Question about SkyScan 86709 Atomic Wall Clock
My clock has a blank face. I changed the batteries. Still blank. I don't know how to set it. Please help me...or is it broken?
  • macmoss Oct 01, 2010
    You sent an answer for model # 86709. I had stated that I have model #86715. Does that make a difference?
    President:
  • 1,796 Answers
Check your batteries, not because they are in the package it means they are fully charged. If you don't have a battery tester available, test them with a flash light or try installing your remote control batteries. Make sure the contacts are tight and clean. If there are signs of corrosion on the clock battery terminals, clean with a Q-tip and alcohol. Take out the batteries, let stand for about 30 sec replace batteries and reset clock. This clocks usually set themselves within 24 hrs. If asked, select mode to set your time zone.
If this don't work, your clock may be defective.
keep me posted!!
Posted on Oct 01, 2010
    President:
  • 4,070 Answers
Hi! Once you installed the batteries it should be working immediately. Its a plug and play thing that when it doesn't respond on the new batteries then I believe that it reached it's break point. Im sorry to say that but it's unrepairable.
Unable to set clock on pioneer super tuner IIID - tried holding down clock button but time doesn't flash. Your assistance will be appreciated thank you
To set up the clock...
Turn radio off.
Hide clock face.
Press and hold a few seconds “clock button” to bring clock face up.
Press and hold “power on button” till clock starts to blink.
The 4 buttons in a cluster on the right under audio, move the hours and minutes.
press power when done.
I hope this helps
Please rate accordingly
Thank you
Computerrep
Apr 27, 2008 | Car Audio & Video
Does anyone know how to change the clock face on an ouku double din gps stereo unit? I just installed one in my truck and the clock has Minnie Mouse. Cmon, this is a man truck. Minnie Mouse? Also the
Just touch the clock. It's actually your screen saver and you can then it off in your settings. But I'd you just want a different clock, simply touch the clock and it'll display another style.
Dec 30, 2012 | Crown Ouku 7" Touch Screen Dvd In Car...
9 v battery won't turn on the clock
Check battery clips for corrosion, if okay! try a fresh battery first, if no change the unit must be dismantled to inspect the 9volt red and black wires inside to make sure it has not broken free.
Apr 18, 2012 | Timex Auto-Set Dual Alarm Digital Clock...
There seems to be power going to my Mr. Coffee (the clock face is lit- though the clock face is blank). However, when I push the "brew now" button nothing happens. I changed outlets and still nothing. I...
Does the bottom pad get warm? If not it maybe a relay on the control board or most likely the element is bad. You can change this out but it is probably more cost effective to just purchase a new one.
Aug 21, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
Sony NWZ-E438F clock display is blank..
To set date and clock:
1. Go to Settings (looks like a suitcase-bag)
2. Go to Common Settings
3. Go to Set Date-Time (this allows you to set the date and time)
If you want to change date and time display format, you can also do this under common settings.
I hope this helped
May 28, 2009 | Sony NWZ-E438F Digital Media Player
I HAVE A KENWOOD KDC 122 CD CAR STEREO. THERES A CLOCK ADJUSTMENT BUTTON,WHEN I PRESS THE CLOCK ADJUSTMENT BUTTON THE CLOCK "FLASHES" BUT I DON"T KNOW HOW TO SET IT,I DON"T KNOW HOW TO MOVE THE NUMBERS,IF...
For the manual for this unit head to this page
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf]
However im pretty sure you actually use the volume or tune/seek to change the numbers then when changed to what you woudl liek again simply hit the main button you used to get into the clock setting originally,
Hope this helps
Cheers
Steve
Mar 09, 2009 | Kenwood KDC-122 CD Player
Skyscan Atomic Clock WWVB
figure out where yu are north south west east zones on your map from where yu are , then pull battery again it should stop at for eight or twelve push time zone then set in a window facing your zone it should automatically pick it up shortly in awhile
sw i think it may stop at four also but then wait
Oct 14, 2008 | SkyScan 86709 Atomic Wall Clock
How to I change the clock setting for a pioneer car radio deh-2750mp
Turn on the car so the stereo is playing.
Press, and hold for a few seconds the 'SRC' button [Bottom left side of the unit face]. This will turn the radio OFF. The clock may or may not be visable at this time. If it is visable, press the 'CLK' button [top left side of the unit face] to make the clock turn OFF.
The screen should now be blank and dark.
Press the 'AUDIO' button [Top Right side of the unit face] and hold for a few seconds. This will open the functions menu. The clock setting should be first in the list. Use the arrow keys to set time and toggle between the hour and minutes.
By sequentially pressing the 'AUDIO' button, you can also set the tuning scans from 100 to 50 kHz in FM or from some other scans in AM, but there is really no need to do this.
Mar 21, 2008 | Audio Players & Recorders
Honeywell programmer gone dead
lift the face plate off and change the batteries
Jul 07, 2017 | Honeywell 2-way Oscillating Ceramic Heater
SkyScan 86709 Atomic Wall Clock Logo
Top SkyScan Home Experts
nejones57
nejones57
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a SkyScan Home Expert? Answer questions, earn points and help others
