Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I look for GE P/N Model WKKT 0158-01-02 - GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Refrigerator clicking
There are 4 capacitors that need to be replaced to solve this issue with WKKT Model No: 0158-06-03 These caps are listed below. C106 470uf 25v recommended (470uf 35v) C29 470uf 25v " " C6 10uf 25v C100 47uf 25v
Feb 02, 2013 | GE Refrigerators
My GE side-by-side howls. Model GSL25IGRBBS.
First of all - make sure you route the green grounding wire connector from the board to one of the screws, holding the board cover. If you leave it hanging - you can kill the board if the wire touches some of the board elements.
Second - check what kind of sensors you have in your fridge. There are three of them: one in the fresh food section, and 2 in the freezer.
If any of the sensors has black compound where the wires enter the white plastic cylinder, you'll need to replace it with the newer one: WR55X10025
Locations: One behind the damper cover in fresh food section (far left top corner)
One in the far left bottom corner (small cover with 2 white wires to it)
One (which most likely makes the problem) is on top of the evaporator (coil in freezer section, behind the lower back cover). Ifyou replace any of them - make sure to insulate the splice points with food-grade silicone.
Oct 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The circuit board is making a clicking noise... I
Sounds like you have a GE side by side, replace the mother board. Common problem. Once you replace then check to make sure the evap fan is running and condenser fan are working.
Sep 30, 2009 | Refrigerators
User manual for GE Ice Cream Maker Model 106765
Hi
Thanks for using FixYa. You can download the user manual for GE Ice Cream Maker Model 106765 from the following link—
GE Ice Cream Maker Model 106765 User Manual
Please do rate the solution.
Thanks
Rylee
Aug 22, 2009 | Gel Canister 106765 1.5 Quart Ice Cream...
GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Jul 26, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Read, this model posted has a main board in back that controls the refer. Your problem sounds like the overload and relay on the compressor but you need to do a test to verify. On the main board in back there is a blue harness, 3 pronged, that is marked line, defr and comp. Lower left hand corner. You need to get a jumper wire with alligator clips and with the plug out, jump line to comp. Now plug it back in, this will send 120V directly to the compressor. See if it starts. If not and it does it clicking thing, chances are it's the overload and relay, or the compressor itself. You have five years warranty on the compresser. If it starts, it's the board it's the board giving you the problem. This of course is for the GSH model posted...Catriver..post back.
Feb 11, 2007 | GE GSH25KGRWW Side by Side Refrigerator
Frige not cooling and click noise.
Sounds like a relay is chattering on the board. First thing would be to change that circuit board, it controls pretty much the whole unit. Make SURE the clicking is coming from the board and NOT the compressor though! See item 801 below http://www.partselect.com/Schematics/GE/00118404i08.gif
Feb 05, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerators Logo
766 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
