Question about B.C. Rich Nt Warlock Electric Guitar
I have a BC rich bolt on body bass guitar..IT SUKS!! it has intonation problems like crazy. I had 250.00 dollars in electronic repairs..new potts new pickups..new bridge..new strings and a new body works. the bass just wont intonate. and still wont.. the saddles are all the way back on all strings and I still cant get the damn thing to intonate. Dammit!! The sound is flat non resonating. I am a active musician and this is about to be a useless piece of wall art very soon..I need help! What do I do with this expensive nightmare it is a BC Rich Warlock
  • Joe Patch
    Joe Patch Mar 06, 2013
    One more thing, I have NEVER seen any guitar have to have the saddles all the way back. Sounds like you may be going the wrong way or not sure of what you hear while trying to set it. My top 2 strings are at halfway, My D is about 2/3 forward, and my bottom G is about 3/4 forward. This should be a close approximation to yours.
    Problem Solver:
  • 9 Answers
TAKE THE LOSS AND START OVER. YOU PUT TOO MUCH MONEY INTO IT ALREADY UNLESS IT'S AMERICAN MADE......SORRY
Posted on Feb 22, 2013
    Sergeant:
  • 336 Answers
Obviously, Mike Rodgers has misunderstood the question and has no idea what intonation is. I have the exact same guitar in flame red and mine works great, it comes with the badass 2 tailpiece. I am using ROTOSOUND swing bass strings. The guage of the strings makes a big difference. I do agree with Kreesha to a point but that a loose tuner would not stop intonation setting, it just wouldn't stay tight. Knowing how to set it properly is the key. Stabilize the tuning(if you have a bad machine head) or replace. The 12th fret harmonic should be the same as that fret pitch when checked with a tuner. IF you have changed the neck for any reason, it may be a different scale. Check thoroughly.
Posted on Mar 06, 2013
5 Suggested Answers
  • 11 Answers
SOURCE: How do i repair my B.C. Rich guitar??
Guitar manufacturers use generally one of two different knob types: (1) knob has a small set screw of some type holding it on or (2) press fit onto the shaft of the tuneing pot (volume knob in your case).
Now, the problem is if it is NOT a set screw type, it is press fit. You see press fit used most of the time on lower-end instruments (and a few high end). The BEST way to get a stuck volume know off is to get a shoe string, loop part of it under the knob, brace the guitar firmly and PULL SLOWLY WITH FORCE. Realize that it is possible to damage the guitar if you **** on the string too hard.
I have never seen where a stuck know did not come off (or hear of someone breaking their guitar doing it).
I have also resorted to using a small screwdriver: work it way under the know and gently twist it to loosen it so it can be pulled off with a string or your hands.
Be carefull not to scratch your guitar!
Good luck,
-mike
Posted on Mar 30, 2009
  • 10 Answers
SOURCE: ibanez intonation problem
Might be best to learn how intonation is worked out so you can spend some time doing it yourself. I used raeguitars guide, found it to be pretty good!
Posted on Nov 30, 2009
Kree8iv
  • 192 Answers
SOURCE: g string on epi sheraton elistis loves going out
It sounds to me like you have a machine head that needs to be replaced. That is the only possible thing left, and it has certainly happened to me before. I have been playing and building guitars for about 25 years now as a serious hobbiest. So I'm not just shooting in the dark about this. The fix is inexpensive and an easy replacement. Your string gauge is not the problem.
Hope this helps.
Posted on Jul 09, 2009
  • 5603 Answers
SOURCE: How do I change the
There are good videos of guitar setup on YouTube. Search for them.
Posted on Dec 03, 2010
B.C. Rich Ironbird Pro guitar serial no G01111219. What year was it made and where?
Dating Your Rich Guitar Dolphin Music
The relevant part -
In November of 2000 B.C. Rich implemented a new date stamp format for serial number coding of it's imported models. . This started on the January 2001 models. All B.C. Rich models, both imported and usa handmades implement this same year time date stamp and guitar production number format:
121XXXXX first digit = year of manufacture
second digit = means nothing until double-digit years get here again
third digit = quarter of manufacture
digits 4 thru 8 = production number
Current US-made B.C. Rich serial numbers follow the same year and guitar production number format. (example - serial number #24123 was the 123rd guitar made in 2004)
Jun 10, 2016 | B.C. Rich Music
I need documentation to set neck adjustment and intonation for a Gibson ES-359 custom. It doesn't seem that Gibson has anything readily available.
Intonation is easy if you have an electronic tuner, and instructions for a Les Paul style guitar will be close enough. Same with neck adjustment, if it is a set neck, use the Les Paul info. If a bolt on neck, everything but the neck angle is still relevant.
Jul 01, 2011 | Gibson Guitar Gibson Custom ES 359 Semi...
The D string on my new J-45 standard sounds unmusical , as if there are no rich overtones . I can tune the string with my electronic tuner but it never sounds musical. I think it has Gibson Premium...
Hi. Your guitar may not be intonated properly. You might want to try to level and balance the height and strings all throughout the neck. The level at the rear half (close to the soundhole) can be slightly higher than the front half (near the headstock). This can be done be adjusting the truss rod, nut and/or saddle.
Note: You may want to get a guitar luthier to do the trussrod, nut and saddle adjustments as these are very delicate procedures.
May 13, 2011 | Gibson Guitar Gibson SAG MB11 Masterbuilt...
Looking for new pickups but I don't understand the wiring schematics on the BC Rich site.. I bought my B.C Rich Mockingbird ST on the internet.. without schem. I just can't find the right one.....
I'm not sure if you have access to a local Guitar Center, but their guys can walk you through the schematic pretty easily. You'll probably have to go to one of their locations and take to guitar dept/
Feb 26, 2011 | B.C. Rich Mockingbird ST Electric Guitar
When I recieved my BC Rich Virgo celtic bass there was no problem. I played with it for almost an hour. Later I wanted to play another time so plugged it in. No sound came from my bass. I tried to replace...
Intermittent problems can lead one on a merry chase. The first suspect would be the guitar cable.
Players learn to check the connection to the amp is good by touching the tip of the cable and observe you get hum.
It is UNLIKELY to get two bad guitars so we need to check everything else. Cable is next suspect.
Check the cable IS for intruments and NOT speakers. Check that the tips do not spin. Some cables become worn and the sleeves no longer actuate the switch that turns the battery in the guitar on or the tip fails to make contact. Do not use cables that are intended to connect stereo systems. Use ONLY instrument rated cables.
Feb 24, 2011 | B.C. Rich Virgo Vintage Celtic 4-String...
How do I lower my strings closer to the fretboard
There are a few different ways to do this, and unfortunately if you have not done this kind of work before you could end up damaging the guitar more than fixing it.
A few things to look for:
Sight down the neck from the top of the guitar looking down along the edges. If you see a concave (banana shaped) bow in the neck, it needs adjustment. Almost all guitars including yours have a neck adjustment rod that can alleviate some of the bow. If however the neck is convex ( higher in the middle) the neck would need adjustment too. You want a very slight bow in the neck to allow for weather changes as wood expands and contracts with the weather.
Other adjustments are down on the bridge. There are usually very small allen or hex key adjustments for each string to raise and lower the action (height) of the string. Again, any adjustments here can also affect the tuning of the string up and down the neck (intonation). The guitar may not end up being tuned at one place one the neck while in tune on another.
I would highly recommend taking this to a music store with a qualified person to adjust it. Many times the action can be lowered and the string height adjusted for better playing ability. You can inform the technician now what you see and what you want done. Also let them know if you have a heavy or light touch on the strings as this can make a difference when they adjust it too. At the same time a lot of them also restring your guitar for you and you may request a lighter gauge of string allowing for better play too. Good luck.
Feb 21, 2011 | B.C. Rich BC Rich Kerry King Wartribe 7...
Ibanez intonation problem
Hi there. Use guitar tuner. Pluck string in open position. Tune. Now pluck same string at 12th fret. If tuner says flat, adjust bridge for that string towards neck. Towards bridge if sharp. Repeat procedure until in tune at open and 12th fret. Go to next string and repeat procedure.
Thanks
Paul
May 11, 2009 | Music
Good luck,
-mike
Mar 30, 2009 | B.C. Rich Nt Warlock Electric Guitar
B.C. Rich Nt Warlock Electric Guitar Logo
340 people viewed this question
Top B.C. Rich Music Experts
Eric
L. Sawyer
rhodesworks
Are you a B.C. Rich Music Expert? Answer questions, earn points and help others
