Question about Dometic Rooftop RV Air Conditioner
Dometic unit cools great but compressor does not cut off when desired temperature is reached. The thermostat is on wall. The fan will cutoff at proper temperature but the compressor keeps humming and therefore builds up ice without fan running. What would the problem be?
    President:
  • 1,515 Answers
Hi, as you know the thermostat controls the unit. Here's what you need to do first. Go to your thermostat on the wall, pull off the cover. You are looking for the main control wires that come in from the back to connect to the screw terminals. Don't be afraid of shock as these are millivolt wiring connections.You say the fan shuts off but the compressor keeps running causing it to ice up. You need to get a screw driver and disconnect the wires from this stat. This should cause the compressor, fan, and all to shut down. If it does, you know that your thermostat is faulty and you will need to make your self a drawing on the wire connections, remove the stat, and you can get a new one at a RV sales and parts house.Find your breaker box where your main wiring comes in and shut off the a/c breaker if you like. Now, if the compressor keeps running after you disconnect it from the thermostat, then somewhere from the stat to the controls on the top have a hot wire that is touching somewhere causing the compressor to be energized all of the time. If you can go up top and find where this thermostat wire comes in, look it over good to see if the red is touching the yellow wire some where. I believe you just have a faulty stat at this point. Do what I asked on the stat, disconnect it completely, and we will go from there. You can get back to me by leaving a comment under my user name. Please let me know and we will take care of this problem.
Sincerely,
Shastalaker7
A/C, and Heating Contractor
Posted on Oct 01, 2010
I have a Dometic a/c with a digital thermostat. When I have it on cool the compressor will cut off when the proper temp is reached but the fan continues to run and won't shut down unless I turn off.
It could be could be several things depending on what type of AC it is. is it a window unit, or a split system. Could be a bad thermostat or thermostat wire or bad board or a safety or wired wong.
Nov 17, 2015 | Dometic Heating & Cooling
Weak heating and weak cooling in cabin
get the heating coil and the thermostat checked.
Oct 11, 2008 | 2004 Toyota Land Cruiser
2014 Dometic Brisk II 15,000 unit won't cool below 88 degrees
Check the unit to see if the outdoor fan and compressor are coming on. If not, check to see if power is reaching the contactor, both the high power contacts and the low voltage solenoid. Some contactors can be manually actuated, and a quick press (with a NON CONDUCTIVE ITEM) can show you if the contactor is engaging. If the solenoid is not working, check the wiring of your thermostat. When set to cool mode, there should be voltage on the solenoid of the primary contactor, sending power to the outdoor fan motor and compressor.
If the outdoor fan and compressor engage normally, then make certain the coils are free of debris and other blockages. If air flows freely and the compressor is running, feel the tubing for temperature changes. One side should grow cooler and the other warmer.
If the compressor runs but there is no temperature change, take your unit to a certified technician to check for leaks and system pressures. Roof top units typically use R22 refrigerant not R134a automotive refrigerant, which require EPA certification for purchase and dispensing.
Jun 25, 2014 | Dometic Rooftop RV Air Conditioner
I meant the AC does not cool
Make sure the mode is set to freeze and temperature is set to below the room temperature.
If it is a split system, check the outdoor unit whether it is running. If it is running, see if you can reach and feel the temperature of the pipes connecting between the indoor and the outdoor unit. It should be cool.
If it is not cool, you may need to get somebody to check the refrigerant.
May 22, 2014 | Dometic 57915531 Air Conditioner
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
Thermostat dial broke and huge ice pushed out cover. Fan still works ok.
dear sir
i think in your air conditioner,s thermostat is not working because there huge of ice on unit. thermostat control to compressor for desire temperature, when temreture reach till desire tempreture it,s cut supply for compressor . and make balance on cool air.
please replace thermostat for solve this problem.
hope answer the question
thank you
please vote!
Oct 02, 2010 | Sharp AF-R100DX Air Conditioner
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
Dometic a/c, duotherm thermostat, turns right back on after it reaches desired temperture.
I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
May 13, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
136 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
