Question about E-Machines eMachines Desktop PC
My computer will not turn on completely the only thing that happens when I try to turn it on is the fan comes on and spins non stop. Any possible solutions?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
Problem i guess, there may be dust in memory card slot.. cleanup the slot and see that there is all connectors or fixed correctly to mother board and to HDD
Posted on Oct 01, 2010
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
I have a Honeywell Hy108 Quietset Whole Room Tower Fan which suddenly stop running. Its turning ON but the fan is not turning
possible bad motor or bad capacitor try spinning fan by hand if fan runs change capacitor if it dont come on check voltage to fan if voltage is present change fan motor.
Sep 15, 2011 | Honeywell Heating & Cooling
SHUTDOWN ALL OF A SUDDEN WHEN I'M CHEKING MY EMAIL, I TURN IT ON, STAYS ON, CAN'T BOOT, INSERTED OS TO FIX IT BUT JUST SPIN AND STOP, POWER STAYS ON AND FANS ARE NOT MOVING, BLINKING LIGHT IN MOTHERBOARD,...
what hardware have you replaced? do you hear a beeping sound? try removing everything (HDD, DVD/CD/FLOPPY/)except the proc,video card and mem on the motherboard and try to boot. check if it will give you bios. if it still the same, do an isolation test. the main reason why its not responding is your computer doesnt complete POST. POST is one of the process the computer do to test all the hardware that is connected on the motherboard, if one fails and POST doesnt complete, you wont see the BIOS startup screen. Theres a lot of possible fault on this concern. since theres a lot of things connected on the motherboard
Mar 27, 2011 | Gateway Profile® 6C (PROFILE6C) PC Desktop
I have a desktop that resently started with the blue screen of death, now it just go black screen and cant operated even dow you can litsen to the computer running, and i have to shut it down completely...
The thing it sounds like to me is that the computer is overheating. Do you happen to know if the fan has stopped? I would, if your confident, take the side of and turn it on, see if the fan on the processor is spining. if not it would need replacing.
Oct 18, 2010 | Computers & Internet
My computer wont boot up the fan and light turn on for a second then goes right off....
With the little bit of information presented, it appears that this is possible a power supply problem. One thing you can try is to unplug the power adapter from the laptop, remove the battery, then plug the power adapter back into the laptop. Then try to turn it on. If everything comes up normally, then the problem points, potentially, to the battery.
Hope this helps!
Feb 18, 2010 | HP Pavilion dv9000z Notebook
Sony vgn-s460: screen blinks, fan runs very loud
Possible clock timing of CPU is wrong. Is it two fan on this laptop? Maybe one is not functioning. Plus check your power supply if gives correct power!.. If none of this , it comes to the MB and possible a CAPS making problem. Need expert.
JMC
Aug 06, 2009 | Sony VAIO VGN-S460 Notebook
My compaq presario keeps going dead on me
You could have an overheating problem, especially when you try to start the computer up again straight after a shutdown and it won't start, and starts only after it cools down.
This could be caused by a faulty fan (ie has stopped spinning or spins slowly) and or dust clogging the heatsink and or fan.
Clean/remove the dust and if the fan is faulty, replace it.
Mar 13, 2009 | Compaq Computers & Internet
Trouble starting up computer
First thing to do is remove as much as you can from the motherboard, cdrom,some memory(if possible) floppy drives ect...
any slot cards then try it and plug each item in and reboot each time till you find whats causing it. or could be a week power supply
Feb 26, 2008 | E-Machines eMachines Desktop PC
Washer won't complete spin cycle
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
Jan 06, 2018 | Maytag Neptune MAH6700A Front Load Washer
E-Machines eMachines Desktop PC Logo
16 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
