HP 7280 interrupts Internet
Before I proceed with your suggestion, do I need to remove Ping blocking from my router and do you want me to connect wirelessly or with ethernet cable?
I will have to purchase a cable to otherwise.
Thanks for you help so far.
Jim
    Scholar:
  • 187 Answers
Wirelessly at first. The results of this will determine whether or not you need to connect via an ethernet cable. Note however, if you've never connected to this router via an ethernet cable, it's very likely that it's simply not correctly setup for this. You can of course, also try connecting the printer via an ethernet cable and monitor whether or not the problem persists (this will also help allow you to determine the source of the problem).
Posted on May 26, 2008
I've connected my Router to switch and through switch i connected two wireless Netgear N150 router where my router is gateway. My Problem is I can ping from Laptop to Router gateway but unable to ping from...
The two wireless routers THINK they are directly connected to the Internet and they prevent the WAN side ports from being pinged so hackers can't find out you have a device on the Internet. The devices will let you to the Internet without any problems, why do you need to ping from the router to the WiFi routers anyway. all of that is your internal network....
One thing that might fix this is if you can put the WiFi routers in BRIDGE mode. Some routers will let you do that, some won't. Don't put the router that is facing the internet into bridge mode. hackers will be able to see your whole network.
Sep 12, 2013 | Linksys EtherFast Cable/DSL Router
Cant connect to internet
Check your all physical connection and cable..
First,restart your computer
->Open web browser and enter the IP address and enter the login details on the login screen and proceed.Click Router Status under Maintenance and check if you see your IP address.
->If you see 0.0.0.0, the router is not obtaining the IP address. It can happen due to various reasons. Contact your ISP and ask for the details including username, password for PPPoE etc. and try to connect to the Internet again afterwards.
->After configure you router ,open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway
->If you are still unable to browse the Internet, ping your router's connection to the PC. Open Command Prompt, type 'ping IPaddress(ex:192.168.1.0)', hit Enter.
->If you get the Request timed out message then check your router connection again and correct the Ethernet connection between your PC and the router.
If you need any technical help on wireless router then you can reach at http://www.vtechsquad.com/
Feb 20, 2013 | Computers & Internet
Can't access internet, all lights are on
->First,restart your computer
Nov 14, 2012 | Belkin (F5D7230-4) Router (587009)
Having problem internal network to connect outside but the router itself can ping the outside domain or public domain/IP. The Internal Network cannot ping the domain or cannot connect to the internet what...
1.Check whether there is ping to router from lan computers.
2. If there is no ping then check the cable b/w lan computers 7 router.
3.Else if there is ping to router, then check ur router for any ip blocks, access lists etc..
4. Turn - off the local firewall, so there also a chance of it blocking access to internet
Sep 27, 2010 | Cisco 881 Fast Ethernet Security Router
If a change in my firewall is preventing netgear router, i do i fix?
First, make sure the cables are properly connected, if using xDSL modem, it must be connected to the WAN port, the pc on the ethernet ports (any of the 4 ports available).
Second, check your current IP Address (default 192.168.1.x), then ping from your pc the ip address of the router (default 192.168.1.1). If OK, then your LAN connection works fine.
Third, ping any internet site, i.e. ping www.yahoo.com. if a reply response is received, your internet connection is now working.
If not, reset the router then do the initial set up from the router web page. Go to IE or mozilla browser, type http://192.168.1.1 (default ip add of router), the password or username is admin (default - refer to your manual). If already inside the page, go to the setup folder then proceed to configure the router. After all the configuration, check your internet connection, go to any web site.
Sep 15, 2009 | NetGear WGR614 Wireless Router
I have a D link router DIR 100 and since i have installed Service Pack 3 in my laptop, I am unable to browse internet. It shows wireless connection as connected but I am not able to browse anything....
Well te first thing you need to make sure that if you have the connectivity
To check this: Go to command prompt and than type ipconfig and see you get the right ip address or no if yes than
Try to ping website like in the command prompt type ping www.yahoo.com
if you are able to ping the websites that means you are connected to the internet and it's just a browser issue for that the best solution would be System restore which will remove the service pack 3 from the system and can fix the issue.
if you are not connected the the interenet than you ca try resetin your router iff need any clarification tha let me know.
I am assuming you understand about reseting router, ipconfig and all that.
Jul 29, 2009 | Computers & Internet
HP 7280 fax interrupts phone calls
Set the fax to MANUAL MODE, you will then have tp press START to receive a fax.
Dec 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP 7280 printer/internet access
It's just the printer she cannot access? Is she able to ping the printer? or possibly, connect to the printer via your computer? You can also try adding the printer manually. It's share name can be found either via your own computer (in the printer properties), or via the printers web interface (192.168.x.x). To do so, click Start > Printers and Faxes > Add Printer Select "Local printer attached to this computer". Click Next and select "Create new port", then from the dropdown list, select "Standard TCP/IP Port" and click Next. Click Next on the dialog that appears, then enter the printers IP address, and a port name for it (for example for my own I entered "192.168.0.100" as that is my printers IP address, and "IP_192.168.0.100" for the port name (Windows enters this itself when you put in the IP address - you can change this to whatever you like)), and click Next. You will now see a dialog showing you the printer it is going to add. Click Next on this screen.
May 26, 2008 | Office Equipment & Supplies
Have a HP C7280 Photosmart all in one for wireless connection with Belkin 54g Router. Finds router and everything works correctly but when the device is active (switched on) it disrupts attempts to access...
You mentioned it's disrupting internet access when turned on. Can you post the results of a ping and tracert (with it connected via ethernet and turned on)? To ping: 1. Start > Run and type: cmd 2. At the prompt, enter the following and press enter (after each line); cd c:\ ping google.co.uk >> ping.txt ping.txt The last line of the above, will open ping.txt in Notepad, for you to post here. To Tracert: 1. Click Start > Run and type: cmd 2. At the prompt, enter the following (again, press enter after each line) cd c:\ tracert google.co.uk >> tracert.txt tracert.txt The last line of the above, will open ping.txt in Notepad, for you to post here.
May 25, 2008 | Office Equipment & Supplies
77 people viewed this question
jasbo
jasbo
