Question about Maytag Washing Machines
Agitator is not turning and after a minute of running it will start to sqeel. Have cleaned out pump and hose running to pump. Did notice the motor is on a base and has some play in it, should it be stationary or move back and forth?
    Scholar:
  • 157 Answers
Hello switchwitch, There several parts that could cause this problem. #1 a drive belt has weakened, #2 the Agitator bearings or cushions badly worn, #3 the motor may have rubber supports gone bad. As "Number 5" stated "More Input" , Please provide the model
Posted on Oct 01, 2010
The agitator will not turn
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Agitator on a Inglis Niagara washer
Dec 31, 2009 | Washing Machines
Agitater is weak and stops 3 minutes into wash
Dec 23, 2009 | GE Washing Machines
Whirlpool washer agitator not working
AGITATOR REMOVAL GUIDE
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Dec 13, 2009 | Whirlpool Washing Machines
Agitation doesn't start. First we could do this when just hit the cover or press it, but now it doesn't help.Eugene and Galina
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Agitator not working, does complete cycle with no agitator
Oct 02, 2009 | GE WBSR3140DW Top Load Washer
Water pump is makeing a squeeling noise, I want to dissassemble it to see if something is inside the pump
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary.Always remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
However Open the washer lid to gain access to the agitator. Depending on your model, lift the fabric softener dispenser off the top of the agitator. Some models only have a cap that lifts off the top.
Remove the barrier cap and the o-ring by pulling them out with your hands. Inspect the o-ring for damage and wear. Replace it if necessary when reinstalling the agitator.
Remove the bolt that attaches the agitator to the clutch in the middle using a socket wrench. Lift the agitator out of the washer. Some models, like Maytag, have a flex vane agitator which requires it to be lifted off bell housing. This is accomplished by inserting two screwdrivers opposite each other between the tub and the agitator. Lift up to remove from the bell housing.
Turn the agitator over to reveal the cogs that are in place. Remove the cogs from the agitator by snapping them out.
Thanks for contacting Fixya.com
Sep 29, 2009 | Maytag Legacy Series Top Load Washer
Will not agitate but spins
Sep 10, 2009 | Amana LWA90A
Having trouble with my 1974-78 outboard marine engine
Just an idea but your water pump is only rubber and setting for the winter it didnt stick to the sides of where it pumps did it.. sometimes these pumps are tempermental.. you might check your water pump again making sure its pumping right.. is it peeing out the sides good like it is suppose to ? also if its getting hot on top it makes me think the pump is not doing its job right maybe just pumping some.. not enough? just a thought .. thanks Jerry
Apr 27, 2009 | 2004 Mercury Mariner
Waher
First thing is belt broken? If not try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor.
Nov 07, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
