Remove the battery and take it to an auto parts store for a (free) test. A failing battery can have enough power to activate some circuits (warning lights, sensors, etc.) but not enough to crank the engine (even if it's showing 12 volts or more).
if they didn't read the fault codes before starting work, they are repairing by replacement and that is not good
if a sensor is faulty and it could be a cam shaft sensor as well as a crankshaft sensor , normally it misfires or stops altogether
the ECM is in limp mode and that reduced the engine power and if there was a sensor problem it would not just reduce power and put the light on but would show up in a define manner
engine lights also come on it there is a transmission problem and that will also initiate the limp mode
have the fault codes read to determine the faulty part/ sensor
get CEL scanned at a garage and have them look up the code. It could be almost anything but usually lack of power means its in limp home mode and there is a critical sensor that has failed, like cam or crank sensor or ignition controller.
This fan runs of a heat sensor..The sensor may be gon......Trace the wires and see if their is power from the sensor when it gets worm and also powet to the sensor........Power to the sensor is good but power not showing from the sensor after temp light or gauge shows time to cool means the sensor is unservicable..Hope this helps.
sorry I got it, usually you may try:
1) check all paper road no paper inside include the area betweem input tray and cartridge unit the area wetween cartridge and fuser unit and output tray.
2) check 4 sensor input sensor near the input tray roller, marging sensor between input roller and cartridge unit, cartridge sensor at oneside of cartridge unit body, fuser sensor near fuser roller. usually need to clean or adjustment the position.
3) check input roller and cartridge unit and fuser unit at running condition when the power on.
anyone nothing running show error light blink, also show the hardware trouble if all sensors are normal.
I am having problem in finding solution for HP Laser Jet 1300 which is not getting ready and shows orange light blinking. I have check the tonner and the sensor which are located backside but the problem is still as it.
