Question about LG L1951S (Black) 19 in. Flat Panel LCD Monitor
Scratches on monitor!
There are scratches on my LG monitor, where can I get that repaired... or how? Please don't tell me it's not possible.
  • CHERRYTOP May 26, 2008
    Does it even out the surface too? People have told me about vaseline also, but I'm not looking just to fix the colors. It's the scratches that bother me. Thanks for the reply.
    It's called "Clear Reson"? I can get this through just any tech?
    Genius:
  • 1,224 Answers
Its possible this requires a special solution similar to the one you find cleaning your cd's but a tech will have to apply this for you dont let them tell you it cant be its call clear reson (spell check) this stuff has been around since rear projection tv's and works quick and fast there is a down side with though if you dont know how to apply and wipe off you can ruin your screen it requires a heat source to apply
Posted on May 26, 2008
  • Christophe Thompson
    Christophe Thompson May 26, 2008
    yes it evens out the colors this is something they dont tell you but your screen is actually a hard plastic the resisin is applied heated on it fills it in then they smooth the surface to clear shine it gives it a clear shine finish like you were looking at a new screen but the solution if you get wrong it will mess up the screen i watched it be applied at the factory for a coledge class tour trip it was the most interesting thing during that time i remember
How to remove scratch in pulsar
Hi, Raj for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
What good for removing light scratches from tank Honda CBR1000 Forum...
http://etalkindia.com/talk/showthread.php?13656-Scratches-on-Pulsar-135-cc-fuel-tank-What-Should-be-Done
Easy Fix Car Scratches with WD 40
How to touch up scuffs scrapes scratches on your scooter using touch up...
How To Remove Swirl Marks Scratches Chemical Guys Car Care
Jan 25, 2014 | Bajaj Motorcycles
Remove scratches
how to remove scratches from motorcycle tank
Fix Car Scratches New Easy Method
How can i repair scratches on a plastic caravan window
Plastic polish comes in a variety of grits to help buff out scratches in a wide variety of plastics. Novus is a popular brand; their stuff comes in 3 grades: #1 for very fine scratches, #2 for moderate scratches, and #3 for deep / rugged scratches. I generally use #2 polish; #3 polish leaves smaller scratches behind that must be buffed out using #2 polish. Auto repair shops also sell plastic polishes. You might also be able to use automotive rubbing compound, if you don't have access to plastic polish. In a pinch, you can also use traditional white toothpaste, as it contains mild grit (that's how your teeth get polished, after all). Note that toothpaste may also leave behind small scratches.
In terms of hardware, some people use a rotary buffer (like you'd use with car wax) to apply the polishing compound. I have tended to leave swirl marks when I use one. Some people use a Dremel rotary tool, but the super-fast rotational speed can melt/burn the plastic if you apply too much pressure. I prefer to use a soft, all-cotton cloth (an old washcloth or tube sock turned inside out works well), with a dab of polish on it. For straight line linear scratches, I generally run the polish along the scratch to lift out any paint, etc, and to soften the walls of the scratch. This alone usually makes the scratch a lot less visible. However, to finish the buffing, it's good to polish in a circular motion to feather the areas immediately surrounding the scratch into the scratch area.
Some plastics are tougher to polish than others. Super-hardened plastics and some polycarbonates will not clear up using these methods. Most, however, will at least look better after you've done a bit of polishing, even if the scratches don't completely disappear.
May 11, 2011 | Watches
Glass hit lcd tv
my LCD 50 inches that is scratches on the screen with a stick when my son swings the stick and scratches on the screen. Please tell me how to fix it.
Jul 06, 2008 | NEC MultiSync LCD15T Monitor
Long scratches on my LG Titanium refrigerator door. Is there a way to fill or buff out?
Unfortunately there is no way to fix this problem. The doors can't be "buffed" out to repair scratches. The only way you can fix scratches on the refrigerator is to buy "touch up paint" from LG and it is only for the sides of the refrigerator. To fix this problem you will have to purchase a new door. You can call LG Parts Dept. 888-393-6484 to purchase this door.
Apr 28, 2008 | Refrigerators
Repaire scratches on a lcd flat screen
The eraser method is even better than I first thought.
I acquired my first scratch some weeks back, tried the eraser method, and was quite pleased with the results, as my scratch was approx. 80% less visible, a faint grey line visible only on very light or dark coloured backgrounds, instead of the glaring black line it was at first.
Today my monitor toppled again (I really must tether the damn thing to something next time) creating - gulp - a new and even larger scratch. Oh, no... But whodathunk I'd end up happy I got the 2nd scratch? Oddly, I am happy, 'cause I took the opportunity to lay the monitor flat, take my white eraser again , and really go to town rubbing both new & old scratches. Lo & behold, both scratches appear to be now virtually 100% invisible or gone. My 2-scratch monitor is better now than it was as a one scratch one! I'm now convinced it's partly, largely, or completely due to the heat from friction of rubbing the eraser across the scratch, plus pressure applied, that does the trick. The heat must soften the plastic surface making it malleable, and the pressure of rubbing smooths out the jagged scratch edges, making the scratches disappear.
-So, if at first your eraser doesn't completely eliminate your scratch, try, try again! Keep working on it - harder!faster! And with luck, you'll get results like mine: complete elimination of two ugly scratches!
Apr 25, 2008 | Computers & Internet
Small scratches and watermarks that I can't get rid of.
Best left alone me thinks- you may EMHANCE the damage.
May 20, 2007 | LG Flatron F900P 19" CRT Monitor
Removal of Scratches on TV Screen
you can try toothpaste. use on the scratched areas in a circular motion for around 5 minutes. This can reduce, and remove scratches from plastic, and even glass. Wipe of with a clean soft fabric or tissue paper lightly moistened.
Another solution is scratch-out. Which is used to repair spiderweb scratches in the clearcoat on automobiles. This is a polymer coating on cars. Your screen is also a polymer. follow the directions carefully, and don't get too aggressive with it. If it doesn't work, what you lost?
The poster above is obviously inexperienced with this type of thing.
Dec 26, 2006 | LG 30FZ4D TV
TV Scratch
You can probable conceal the scratches but a complete repair is not possible,I've seen people who repair cracks in windshields using a special compound that dries clear but even that only conceals the scratches.I hope the scratches are not too deep and you can hardly see them when the set is on.
Oct 10, 2006 | Panasonic CT-27G14 27" TV
LG L1951S (Black) 19 in. Flat Panel LCD Monitor Logo
65 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
