Question about KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble Front-Load Washer
My husband disconnected our Kitchen aid ensemble front load wash machine. When he reconnected it on the locked controls light is on. How can we fix it?
  • 5,081 Answers
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
Posted on Oct 01, 2010
Mymachine's light is fixed at 'control locked' even though the door is open. It won't start. I've tried unplugging it, but it won't reset itself. What do I do?
If the model number is correct, press the END OF CYCLE SIGNAL button for 3 seconds. These instructions are listed on page 10 of the owner's manual. If you no longer have a manual, you can obtain a FREE copy at managemylife.com.
This is a designed safety feature that enables the comsumer to lock the control panel to prevent small children from accidentally locking a playmate inside the washer and starting it. This usually is not an indication of a washer malfunction.
If you need further assistance, please let me know. I hope this helps you.
Oct 28, 2010 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Hallo,I have problem the cycle dosent spin kitchen-aid wash machine
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | KitchenAid KAWS850L Top Load Washer
What does Troubleshooting "F" "02" mean
F02 Long drain If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.hope this helps
May 01, 2010 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
My kitchenaid ensemble keeps coming up with error code f dl. why ?
This is more than likely a door lock failure eroor code and you need to replace the door lock,
Feb 07, 2010 | KitchenAid KHWS02R Front Load Washer
My husband was washing a load of clothes and as our front load maytag washing machine started to spin, a shirt wrapped itself around the rubber part that is at the front of the washer and pulled it out and...
you will have to take off the front off washer to put it back correctly.
remove the top panel 3 screws in top rear
remove the bottom panel 3 screw in bottom front
remove the top led control panel 3 screw or more along front lip
if you disconnect any wiring mark it well .
now the front of washer can be removed with or without the door (your choice)
careful with the door lock wiring.
be sure to unplug the washer.
while you are in the innards its a good time to wipe around the drum any buildup of soap etc..
and to clean the filter trap in the bottom access tube below drum.
Mar 31, 2008 | Washing Machines
Self cleaning does not work
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$$$$
Mar 24, 2008 | KitchenAid KERC700LBS Electric Kitchen...
Washing Machines Logo
163 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
