Question about Canonical Ltd. Ubuntu
Help me to remove ubuntu from my computer - Canonical Ltd. Ubuntu
    Problem Solver:
  • 5 Answers
If you have vista format the ubuntu partion then use EASY BCD to fix the bootscreen.
if you have ubuntu use your live cd and go into the partition manager and remove it from there.
Posted on Oct 07, 2010
How can i see files created in windows os after installing ubuntu 14.04 tls
when you computer turns on it should automatically ask you what os you would like to boot from. on a side note of you go into your harddrive you should find a folder named "windows" or
"windows old" and all the files you saved should be in there. seems to me that u install'd ubuntu over windows and now only have ubuntu on your computer... but you should still have that windows folder if you chose not to delete you files.making a new partition does not mean you will have 2 os's on your computer... hope this all helps.
Jun 29, 2014 | HP 2000-369WM AMD E-450 DC 1.65G4GB 320GB...
Want to unistall ubuntu 12.04 from hp sleekbook and install windows 8.1. pls help
Assuming you have your windows 8.1 on disks, make sure your HP is set to boot from disk and put disk in and boot your computer up. The windows install should start and you can choose to delete Ubuntu and install windows. Remove any partitions that it displays and choose to install windows on the entire disk. After that just follow the prompts and windows will install.
Mar 22, 2014 | Canonical Ltd. Ubuntu
Terminal codes for resetting my pavilion dv5
Not sure what you're asking. First what Operating system are you using and is Ubuntu installed to your hard drive or on a virtual drive?
These are the normal procedures for HP Pavilion DV5
  1. Restart the Computer
  2. Press the F11 key to launch the HP Recovery Manager.
  3. When the "Welcome to HP Recovery Manager" window appears, click Next .
  4. When asked to perform a "Microsoft System Restore" , select No, then click Next .
  5. When asked to perform a System Recovery , select Yes, then click Next .
  6. When asked to Backup Files , select the option you want.
When asked to perform a "Recover your computer to original factory condition" , select Next wait for the recovery process to finish.
Hope this helps.
Jul 23, 2012 | ubuntu.com
Netbook hard drive problem
Please login to the Computer with the Windows Operating System. Now, open the Disk Management window. Click on Start and select Run. In the Run command box, type Diskmgnt.msc and press Enter.
In the Disk Management window, you can view the 66 GB allocated space for Ubuntu. Right click on 66 GB space and select format. Now, you will get free space for Windows only.
Jun 30, 2010 | Acer eMachines eM2501162 Netbook
I bought a secondhand computer with Ubuntu operating system. It is asking me for username and password to log in, before i can go any further. I can't contact the seller to find out. Please help. How can I...
Format ur computer using UBUNTU and do clean install.
The existing data will be lost.
As it is a second hand computer, u dont need the existing data.
Got UBUNTU Desktop edition?
If not try to download it from official UBUNTU site.
Jun 05, 2010 | Canonical Ltd. Ubuntu
How can I uninstall Ubuntu from Dual Boot. I have a dual boot of Windows Vista Ultimate with Ubuntu 9.04 The specs of my computer is 2gb ram, 500 gb HDD and dual core processor 2.66ghz (E5300). I installed...
How to remove Ubuntu from a Vista dual-boot config
On my new PC I wanted (still want) to have toa go with Linux. I chose to experiment with Ubuntu. I downloaded thedesktop CD, burned it, freed up some disk space (inside Vista) andloaded up Ubuntu from the CD. After some experimenting I figured outhow to install Ubuntu in the empty disk space and it all worked fine(GRUB took over my booting (recognized Vista automatically!) and Ubuntuloaded up fine).
Then I tried to install my GPU drivers andeverything went wrong.. For some reason Ubuntu wouldn't boot anymore(failed to load X-Server or something). I was completely lost andwanted to remove Ubuntu.
This is where things start to get really messy!
Ifyou simply remove the Ubuntu partition, GRUB (Linux boot loader) willstill be on your PC (in control). It will trip out, as the Ubuntupartition will be removed.. Bad thing!
So you need to restore your Master Boot Record (MBR) for Vista (so that Vista will handle the booting, not GRUB).
Googleonly pointed me to sites that explained how to REMOVE VISTA, whichisn't what I wanted. Many sites talked about the 'fixmbr' command, butthis is really only available in Windows XP.
So how do you restore your MBR for Windows Vista?
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe /FixMbr, and then press ENTER.
That'sit. Now when you reboot your PC, Vista will load automatically... Youcan now safely boot using your Ubuntu desktop CD, to use the built inGnome Partition Manager to remove your Ubuntu partition!
Apr 06, 2010 | Microsoft Computers & Internet
I dont know how to use wine on my ubuntu
I mean that there is a menu somwhere or you only need to install the "windows" software now.
Wine you use to run windows compatible software on ubuntu
If thats not helps let mee know.
Aug 24, 2009 | ValuSoft Ubuntu Linux for PC, Mac, Linux
Install Ubuntu
Make sure the computer starts from the cd drive.
see this page for instructions on changing the boot order
http://www.whitecanyon.com/how-to-change-boot-order.php
ones the boot order is set properly insert the cd in the drive and restart the computer.
ubuntu cd/dvd will load and give you some options on the screen, follow the prompts to install ubuntu.
if you need more help read the ubuntu documentation
https://help.ubuntu.com/community/Installation
if the above link is broken try
http://help.ubuntu.com/community/Installation
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
Download Ubuntu
Hello Eitan,
I will provide you the direct download link for Ubuntu latest version. And this the original version.
Here is the link:
http://www.ubuntu.com/getubuntu/download
You will have two options either you can download the CD version or DVD version. Also you will have the case studis, online support and the documentation for installing Ubuntu.
Sep 10, 2008 | Canonical Ltd. Ubuntu
Canonical Ltd. Ubuntu Logo
170 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
none
k24674
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
