Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
The cover over my left oil tube is cracked, can I get a replacement ? How & where ?
    Scholar:
  • 195 Answers
I would check out the Victory Glass website at www.victoryglass.com they have a range of trims for the One More Time plastic trims, you will need to find out what manufacturer made your jukebox i.e. Wurlitzer, Rowe Ami, Rock Ola or the earlier Antique Apperatus, Sound Leisure (parts available in the UK from Sound Leisure at Leeds).
Regards
Alan Hood
ami-man
UK
Posted on Oct 13, 2010
My 02 galant runs rough when put in gear but in idle runs okay it also surges up and down replaced the plug wires
Okay, lets start with the oil you found on spark plugs when you were replacing them. this oil is coming from the valve cover tube hole area, notice the plugs go into the holes in the valve cover, there is a gasket the goes around the top of the tubes and when it leaks it goes into spark plug hole, the valve cover needs replacing .
this will cause rough idle and running problems, after replacing valve cover gasket the holes must be cleaned, using crab cleaner, spray into holes and use air to blow out . this may need to be done a few times to get oil out .
after oil is removed . then remove spark plugs and wipe them clean.
The next step is to find the air (vacuum leak) , you said you hear it around intake tube. check for cracks or broken vacuum line. this leak will cause idle problems and driving problems,
Nov 18, 2012 | Cars & Trucks
Coolant in the oil, so replaced head gaskets and front timing chain cover seals. flushed coolant and changed oil. ran it, now i have oil coolant sludge comming up the oil fill tube and through the pcv....
it could be left over and but i would check and see if you are still losing it have seen blocks crack in wierd places if its still leeking thin i would asome cracked head are block most likely the head
Jan 20, 2011 | Jeep Liberty Cars & Trucks
My 1993 Dakota Club cab Mangnum 3.9 V6 has been leaking antifreeze. Mechanic said the fan clutch was bad & replaced it 9/6/10, but they could not find a leak in the radiator or reservoir(which were...
The price seems really high. I have the 3.9 and if the timing cover is cracked you would be getting coolant in the oil. And 135,000 miles on a timing chainis low, it still has many years left. I think I would try another mechanic. good luck
Oct 04, 2010 | 1993 Dodge Dakota
Head Gasket?? Valve cover Gasket???
most likely it is the valve cover gasket. it covers the valve train where there is alot of oil to lube the top of the motor. if the head gasket was leaking it may have more signs of running poorly. also having coolant leaks also. so i will have to say valve cover gasket. now usally you may have a oil burning smell with it depending on the area of the lek but not always.
the valve cover can easily be seen when the hood is open. it is right on the top and where it meets the clyinder head is where the gasket is and the leak can be seen.
if you have more question please ask.
Nov 12, 2009 | 1997 Geo Tracker 2 Door
After warming up my suzuki 750 gsx leaks a oil/fuel mixture out of the air cleaner
You need to service the crankcase breather system. Basically, this means taking apart and cleaning all the goo out of the area where the crankcase breather tube goes into the air box. Also check the air filter for oil saturation and replace if needed - and clean any accumulated oil from the inside of the air filter box.
Nov 07, 2009 | Suzuki GSX 750 EF Motorcycles
Automatic chain oiler will not function
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 27, 2009 | Garden
Chain oiler not working
Oil System Plugged.
Lou
Oct 15, 2009 | McCulloch Garden
Chain and bar do not seem to be getting oil. Have not had to refillbar oil in a long time.
Oil System Plugged.
Lou
Oct 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Automatic oiler won't oil chain.
Oil System Plugged.
Lou
Oct 03, 2009 | Garden
My 1999 VW polo 1.6i blows oil from the dipstick hole. What could be the problem? (not listed but similar to jetta)
sump is pressurising it will be ahead gasket ,if you are lucky cracked block if youare not but iwould think head gasket
Aug 11, 2009 | 1999 Volkswagen Jetta
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
181 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
