Question about Sharp R-1502 Microwave Oven
I've had mine for approx. 5 years and this year the buttons started to not work. I could only use the One Minute Plus button. This morning nothing worked! I unplugged it, replugged it and still nothing. Now what?
  • Sharp Master
  • 9,047 Answers
On these models, each of the four plastic buttons on the right side of the control panel runs a hidden pad on the membrane keypad.
The other pads on the keypad are fully exposed once you open the door and you just press them directly to operate them.
These plastic button assemblies have been upgraded due to weakness and breakage.
Most often it's the bottom two buttons (Stop/Clear and Start/Minute Plus) that fail.
You can order the button assemblies here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The service manuals you need to refer to are here and here.
Posted on Oct 02, 2010
Our LG microwave (LMA 1560SW?LMA1560SB) has a door that won't open. The open button will push in, but not release the door - the plastic button cover pops back out, but just the cover - not the whole...
Mine did this too. Also, at times when I would shut the door, the whole keypad would go dark and the clock would have to be reset. There were also times when I would push Start and it would do nothing. I'd have to unplug it so it would reset itself.
I used a screwdriver and forced the door open. Mine is about 2 years old and it's now dead. Biggest piece of junk I've purchased in years. Really ticked me off, no more LG products for me. I had a Toshiba that lasted me 22 years and the only thing that went bad on it was the light stopped working and the fan cover fell off.
Mar 20, 2011 | LG LRM1230W Microwave Oven
Display panel is all white, nothing showing. microwave was still operational using "easy minute" button for quick re-heating for a few weeks, however, now that has stopped working. lights on the unit...
This is a common problem. Your CPU / LSI / display unit needs to be repaired or the entire control unit needs to be replaced.
We regularly repair such display units for customers nationwide by mail for only $39.95 postpaid with a one-year guarantee.
Or you can order a new control unit (part number 101871
) here for $244.36 plus shipping.
Aug 05, 2010 | Dacor DMT2420 1200 Watts Microwave Oven
Lower button - Start Minute Plus, does not return. Spring broken?
you have a bad spring and micro limit switch. You need to pull the cover in the front in order to remove that.
Jul 28, 2009 | Sharp Microwave Ovens
Sharp R-1510 Start Button Not Working
This may not solve your problem, but on my Sharp R315J microwave, the little plastic pin that pushes forward on the inside of the start button, had broken off and it wouldn't start. The Minute Plus button would start the microwave, so I knew the microwave worked, so I tried to find a piece of plastic that I could glue into the start button hole, because the part doesn't exist and you have to buy the whole door for $100 plus shipping. Nothing I could find was small enough, so I started looking for a new microwave.
While ouside doing lawn work I noticed a small bird tail feather and the end looked to be the perfect size. I snipped off the pointed end and then up about 3/8" to make a little rod to replace the plastic one that broke. It fit perfectly!!! I didn't even have to glue the inside end, it stays put even after repeated door opens. This is sturdy material and looks to last a long time. When it wears out, I have a cat, there's always a few feathers around. I hope this saves someone else a hundred bucks, like it did me.
Mar 09, 2009 | Sharp R-1510 Microwave Oven
Chefmate microwave oven won't start, only flashes numbers.
Well I had the same problem. It made me start unplugging a microwave when it wasn't in use, which is always a plus.
When it does the whole 6666 thing, press 5 and then stop/reset. It usually allows me to input what I want after that.
Good luck people.
Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1500 - Start/Minute Plus Button Inoperable
Please be careful with the knife - you may damage your keypad.
You can order a new and improved select button assembly for only $15 postpaid here.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
It will show you how to do the disassembly.
Also at our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
By the way commonsenfs, we also regularly repair these control units & displays for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
It's much less than buying a new control unit which is bound to fail anyway.
Nov 04, 2008 | Sharp R-1500 Microwave Oven
Comes on when you open door, and now it finally quit working
I think you've put up with enough hassle from this unit and should get another one. Intermittant flakey problems are hard (read expensive) to fix.
Dec 29, 2007 | Panasonic NN-S962 Microwave Oven
Sharp R-1502 Microwave Oven Logo
250 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
