Question about Minolta Di152 Laser Printer
Toner collection box full? how to fix it? - Minolta Di152 Laser Printer
  • Minolta Master
  • 6,161 Answers
NO TONER BOX ON A DI152
Posted on Mar 01, 2015
2 Suggested Answers
SOURCE: error message in di620
my copier says toner colection box is full what can i do
Posted on Apr 12, 2009
Our kyocera printer says WASTE TONER BOX FULL. what does it mean?
there is a waste toner collector, it is a clear plastic container that collects any toner that is not transferred to the paper. after a certain amount of time it needs to be replaced (or taken out and dump the toner) depending on the copier it uses weight of the container or a sensor to block the light if full. if dumping into a plastic garbage bag make sure it is not dark so the sensor can reset, otherwise it thinks it's still full. You will have to Google where your waste toner box is.
Apr 08, 2014 | Kyocera Office Equipment & Supplies
Tip
Toner Box full when its not - fault
Putting a small lump of bluetac on the inside of the door will push the waste toner collection box into the correct position and stop the empty the toner box fault.
As the toner box is not seating in the sensor correctly.
on Feb 13, 2014 | Kyocera FS-C5030N Led Printer
Waste toner full
The waste toner collection box is located before the imaging unit,open the front door observ a black box,pull out and clean very very good,because in rear part of box is located one transparent window,if is not clean after assambled the box a copier say waste toner box full.
Apr 29, 2013 | Konica Minolta Bizhub C35 Multi-Function...
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Sharp MX 2300N - Toner collection unit needs replacing, not sure what this means. We replaced toner cartridgers very recently and assume this is a container that collects loose toner particles. How do...
REPLACING THE WASTE TONER BOX
The waste toner box collects residual toner that is produced during printing. When the used toner box is full, the display
will show "Replace used toner container". Follow the procedure below to replace the used toner box.
Open the front cover.2
Release the used waste toner box.
The waste toner box will fall forward as shown.
Gently support the box with your hands as you let it fall forward
as far as it will go.
fmtx.png Remove the waste toner box.
Hold the box by both hands and lift it up slowly.
If the waste toner box falls too far forward, it will not be possible
to remove it. (Remove the box when it is at an angle of about
30 degrees.)
Install the new waste toner box.
Insert the box from above at a slant. (The direction opposite to
when you removed it.)
Push the waste toner box into the
machine.
Push the box in until it clicks into place.
Close the front cover
Hope this helps.
Feb 07, 2011 | Sharp MX-2300N Color Copier
I have an MFC Brother printer and I cant copy or print...it says waste toner full??? How do I fix this problem?
What model MFC Brother Printer do you have? The waste toner is left over toner from each print or copy that isn't used. It collects in a different spot in each printer. Usually the waste toner container is with the regular toner cartridge. The printer is able to detect when the waste toner is full by a light sensor in or near that container. Sometimes excess toner collects on the sensor itself and causes it to think the waste toner is full when it actually isn't. Try finding the waste toner container and empty it or replace it. clean the sensor that is on or near the container. it is likely a small black plastic piece that has 2 or 3 small wires coming from it. The model of printer will help to identify where the container is.
Jan 14, 2011 | Office Equipment & Supplies
Self test says 'check waste toner box'
It looks your waste toner box is full. Waste toner box collects toner drawn during printing. You have to remove waste toner bottle and empty it.
Follow the instructions to clean up toner bottle
http://www.kyoceramita.co.th/news/products/img_promain/20091141129533.pdf
Hope this helps
May 21, 2010 | Kyocera FS-C5030N Led Printer
Error message in di620
Mar 16, 2009 | Minolta DiALTA Di620 All-In-One Laser...
Toshiba 2060
bota la botella que esta jenna de toner cuando avre la puerta y ponle una nueva
Sep 23, 2008 | Toshiba 2060 Copier
Minolta Di152 Laser Printer Logo
55 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
