Question about Optics
Leupold VX11, the zoom ring is very stiff. Is there an easy fix?
  • 3,186 Answers
No I would return it for repair.
Posted on Oct 02, 2010
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
My Nikon 18-55 mm lens turns easy when zooming in, but is stiff when zooming out. There is no roughness in the movement that would suggest dirt.
hi there,
the zoom-rubber might have been loosen, so it moved too easy while you use it
you can fix it by contacting nikon representative technical support
thanks
Dec 12, 2010 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
The adjustment 3 thru 9 is too tight and hard to turn. How or who can repair?
This is not uncommon with Leupold scopes. The first thing to try is to get a good grip on the adjustment ring and just crank away, making sure you're not trying to go past the adjustment range marks on the adj. ring. If the ring has not been moved recently(like within the past few months) it can take a surprisingly large amount of arm-strong to break the ring loose. The reason the ring can be so difficult to move is because Leupold uses a close(tight) fit to keep moisture out and the dry inert gas(argon or nitrogen) in. I haven't felt a Leupold yet that didn't require substantial effort to move either the power or occular ring. Be sure to wipe down the exterior of the ring to remove any oil or dirt to insure you obtain maximum adhesion between your hands(you did wash them, didn't you?) and the ring. 70% isopropyl/rubbing alcohol and a paper towel(don't soak it) makes quick work of cleaning the adjustment ring. In any event, DO NOT APPLY ANY OIL/LUBRICANT IN AN ATTEMPT TO TRY TO MAKE THE RING MOVE EASIER! All that will do is probably cause the o-ring seals to begin deteriorating, and then you WILL have to send the scope in for repair. Once you have the ring moving, just work it back and forth until it it moves about as easily as it's going to get. If this doesn't work, get on the horn(telephone,email,etc) to Leupold and they'll likely instruct you try what I told you before sending the scope to them. They normally don't consider this stiffness to be a problem as they consider this to be a sign that the seals are working the way they should. Last time I talked to them nonwarranty problems cost $10, warranty stuff was free of charge. Leupold is a class act; they back their product to the hilt. Good luck!
Nov 29, 2010 | Leupold 3 9 x 50mm VXII Series Riflescope...
Power ring selector on 3-9x Leupold scope is difficult to turn--its stuck!
inside the scope are runner rings to keep out dust and water the this ring need changing or lubing,,,have the scope serviced dont try to fix it yourself you wll only bust your scope
Aug 28, 2010 | Leupold Optics
Hi, i was thinking of getting a leupold riflemen 4-12x40 and was wondering if i can zoom in? thanks Taylor
The 4-12 X 40 means 4 time magnification to 12 times magnification with a 40 mm objective lens.
This indicates that you can zoom from 4-12 times the unmagnified size of your subject.
Short answer - Yes!
May 04, 2010 | Leupold ® Rifleman® 3-9x50 mm Scope
Leopold VX11 power adjustment really hard to turn
Take the eyepiece off and clean out the threads with wd-40 or something like that, put on some fresh, light weight oil, a little, and see if it doesn't spin a little better. Sometimes the oil gets gummy and sticky. Hope this helps.
Apr 09, 2010 | Leupold 3 - 9 x 40mm VX-II Series...
Canon 15-55 zoom: won't auto focus. My 70-300 on
focus ring on cannon ef70-300 zoom is stiff, jerky. how can i free it up.
Mar 14, 2010 | Canon EOS Rebel XSi Digital Camera
Screw missing in ring that adjust varible power - this screw is a knob that sticks up so you can turn it. i need to find this screw
Here's the info I found on Redfield's website:
Warranty InformationWhen Leupold purchased Redfield in April, 2008, Leupold did not assume the Redfield warranty. Because many Redfield customers have contacted Leupold with regard to the former Redfield warranty, Leupold is making this information available to Redfield optics owners.
At this time, three Redfield repair facilities are available should your Redfield product require service: Parson's Scope Service(513-867-0820), ABO USA Inc (305-859-2010) and Iron Sight Inc. (918-445-2001). The contacts provided are for information purposes only, as these companies are not affiliated with Leupold & Stevens. Please contact them for all information regarding repair, service, and associated charges.
As a courtesy we are now offering 20% off the price of a new Leupold scope, up to $100, in trade for any defective Redfield scope. If you would like to take us up on that offer you may call us at 1-800-LEUPOLD.
Jan 02, 2010 | Redfield Optics
Tamron 17-50 loose ZOOM ring (not Focus ring or Front Element)
the same thing just happened to me like 3 days ago. The zoom ring was kinda sticky and then all of a sudden it just spins around and doesnt extend the barrel at all.
Nov 16, 2009 | Cameras
EF 24-70 lens droop...
The zoom creep is an easy fix for Canon. I really do not recommend trying to tighten it yourself, since that would void your warranty.
It is usually free to tighten the zoom ring.
/Chris
Dec 13, 2008 | Canon EF 24-70mm f/2.8L USM Lens
Optics Logo
106 people viewed this question
Top Optics Experts
james laughton
james laughton
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
