Question about Maytag Atlantis MAV9501E Top Load Washer
Maytag Atlantis Model Number MAV9501EWW has problem filling with cold water. I have switched the hoses and can fill with cold water through the hot water valve.
  • Maytag Master
  • 19,396 Answers
Hi.
Test and eventually replace the inlet valve.
The inlet valve is tested reading impedance, if it is broken, then it usually read infinity (circuit open). Reaing is done disconnecting valve and pointing multimeter probes at valve solenoid contacts (the cold ones in your case).
A definitive test on inlet valve is done reading volts while cycling and observing if valve is opening. For safety reasons is better if the user performs only tests that can be done with power off.
The switching contacts and inlets is also a test even if basic, I think that the valve is gone.
Here part:
Series 21 models: sub 22004333 (water inlet valve)
Series 12 models:VALVE-INLET
Valve is part nr.2 in diagram below. Click on the picture to enlarge.
If you repute this solution helpful, then please do not forget to accept.
Best regards.
Ginko.
Posted on Oct 01, 2010
Washer will not fill on cold water at the start of any cycle but will fill on the rinse cycle every cycle. Is this a timer problem?
This sounds like a hot AND cold fill washer? If so ->
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 23, 2011 | Maytag Atlantis MAV7000
Water when filling has slowed down cold water is very slow hot is ok
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Will fill with cold water but not hot
the hot water inlet valve is shot replace it
Apr 27, 2010 | Maytag Atlantis MAV7551 Top Load Washer
Maytag Model MAV6000AWN filling with hot water on the cold water cycle.
Try to switch the water inlet hoses, sounds like you have the hot hooked up to the cold water inlet.
If not then the solinoid needs to be replaced
Sep 25, 2009 | Maytag Washing Machines
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold water fill
You need to open the back and follow the cold water hose to the solenoid. Tap the solenoid a few times wile you are trying to use cold wated. If not check for power at the 2 wires that go to this solenoid, if you gout power then you need to replace your cold water solenoid. I hope this helps. Don't forget to rate my answer, thanks.
Feb 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer (approx. 7 years old) has slow stream when filling
Follow the two inlet hoses from the back of your machine. They should each end at a valve (one for hot and one for cold). Make sure that these valves are all the way counter-clockwise and that the hoses are not kinked or pinched.
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
No hot water
Make sure your hot water supply valve is on first. If so then try reversing the hot and cold water feed lines and see if you get hot water when asking for cold. The water valve for the hot water side could be bad. Are you familiar with a voltage meter or know someone that can see if you valve coil is getting 120V when the machine is trying to fill with hot water. If not the control unit is faulty. If you do have the 120Vac on the solinoid coil and no water the either the coil is open circuit(bad) or the inlet is plugged. Most generally the problem is in the control knob unit.
Feb 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV9501E Top Load Washer Logo
409 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
