I have a Vokera Compact LE with a Honeywell Room Thermostat it has two wires connected Red and Yellow and an earth wire. I want to replace the Room Stat with a Sunvic TLX RFP calling for volt free connections of the looped terminals of the boiler to Common marked L In and normally open contact marked SL on. The existing Honeywell wiring is Red to terminal 1 and yellow to terminal 3. Should I connect Red to SL on and Yellow L in ?
  • 104 Answers
SOURCE: Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Posted on Jun 18, 2008
  • 163 Answers
SOURCE: Installing a Honeywell Programmable Thermostat with my Bryant Puron HVAC System
i hope this helps
Posted on Aug 18, 2008
  • 254 Answers
SOURCE: HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Posted on Aug 28, 2008
  • 4 Answers
SOURCE: need to wire honeywell programable
need more info about your system is your stat heating only if yes r and w on stat go to two wires at the boiler T1 and T2. You may have some other controls and would have to list them all.
Posted on Nov 06, 2008
  • 25 Answers
SOURCE: Low Volt wiring for a two stage heat pump as primary heat with a gas boiler as back up heat the out door unit has a sencor on it with a honeywell 8000 t stat
ok?? what is the problem?
Posted on Nov 22, 2008
I need to replace an old Thermostat that just has 3 wires coloured Red, Blue and Yellow. The Honeywell THR830TUK Thermostat I have bought shows 5 wires on the diagram. I'm not sure which wire goes into...
The honeywell THR830TUK thermostat does not require a neutral as shown in the instructions.Connect the LIVE to terminal "1" and your YELLOW SIGNAL wire to terminal "3".
Connect your EARTH (if you have one) to the EARTH connection on the top left hand corner of the thermostat and blank off your NEUTRAL wire with a block connector.These instructions were supplied to me by Honeywell Customer Support.Hope this helps.
Jan 08, 2011 | Heating & Cooling
Room thermostat Honeywell T6360B - gravity hot water, pumped CH
Go to
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 02, 2010 | Honeywell Programmable Thermostat Heater
Central heating - room thermostat Honeywell T6360B
hI he has wired the pump to permanant live there should be link between two of them ? cannot recall which . not much help sorry
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
How do I wire a Honeywell room thermostat T6360B1028?
The red goes to R or rc and the blue would go to C or common sometimes its BK on the thermostat and the yellow would go to Y.
Jan 22, 2010 | Honeywell Programmable Thermostat Heater
How do i change an old style honeywell room stat
Shut the furnace off for starters. Remove the old Thermostat. As you remove each wire write down what terminal it wen to.
Red wire usually goes to R-Power
Green Wire usually goes to G-Fan
White usually goes to W-Heat
Blue or Yellow usually goes to Y-Cool
Jan 04, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Help! replacing WeatherKing thermostat with Honeywell RTH230B
Sep 18, 2009 | Heating & Cooling
Wiring honeywell DT200(T6620B)
Go to
Apr 11, 2009 | Honeywell Programmable Thermostat Heater
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Jan 13, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
