Question about Intel Motherboard
Widows server-2003 sir i want to ask that i am having a domain which is having only win-server2003 and two clients i download my photo from web cam and i want to see my photo to all the clients
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Need to send it threw your email
Posted on May 28, 2008
Dear Sir, We have one IBM x206 8482 I8S Serer. We have loaded Win XPP to this system and configured as Thin Client Server. The Thin Clients hang during the operation. The Thin client Vendor identifies this...
You have a compatibility issue as per your comments and you have no choice but to use the components and operating system that will work with each other. Without drivers you are in deep doo doo and there is no forcing the issue.
Apr 07, 2017 | IBM eServer xSeries 206
We Are Using Windows 2003 Server,But We Are Not Able To Access Server From Win XP & Win 98 Clients & Also We Are Not Able To Access Clients From Win 2003 Server. Please Help.
You must be on same domain/workgroup to see it and the computers should have an account on the server.
If not you MUST have a user account you are using on the server.
You can try to connect using the IP address of the server as such:
Go to start.run then type \\Serverip\c$ it should then ask for credentials
If not then your server is not on the network properly and you should contact a consultant in your area to configure the server
Mar 16, 2010 | Microsoft Windows Server 2003 Enterprise...
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
Configuring Symantec Scan Engine5.1 on Server2003 to scan solaris
Symptom: SSE install script does not detect the presence of non-global zones on Solaris 10.
Solution: New build (v5.19) supports both global and non-global zone installation.
Jun 22, 2009 | Microsoft Windows Server 2003 Enterprise...
Dhcp in server 2003 in domain not working
Windows 2003 server supports DHCP. If you don't see in Administrative tool DHCP maybe the DHCP role is not enabled. You can add this role in "Manage your server". You don't need to reinstall win 2003 server.
Another way to access DHCP management tool is: in command prompt type mmc and then File> "Add remove snap-in" then "Add" and select DHCP.
Jan 06, 2009 | Microsoft Windows Server Standard 2003 for...
Slow login problem on domain
It could be the clients dont have sufficient hard ware specs ..... or there is a script that is running for the log in that could cause the delay...?? there could be the two ways to handle it... so you need to trouble shoot where the problem lies first then dig in deeper... :0
Jul 29, 2008 | Microsoft Windows Server Standard 2003 for...
Difference between DNS and WINS
WINS is Windows Internet Naming Service, a system that determines the IP address associated with a particular network computer. This is called name resolution. WINS supports network client and server computers running Windowsand can provide name resolution for other computers with specialarrangements. Determining the IP address for a computer is a complexprocess when DHCPservers assign IP addresses dynamically. For example, it is possiblefor DHCP to assign a different IP address to a client each time themachine logs on to the network.
__________________________________________________
DNS, a.k.a Domain Name System is a database system thattranslates a computer's fully qualified domain name into anIP address.Networked computers use IP addresses to locate and connect to eachother, but IP addresses can be difficult for people to remember. Forexample, on the web, it's much easier to remember the domain namewww.amazon.com than it is to remember its correspondingIP address (207.171.166.48). DNS allows you to connect to anothernetworked computer or remote service by using its user-friendly domainname rather than its numerical IP address. Conversely, Reverse DNS(rDNS) translates an IP address into a domain name.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Windows Server 2003 web Edition Driver Problem...
You can download it here:
http://www.microsoft.com/downloads/details.aspx?FamilyID=22cfc239-337c-4d81-8354-72593b1c1f43&displaylang=en
You should always run Windows Update until your system is fully patched.
But, you might want to check with your sound card vendor to be sure there are drivers for W2003. They may be different than the XP versions.
Jul 18, 2008 | Microsoft Windows Server Standard 2003 for...
Win server 2003's drive c: is access to all client computer
Kindly revert for further analysis - for the points below
1.as said above - have you shared c:\ for clients ?
2.Are you using Terminal server - without security policy ?
3.is Your client directing logging in the server ?
if not any of the above please explain - ur problems in point specification.
Regards,
Sushil
sushil.mudaliar@gmail.com
(mail me across in case of emergency)
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
Win server 2003 enterprise
You need to ensure your DNS server is the first in the workstation's DNS list.
Does this help?
Sep 27, 2007 | Microsoft Windows Server Standard 2003 for...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
