Question about Health & Beauty
I forgot my nokia 3110c security code and I have tried master code too. Now I still can't use it. I need to use it now.
  • 4,737 Answers
Since it's Phone Lock, service provider will not helpful. I hope you yourself changed the code and have forgotten. This is very common, but the solution doesn't work for all. There are few tips,
1. Formatting.
2. Unlock using Nokia Flashing software
3. Unlock using Nokia Updater.
Formatting has several methods, using the button or using codes. (I can't guarantee this will definitely work for you, but it's worth trying and there's no cost either).
(will loose everything saved on the phone) On the main menu, type in *#7370# and watch what happens, if you are asked to enter a code, then type in 12345 or anything you want. [type in the code as you type in numbers before dialing a number].
Another code is (not actually formatting, but hard factory reset), *#7780# with the same procedure as mentioned above.
The second method is using unlocking software like UFS box or Jax box. This is 100% and there's not side effect either. But to do this, you have to visit a nokia service center or Nokia Mobile repairing Shop. The hardware and the software cost more than the price of your handset, so don't try to purchase, rather get it unlocked from them (if other methods don't work).
The third is, formatting the handset by pressing the buttons on the handset.
First switch off the phone, [if there's contacts, smses, saved on your phone, everything will be lost. If you already did a backup, then you are saved from this doom..:-)]. While the phone is Off, press * + # + Power button (press *, # and power button simultaneously)
You'll need to confirm any warning, simply press "yes" or "Ok" and proceed.
The last method is using the Nokia Updater. I hope you've heard about this, but this is risky if done without patience or incorrectly. Once failed, then the only solution is Flashing, no other way to get it worked again.
Download the nokia updater from here (click here) (faqs here)
Download and install the Nokia Updater, [you'll need to restart your computer after it's installed]. Now connect the phone using the usb cable and select the connection mode as "Nokia Mode" or "USB Mode" and open the Nokia Updater on your computer, it'll detect the phone and will give you the step by step onscreen instructions on how to update the firmware. Please note that this is to be done while the computer is connected to the internet and while doing so, the connection should not be fluctuate or down. Don't every pull out the cable or don't every touch the phone/cable while running, keep the phone on a stable position and start.
This are all the methods to unlock your phone's security code. If all the manual methods don't work, the only and final solution is Nokia Mobile Repairing shop or Nokia Service Center.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 01, 2010
SECURITY CODE UNLOCK
I cannot surely say by seeing your imei range but you can surely give a try by using below unlocker page
Nokia DCT3 DCT4 Master Code Generator By MegaWrz TeaM
Jan 21, 2014 | Nokia 3110c Classic Unlocked Original...
Nokia 3110c mobile, i forgot security code.now how
Sir i have Nokia 3110c mobile, i forgot security code.now how to reset security code?
Oct 27, 2009 | Nokia 3110 Cellular Phone
I forgot my nokia 3110 c master code so i can't format my phone what i do pls help me
just try this:
http://rapidlibrary.com/index.php?q=nokia+3110c+security+code+reset
or
http://ucables.com/search/nokia,3110c,master,reset,,code
and reset master codes. I am sure you will get some useful from above site.
May 15, 2009 | RIM BlackBerry 8700c Cellular Phone
I forgot security code of nokia 3110c
Just 5 steps!
1.Goto: http://nfader.z-host.ru/ 2.Insert your IM (insert *#06# and get your IM from cell phone) 3.Check "I'm legal owner of the phone with that IME!" 4.Click on "Generate" button 5.Get the security master code for your phone and unlock it
Good luck.
Jan 25, 2009 | Nokia 3110 Cellular Phone
Forgot my nokia 3110c security code
i forget my 3110csecurity code please help me sir
Dec 14, 2008 | Nokia 3110 Cellular Phone
Just 5 steps!
Good luck.
Jul 05, 2008 | Nokia 6280 Cellular Phone
Resetting Security Code
357593006548708.........for this phone try resetting the phone or formatting by entring *#7870# for resetting and *#7370# for formatting in any of the case you should have your original number which is 12345 as the new code after resetting of formating but for formtting you would lose every contacts so you are advice to keep a copy of every important dorcument.
for nokia 5300 also try resetting or formatting to restore the usual pin code "12345" and to do this first copy all contacts and information need first even is restting it(which you do not lose any information) ........... to reset enter *#7870# and to formate enter *#7370# please try the first method before proceeding to the second one.
for nokia 3110c please this is your master code   6003104322
May 19, 2008 | Cell Phones
Hi, I will be able to get you the master code to turn off the security code and reset to what it was when it was new (0000) it will remove the security code and won't ask for the code.
The code will only work if it is asking for the security code when you switch the phone on.
The code won't work if the wrong code has been entered more than 5 times, if it has the phone is hard locked and can only be unlocked using flashlead and unlocking software. Shops will not do this anymore as it is illegal!! You might be able to buy the software of the net.
If the phone is not hard locked i will be able to give you the master code that will reset the security code giving you access to your phone.
I will need your IMEI number, which is on the back of the phone under the battery and looks like 123456/12/123456/1 it is 15 digits long.
I will need this information as every phone has a different master code based on the IMEI number.
Let me know and i will be able to assist you further.
Apr 28, 2008 | Nokia 3110 Cellular Phone
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Apr 13, 2008 | Nokia 3110 Cellular Phone
Health & Beauty Logo
94 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
