Question about Kodak EasyShare V610 Digital Camera
Errer #45 kodak v610 - Kodak EasyShare V610 Digital Camera
    President:
  • 1,932 Answers
The problem seems to be with your lens guide it is out of track so please follow the step below,
Try forcing the camera lens but be careful while doing this if something goes wrong your camera our lens can be damage
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
If no luck then contact your Kodak service centre
Thank You
Posted on Oct 01, 2010
I just want to know what it errore 45???????
Hello, The system error codes are for kodak diagnostic purposes only. just like you vehicle stores trouble codes for the tech to obtain info for locating system problems. Needs to be serviced.
Best Regards, Russell
Dec 13, 2012 | Kodak EasyShare V610 Digital Camera
Kodak V610 Easyshare won't turn on
You have a board power supply issue which would be covered under warranty. (Hopefully you still under warranty)
Aug 19, 2007 | Kodak EasyShare V610 Digital Camera
Error 45
Hello, The error code 45 indicates that the camera needs service/repair. You need to take it to a camera shop for them to determine the problem.
Dec 09, 2012 | Kodak EasyShare V610 Digital Camera
Hello, I'm from Indonesia introduce doctoral pocket digital camera. to the problem of error 45 on kodak V610, V570, V705 caused by a focus motor carry. I often deal with the problem that I have about 430...
Error 45 usually shows up when there is a problem with the camera's lens. The camera locks up to prevent further damage. On some Kodak models, there is a notation in the user's manual that only says that the camera needs to go in for service.
So, what can you do? Try taking the camera and tapping the edge nearest the lens hard against your hand several times. This can dislodge any grit that might be jamming the lens. Turn on and test.
Clean with canned air. Using short bursts about 2 inches away and at an angle so as to blow any debris out instead of deeper in. Go around the lens turret and then test.
(At your own risk) set the camera on a tabletop and look at the lens to see if it is out of alignment. If it looks off center, push the lens toward the greater gap until you hear a click. Turn on and test.
If none of these work, then your camera needs to be physically examined by a repair technician.
hope this helps.
Feb 23, 2011 | Kodak EasyShare V610 Digital Camera
My shutter is broken on my Kodak V610
I'm afraid your camera needs a repair. There's no other way. Contact Kodak under 1-800-421-6699.
Mar 10, 2010 | Kodak EasyShare V610 Digital Camera
My camera error # e 45
This is a lens fault and unfortunantly the cam. needs a repair.
In order to arrange the repair: Pls. contact your dealer or KODAK directly:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=4248
Sep 27, 2009 | Kodak EasyShare V610 Digital Camera
Kodak V610 Camera error #45
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Aug 18, 2009 | Kodak EasyShare V705 Digital Camera
Camera blanks out with message- error 45 and its not coming on
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EasyShare V610 Digital Camera
Kodak V610, Lower lens not working
I had the same problem. The lower lens wasnt working, but if i zoomed enough the screen would turn back on.. Heres what worked for me.. go into menu, select setup menu, then select digital zoom. and select "off" . now the botton lens should work. take a picture, and then go back into digital zoom menu and select on, and all the zoom views should work!
Oct 07, 2008 | Kodak EasyShare V610 Digital Camera
Kodak EasyShare V610 Digital Camera Logo
62 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
