmarkus :)
Sep 01, 2010 | Thermador SMW272 Electric Double Oven
Front Loader Washer Door Hinge broken
There are a couple of sites you can try.
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
Please rate my solution.
Thankyou
Feb 06, 2010 | Bosch Washing Machines
Removing door panel
Buy a panel puller at Autozone and pry it loose AT THE BOTTOM NEAR THE HINGE first. If you accidentally break the clip, it won't be noticable. Do it on top first, and you're door panel is in your lap everytime you drive. Most panels have clips that just snap in. In theory, they just snap out, but they often break in the process. Be prepared to go to the parts store to buy replacement. Cheap, but can be a pain in the ****. Good luck.
Dec 04, 2009 | Audi 100 Cars & Trucks
Oven door removal and installation please. Simpson Neptune
open oven door to first 'notch' pull door straight up off of hinge levers.maintain alignment of hinges to aid in replacement.
if they 'snap' back to closed position,pull them out equally to replace door
Oct 17, 2009 | Ovens
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Cant get holding pins in door hinges out need to replace door
interference fit ,bigger hammer and a decent snap on drift
Jan 27, 2009 | 2000 Ford Focus
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Hinge assembly makes a snapping sound when door is opened
This is a self closer assembly. Try getting a new self closer and replacing both parts. The part on the door and hinge. 0The door must be removed to do this.
Nov 13, 2007 | Frigidaire FRS26KF5C Side by Side...
Smeg FR148A Refrigerator Logo
57 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
