Question about Dyson Memory CRO1 Front Load Washer
For past few washes I keep getting msg "overload has reduced performance" - this is despite differing amounts in loads. I have tried cleaning out the filter - usual problem, but this is clear.
  • 27 Answers
Your fault is caused by tight drum halves when in contrarotation mode the motors are being overloaded a call to dyson to turn off contrarotation will stop the fault by locking the drums together as a normal washing machine
Posted on Dec 19, 2010
Machine fills up with water and then blinks LE
Hi Robin:
LE is a very bad error unfortunately. It means that your motor communication is being lost. Generally on these LG washers it means that you need to replace the motor sensor. You will have to take the back panel off so that you can access the motor, remove the pulley and take the motor off, there is a little plastic sensor that clips onto the edge of the motor. The sensor is not sold seperately from the motor so you will have to replace the motor unfortunately. Here is a link to the motor you need: PartDetail/Drive-Motor-Stator-Assembly
Here is text of very helpful email from LG... when you receive the LE error code, unplug the machine for approximately 15 - 20 minutes. This will reset the microprocessor. The LE error code can be an indication of several different issues.
The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Many of the leading detergent manufacturers have a high-efficiency (HE) selection. The HE detergents are designed for lower suds levels and enhanced cleaning performance in front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. A good rule is to load the washer until the clothes in the drum are no more than three-fourths of the way up the window of the door. This will allow them sufficient room for tumbling. The clothing having sufficient room to tumble is more important than either the weight or the number of items in the washer. It is the tumbling action that provides the washing effect.
Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. In this case, a servicer would need to take a look at the unit. In this case, you will need a service center to look at your unit. For service assistance, please visit our website at us.lgservice.com Click on "Service Center". Enter your zipcode and product type. Click search.
In the event that you cannot find a service center, please call 1-800-243-0000 for assistance. There, an agent will be able to provide you with an Authorized LG Service Center in your area.
Please have your model and serial number available along with your zip code when you call. If you have a customer service issue, please let the agent know and they will set up a customer service file for you. If your unit is under the factory warranty, your purchase receipt will validate the warranty.
Business hours are 24 hours a day, 7 days a week.
I have taken the liberty of providing some hints and additional information that may be helpful concerning your LG washer.
If you must use a regular detergent, you will only need to use 1/2-1/3 the amount you would normally use in a conventional top-loading machine. However, the HE and the conventional detergents are different formulae, and your machine will not perform as efficiently or effectively. Using half the required amount of regular detergent will give half the cleaning performance. As the new LG washers accept a larger than usual load, the cleaning performance could be further reduced. In addition to the reduced cleaning, there will be oversudsing. The excess suds will cause the washer to stop and rid itself of the suds before continuing its cycle. Getting rid of the detergent will further reduce cleaning performance.
Using too much detergent can cause a build-up on the outer drum over time, which can result in mold and even mildew growth in your washer. Should this occur, do a load of whites on the SANITARY cycle. Use the extra rinse and stain options.
Use NO detergent and use a liquid bleach. This will remove the build-up and any odors accompanying it. This procedure may need to be repeated a couple of times depending on the degree of build-up.
The washing time may vary by the amount of laundry, water pressure, water temperature, and other using conditions.
The 'SenseClean Washing System' has a built-in turbidity sensor that measures the detergent/suds residue in the water during the rinse and then makes an adjustment of time and water usage based on the detected residue level.
The machine will detect an imbalance and attempt to correct it. If the imbalance is detected or if the suds removing program operates, the wash time will be increased.
A built-in water heater in the washer assures that incoming water is the correct temperature to optimize cleaning performance. Most laundry detergents must be activated at certain temperatures to work correctly. We use thermisters (electronic thermostats that have a high degree of accuracy) to detect incoming water temperatures. Our 1000-watt heater adjusts the incoming water to ensure superior thermal action performance.
You won't see a "visible" water level in the window of the unit. The water is pooled in the inner drum. RollerJets are built into the baffles of the washer.
The holes in the baffle collect water and re-circulate it during the wash. This increases the mechanical action to achieve best cleaning performance. The rollers gently move fabrics along in the wash cycle.
This action aids in reducing the amount of water required for thorough cleansing. In contrast with a top-loading machine, which always fills the machine to a precise measured level of water, depending on the size of load you select (small, medium, large), the LG machine will "sense" the size of the load and only recirculate a minimal amount of water, thus making it very energy efficient, efficient in the use of detergents, and extremely efficient in its water usage.
Forced Water Circulation in the washer pumps water during the wash. It recirculates it back up and over the laundry to further increase mechanical action and cleaning performance.
With front loading washers, the door seals so very tightly unlike a conventional machine, that it is recommended to dry the seal when you are done with your laundry for the day to prevent an atmosphere where mold and mildew can grow.
To get the best results, sort clothes into loads that can be washed with the same wash cycle. Different fabrics need to be washed in different ways. Always sort dark colors from pale colors and whites. Wash separately as dye and lint transfer can occur causing discoloration of white clothing. If possible, do not wash heavily soiled items with lightly soiled ones.
Combine large and small items in a load. Load large items first. Large items should not be more than half the total wash load. Do not wash single items. This may cause an out-of-balance load. Add one or two similar items.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 12, 2011 | LG WM1812C Front Load Washer
Tip
Washing Machine Detergent
There are many questions about the type and the amount of washing machine detergent that is needed. Whether you are using a top loading washing machine or a front loading washing machine it does make a difference as to what and how much detergent to use.
Generally speaking a front loader washing machine will need to have less detergent then a top loader washing machine. Combine this with the water savings of the front load washing machine and you will get a substantial savings. However the front loading washer may be much more sensitive to many detergents. The recommendation of many manufacturers is to use HE detergent. This is designed to give less suds then many other detergents.
This is true but the use if the special detergent is not necessary. With the front loading washer you can decrease the amount of detergent used and still get great results. With warmer water you also can get better cleaning from less detergent. If you want you can also mix your fabric softener with the detergent and the fabric softener will keep the suds down for you.
If you have a top loading washer then you may want to experiment with using less detergent then you have thought would work in the past. By using warm of hot water you also can reduce the amount of detergent used and get great results.
Today’s high efficiency washers are very effective clothes washing machines. You can wash clothes with far less detergent in these efficient cleaning machines. Remember that the new machines are very sensitive to excessive suds and will even stop to allow the suds to go down before continuing on. More is not always better and with the washing machine of today, more may make it take a very long time to wash that load of clothing.
http://www.fixya.com/support/r4312694-washing_machine_maintenance
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
http://www.fixya.com/support/r3867591-washer_troubleshooting_water_not
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
http://www.fixya.com/support/r4356970-clean_washer
on Mar 17, 2010 | Washing Machines
Clothes not clean after washing
Were the settings appropriate for the clothing?
The settings on the machine should be set properly for the load. Different fabric types require different wash/rinse temperatures, spin speeds, and wash times. Always follow the instructions printed on the fabric care label. The soil level needs to be set in accordance with the load type. Heavily soiled clothing will not come clean with a light soil level setting.
Was the proper detergent used?
If too much detergent is used, or non-HE detergent is used, the machine will not wash properly. Too many suds present during a wash decreases tumbling action and will not rinse out well. Furthermore, detergent residue built up in the machine over time will deposit extra detergent on clothes and deposit soil back into clothing.
Was the washer overloaded? If the machine is overloaded, the machine will not wash and rinse properly. When the washer is overloaded, the clothes have no room to tumble, and the cleaning performance of the washer is reduced. In addition, when the clothes are packed tightly inside the drum the detergent and water will not distribute evenly throughout the items.
Front loaders require regular maintenance to ensure optimum performance. If this maintenance is not followed, residue can accumulate in the drum resulting in detergent and soil being deposited back into clothing. This can also lead to odor and other issues. Perform the required maintenance regularly (once or twice a month).
Jan 11, 2011 | Asko W6021 Front Load Washer
LG WD 1433RD Error Message LE, sounds like something wrong with motor or pump like it is blocked how and where can i locate an area to find if it is blocked? Do not have a manual
Hi There
OK i got this for you it took some time but i got from Lg themselves.i hope this is helpful for you and let me know how it goes.
When you receive the LE error code, unplug the machine for approximately 15 - 20
sensor, or if the shipping bolts are removed prior to situating the washer. . In
increased.
water usage.
Please feel free to contact me in the future if you have any additional
questions or concerns. Thank you again for contacting LG Electronics.
Cyndi
E-mail Administrator
Customer Interactive Center
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Dryers
Gives the LE code
increased.
water usage.
Hope This help
Good Luck!!!
May 03, 2009 | Washing Machines
LE error coming up
increased.
water usage.
Hope This help
Good Luck!!!
neo
Feb 27, 2009 | LG WM1812C Front Load Washer
My washer was giving off the LE error code and when it was suppose to drain & spin section it would just grind-man came out and showed where that brown filter in the lower left hand corner-I went to clean...
increased.
water usage.
Hope This help
Good Luck!!!
neo
LG WM2277H has the LE code on & will not work.
increased.
water usage.
Hope This help
Good Luck!!!
neo
Feb 25, 2009 | LG WM2277H Front Load Washer
LE on front panel of LG dishwasher after it quit wroking
increased.
water usage.
Hope This help
Good Luck!!!
neo
Feb 18, 2009 | LG 24" Built-In Dishwasher - Black
LG TROMM WASHING MACHINE FRONT LOAD
increased.
water usage.
Hope This help
Good Luck!!!
neo
Sep 18, 2008 | LG WM-1485FHD Front Load Washer
Dyson Memory CRO1 Front Load Washer Logo
189 people viewed this question
Top Dyson Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
