Question about Nordic Track Exercise & Fitness
Nordic Track c2200 no speed signal. My NT c2200 treadmill behaved erratically briefly (sudden speed changes up and down) before quitting altogether. The console now behaves as though it's working but the motor does not turn. It has the MC-2100 motor controller. The trobleshooting LED shines solid indicating it is not receiving a speed signal. In the case of no speed signal is it still possible that the problem is with the MC-1200, or does this indicate that the problem is either the wiring harness from the console, or the console itself?
    Problem Solver:
  • 13 Answers
It likely is the controller if it was speeding up and down erratically. Check the position of the reed switch to make sure it is positioned about 1/8" away from the magnet in the side of the front roller pulley. Run a diagnostic program as follows. Press the stop and speed arrow up buttons until you insert the key. Press the stop once or twice until you get to a screen with 2 sets of zeros. Now press and hold the speed arrow up button until one number set shows 8.5. The unit will go to full speed so be careful not to be on the walking belt. The other number set should top out shortly at either 10.0 or 12.0 based on whether your speed buttons go up to 10 or 12. If the motor races past your top number,( don't let it run that way as you may damage the motor), pull the key. If the readout is above or below your target by more than .4 and not flucuating a lot, you may need to tune the potentiometer on the controller. Counter clockwise turn with a phillips screwdriver turns the motor speed down. Be carefull not to short out the controller board by touching components with screwdriver. If not comfortable ask a friend with electronics background. If you turn the pot. too far it will break. It will not go a full revolution in either direction and tiny movements are recommended. Again I believe your controller needs replacing.
Posted on Oct 03, 2010
  • metazzz
    metazzz Jan 15, 2013
    i am having this same exact problem and i did everything mentioned up top but its still doing the same problem one set of zeros i put up and the second set displays what im assuming the speed sensor is readingcomes on then off imediatlyany other ideas??
Tread belt not turning on
please LUBE the deck belt with WD-40 or grease . and try to loose a little the deck, the idea is to lift- 2-3" max.
Of course is time too, to maintenance Motor
Feb 12, 2015 | Nordic Track NordicTrack C2200 Treadmill...
STARTS AND THEN ITS STOPS??
If the timer is set it will always stop at EXACTLY the same time.
If the motor is overheating, it will usually slow down before it stops; and the time will be a little different each time.
Congratulations, I only know one other person who has worn out a nodic track.
Feb 03, 2015 | Nordic Track Nordictrack C2200 Treadmill...
Nordi Track Treadmill C2200
treadmills draw alot of amps when being used. they recommend a 20 amp dedicated outlet.i ran into the same problem with a treadclimber.
you can try using a 15 amp but make sure nothing else is on that line
Mar 20, 2014 | Nordic Track Nordictrack C2200 Treadmill...
NTL 1192 is the product.
The reset switch is to close to main switch, reset it. See your instruction manual in section troubleshooting. for identify the reset switch. or download your instr. manual from www. fitness.manualsonline.com
God bless you
Nov 07, 2012 | Nordic Track Nordictrack C2200 Treadmill...
C2200 treadmill motor problem
1)measure the voltage input motor, if there are The motor need repair or replace.
2) mEASURE the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the block diagram.
3) Test th drive belt for loose or break and replace.
Jun 28, 2012 | Nordic Track Nordictrack C2200 Treadmill...
My Nordic Track C2200 Treadmill will stop in mid run. The timing when it happens is random. I can pull the safety tab out and put it back in and run for a bit till it stops again. Any suggestions on...
It it completely shuts down ( console shuts down then restarts) it may be a static electricity problem. Check your outlet to be sure it is grounded. Check the plug . The ground pin may have been removed.
Jan 02, 2011 | Nordic Track Exercise & Fitness
My treadmill is telling me the wrong amount of calories burned and the wrong speed at which I am traveling. For example, I hit the button that says 6 mph, but the treadmill says I am running at 9.7 mph....
I had the same problem with my Nordic Track. I had somehow changed the display to metric readings.
Solution: Hold the stop button down while inserting the key, push the speed up or down button to change it back to english, remove key and you are good to go. Re insert the key and it should work fine. Hope this helps.
Nov 27, 2010 | Nordic Track Nordictrack Adventurer...
I have a Nordictrack c2200 treadmill. All of a sudden I feel like I am going to fall through when I run near the front of it. What could be the problem? And if it is the deck, can I flip it and use the...
The deck is most likely broken, It would need replaced if this is the problem. The nordictrack models do not have decks that can be flipped. That is usually reserved for a commercial grade machine of a different brand.
Aug 13, 2010 | Nordic Track Exercise & Fitness
Exercise & Fitness Logo
782 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
