Question about NorStar T7208 Telephone
HOW DO I TURN THE SOFT KEY VOLUME DOWN OR TURN MY RINGER OFF COMPLETLEY ON MY T7208 NORTEL PHONE
5 Suggested Answers
NASAIT
  • 4 Answers
SOURCE: Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
Posted on Oct 29, 2008
SOURCE: Telephone ringer volume
make sure phone is off, then hit prog it will say directory arrow down with the volume key until it says ringer tone. it give 4 options for ringer tones then has off hit select and there you go
Posted on Oct 08, 2008
consultel1
  • 860 Answers
SOURCE: How do you change names on a Nortel T7316 phone?
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Posted on May 07, 2010
  • 19 Answers
SOURCE: How do you turn the ringer back on a T7316E Nortel
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310, ...regards John
Posted on Mar 14, 2011
Testimonial: "Thank you for your quick response, and help! Its most appreciated. So, for my next question How do I program the M7310 :)"
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
How to make a Nortel phone model M7310 ring
If the phone doesn't ring when called by the extension number of the phone then try to use the volume up button while someone is calling the phone. The volume is a multi-purpose button that doubles for phone volume and ringer volume. However, the only way to turn up the ringer is when a call is coming into the phone.
Feb 18, 2015 | Nortel Lands Phones
How do you transfer a call on a Nortel t7208?
This is usually programmed as one of the 'soft' buttons down the right hand side of the device - subject to the programming of your phone / and the system.
Usually the T7208 is connected to the BCM range of PBX systems - in which case, to transfer a call, you'd use Feature 70. You could, of course, program this into one of the buttons yourself, so you only have to press one button to do so.
Hope this is of use to you. :)
Oct 29, 2013 | Nortel Lands Phones
How to forward call to another phone
Press feature soft key (first button under display panel) and the 4.
In order to cancel call forward press feature key, # key, 4.
Jun 23, 2012 | Nortel Business Series Terminal T7208 -...
The ringer is turned off. How do I turn the ringer on? also can I buy another owners mannual
To set the ringer volume of the base unit, press FUNCTION/EDIT, scroll to Ringer Setting using the up or down arrow keys of the navigator key(lower right of base unit), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the right arrow key to save the setting.
To set the ringer volume of the handset, press the CONF/FUNCTION button(lower left) on the handset, scroll to Ringer Setting using the up or down arrow keys of the navigator key(center of the handset), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the soft key SAVE to save the setting. (There are three softkeys directly under the LCD screen of the handset whose functionality can change according to what is on screen)
The manual can be downloaded from the link below free of charge.
http://service.us.panasonic.com/OPERMANPDF/KXTG2770S.PDF
Mar 28, 2011 | Panasonic KX-TG2770 Phone System w/...
The kx-tga510m phone displays "ringer off". How do I change it to get the ringer on?
To change the ringer volume, press the conf/ function button.
Scroll to ringer setting using the up and down arrow keys.
Press the right arrow key to enter.
Press the right arrow key again at ringer volume.
Press the up and down arrow keys to adjust the ringing volume
Press the save soft key to save entry.
Sep 30, 2010 | Panasonic KX-TG5100 Cordless Phone
Ringer off on line 2
To turn the ringer off (or on)
press the conf/ function key,
scroll to "ringer volume" using the up and down arrow keysand press the forward arrow key
press the down arrow key for line 1 and the up arrow key for line 2
select the desired ringer volume by pressing the up and down arrow keys or press the down arrow repeatedly till the screen says "ringer off?"
press the save key (right soft key) you will recieve a conformation beep.
you can exit programming mode by pressing the off key.
Jul 20, 2010 | Panasonic KX-TG2740 Cordless Phone
Password issues
To reset a subscriber mailbox press feature 983, enter in log (default 1020000), on the 3 soft keys bolow the the screen press mbox,chng, enter extension number of the locked mailbox, press reset at the reset password prompt.press rls key
Oct 09, 2009 | Platinum Norstar T7208 Telephone
Ringer
Sep 03, 2008 | Nortel T7316E 2-Line Corded Phone
NorStar T7208 Telephone Logo
99 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
