Question about KitchenAid Architect ® Series II KSRX25FT
I have a kitchen aid KSC 25INMS01 It is a side by side fridge with an ice dispencer. The middle part between the fridge part and the freezer is over heating at times. Can you advice. The fridge is attached to a regulator/ transformer because the fridge is110 and the poaer is 220. I appreciate any advice
SOURCE: kitckenair fridge
I had a similar problem with my Maytag Wide-By_Side. When I wheeled it out and searched near the compressor, I could smell a burned electronic smell. It came from a relay called the "relay overload assembly". Besides smelling burnt, when powered up, this relay started clicking on and off every ten or twenty seconds (far too frequently). I ordered the part from the local appliance parts place. The part I took off was an electro-mechanical relay (set of points/click-click switch). The relay I got from parts was a solid-state (all electronic-no points) device. It looked different, but installed with fairly simple directions. Problem fixed. About $25. Shop around internet by model. Look for parts blowup diagram. Good Luck.
Posted on Apr 11, 2007
  • 1073 Answers
SOURCE: Kitchen Aid Superba side by side
check the relay on the compressor
Posted on May 16, 2008
  • 1314 Answers
SOURCE: Kitchen Aid Superba...freezer shuts off..
sounds like your defrost drain is frozen or blocked its in the freezer side under the back panel beneath the evaprator
Posted on Jun 03, 2008
jrod1125420
  • 161 Answers
SOURCE: kitchen aid side by side 2003 KSC... freezer not freezing
sounds to me like a bad compressor....might want to have that looked at by a pro.
Posted on Sep 30, 2008
notsomot
  • 67 Answers
SOURCE: Kitchen Aid KSRJC Overheating
There is a heating cable that runs down the door in most fridges it might have a relay that is fussed closed and the heater is always on. I would strongly recommend that you get someone out to look at it as all electrical faults can be quite serious if they are not treated.
A domestic refrigeration tech should be able to fix it for you.
Posted on Jan 11, 2009
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
No ice from fridge
the water valve has two parts ( ice side and foutain side ) ice side could be bad . the tube in freezer that feeds the water could be frozen . and the ice mker itself may be bad . mm
Nov 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid side by side 2003 KSC... freezer not freezing
Sep 30, 2008 | KitchenAid KSCS25FKSS Side by Side...
Kitchen Aid Fridge
how long does it take for fridge to cool if its not been used in months?
Nov 23, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
KitchenAid Architect ® Series II KSRX25FT Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
