Question about Microwave Ovens
Franklin Chef Large Vertical Rotisserie - Microwave Ovens
Magic chef microwave model# HMD1110W doesn't heat up. Runs but won't heat anything up at all.
All righty then.
If your model has a fuse, it could be blown.
To see if it does, using your computer search engine, type your model number into the box when you are asked to at "SearsPartsDirect".
Scroll down the parts list to see if yours has a fuse.
By the way, your model number is not correct for the search, I think it needs more numbers &/or letters.
One of the most common reasons otherwise for your symptoms is a bad magnetron ( the large & heavy unit that emits radio waves to cook the food) or a bad capacitor ( the starter for the magnetron).
These parts and their cost are to be found on the Sears website.
More often than not, the cost of these parts plus the labor to replace them is so high most people buy a new one instead.
God bless your efforts.
Oct 03, 2017 | Magic Chef Microwave Ovens
Making odd screeching noise,thought it might be the ac motor for turn table ,but it looks and sounds good because i took it out and hooked it up to ac power.
The loud sounds are always the sound of the magnetron failing. It may actually be caused by the capacitive reactance of the large capacitor drying up.
Nov 24, 2013 | Magic Chef MCD1611ST Microwave Oven
Euro-Pro Rotisserie Toester Oven. We need an operators manual for this unit.
The only manual I could find was for the Bravetti Convection and Rotisserie Toaster Oven by Euro-Pro. Here is the site: http://www.sharkclean.com/manual/K4245H_REV_0405.pdf
I hope this helps
Jan 28, 2011 | Microwave Ovens
TB6080A Welbilt Rotisserie Oven How to use the rotisserie oven
I need a manual for my welbilt TB6080A I lost in moving. my Email is lorraineking8679@yahoo.com
Jan 27, 2011 | Welbilt Microwave Ovens
Cannot remove broken bulb from rangehood
Hello. cut a raw potato so that you have a large piece that will fit into the area where the broken bulb is situated. Jam that potatoe right into the broken bulb and twist it out. Remember it will twist out by turning it counter clockwise. [right is tight, left is loose]. Joe
Mar 11, 2010 | Magic Chef CMV1000B Microwave Oven
The light is off on my Magic Chef MCD11E3W Microwave Oven how do I replace it?
Since the owner's manual doesn't cover it, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Nov 28, 2009 | Magic Chef MCD1311ST Microwave Oven
Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Jan 15, 2009 | Magic Chef MCD1311ST Microwave Oven
Microwave Ovens Logo
139 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
