Can i use the command line xcopy in windows 7 to copy the contents of one external drive to another external drive? i.e. if i have drive I and drive J, can I put in xcopy i: j: /s/e at the command prompt and copy all files from drive i to drive j?
  • 734 Answers
You should be able to do so, but Windows 7 requires you run the Command Line as Admin. Go to Start Menu>Accressories>System Tools and scroll to the Command Line Icon. Right click on it and select "Run as Administrator"
You should be successful after that.
Regards
Posted on Oct 01, 2010
Gateway zx4800 MBR is corrupt..error code = 0 x 57...too, need to know correct boot sequence
Windows installation CDs and DVDs have a number of system repair and recovery tools included that can get almost any computer back on its feet after a bad crash or faulty operating system installation. One very common problem that comes up when installing a second operating system is a corrupted Master Boot Record, or MBR. Windows System Recovery has tools that can fix a corrupted MBR, but if you don't have an installation CD or CD drive to put it in, you're going to need to copy the recovery materials to another medium, like a USB drive. If your MBR is corrupted, you probably don't have access to your Windows installation, so you'll have to follow most of these steps on another computer.
b> Insert the USB drive into another computer and run a command prompt window by typing "cmd" into the search box of the "Start" menu and hitting "Enter." Enter "mkdir X:\boot," and "mkdir X:\boot\sources" where X is the drive letter of your USB drive. Type "cd" and press the "Tab" key once, then hit "Enter." Enter "xcopy /H boot.sdi X:\boot," "xcopy /H Winre.wim X:\sources\boot.wim," "xcopy /H c:\windows\boot\dvd\pcat\bcd X:\boot," "xcopy /H c:\windows\boot\dvd\pcat\en-US\bootfix.bin X:\boot," and "xcopy /H c:\windows\boot\pcat\bootmgr X:\" to copy the necessary files to the USB drive. Enter "attrib -r -s -h /s X:\*" Enter "diskpart" to run the DiskPart program, then enter "list disk." The window lists the drives connected to your computer. Find your USB drive in the list and enter "select disk X", where X is the letter of your USB drive. Enter "list partition" to see the partitions on the drive and then "select partition X," where X is the number of the partition listed. Insert the USB drive into your computer and turn the computer on. Allow it to boot from the USB drive. You may have to set your USB drive as a primary boot drive in the computer's BIOS first. Enter your computer's BIOS (by tapping Delete or F2 during bootup, on most computers), then put your USB drive at the top of the "Startup" list. Go to the "Startup Repair" option in the "System Recovery Options" window. The "Startup Repair" process should correct your Master Boot Record and allow Windows to boot normally again. You will probably lose access to any other operating systems installed on your computer, though, since this recovery option is only designed to get Windows working again.
Hope this helps.
Dec 29, 2012 | Gateway ZX4800-06 (PWG8502023) 20 in. PC...
Tip
Copy files even with errors and many more
You might encounter something like "Access Denied", "The file has beentransferred to another location or deleted" or some other errors whilecopying your files.
This is a typical problem to those Windows XP users. So what they do isjust recopy all the files again but they will exclude the one with theerror.
What if you have virus that you are in random folders that can't be moved/copied?
What if your old files that you don't need have random access denied files?
What if and what if?
How to continue copying files and exclude the files with error?
Here's how you do it.
What is xcopy?
Copies files and directory trees.
How to use xcopy?
XCOPY source [destination] [/A | /M] [/D[:date]] [/P] [/S [/E]] [/V] [/W]
[/C] [/I] [/Q] [/F] [/L] [/G] [/H] [/R] [/T] [/U]
[/K] [/N] [/O] [/X] [/Y] [/-Y] [/Z] [/B]
[/EXCLUDE:file1[+file2][+file3]...]
See the REFERENCE below for the detailed meaning
Step 1.
Click Start then click Run...(Or Simply Press Windows key+R)
Step 2.
type "xcopy [source] [destination]"
Sample 1: (For single File ONLY)
xcopy C:/Windows/System32/userint.exe E:/Backup
Sample 2: (For folder including their sub folders)
xcopy C:/Windows E:/BackupWIndows /S
or
xcopy C:/Windows E:/BackupWIndows /E
Sample 3: (For Continue Copying even Error Occurs)
xcopy C:/Windows E:/BackupWIndows /S /C
Sample 4: (For allowing copying encrypted files)
xcopy C:/Windows E:/BackupWIndows /S /G
Note: You can combine the rules/options that you like.
That's it! you now have a way to copy files that are protected, accessdenied, or even those that are encrypted. Hope This tip helps you. ^^
REFERENCE:
What are the use of the options?
source Specifies the file(s) to copy.
destination Specifies the location and/or name of new files.
/A Copies only files with the archive attribute set,
doesn't change the attribute.
/M Copies only files with the archive attribute set,
turns off the archive attribute.
/D:m-d-y Copies files changed on or after the specified date.
If no date is given, copies only those files whose
source time is newer than the destination time.
Specifies a list of files containing strings. Each string
should be in a separate line in the files. When any of the
strings match any part of the absolute path of the file to be
copied, that file will be excluded from being copied. For
example, specifying a string like obj or .obj will exclude
all files underneath the directory obj or all files with the
.obj extension respectively.
/P Prompts you before creating each destination file.
/S Copies directories and subdirectories except empty ones.
/E Copies directories and subdirectories, including empty ones.
Same as /S /E. May be used to modify /T.
/V Verifies the size of each new file.
/W Prompts you to press a key before copying.
/C Continues copying even if errors occur.
/I If destination does not exist and copying more than one file,
assumes that destination must be a directory.
/Q Does not display file names while copying.
/F Displays full source and destination file names while copying.
/L Displays files that would be copied.
/G Allows the copying of encrypted files to destination that does
not support encryption.
/H Copies hidden and system files also.
/R Overwrites read-only files.
/T Creates directory structure, but does not copy files. Does not
include empty directories or subdirectories. /T /E includes
empty directories and subdirectories.
/U Copies only files that already exist in destination.
/K Copies attributes. Normal Xcopy will reset read-only attributes.
/N Copies using the generated short names.
/O Copies file ownership and ACL information.
/X Copies file audit settings (implies /O).
/Y Suppresses prompting to confirm you want to overwrite an
existing destination file.
/-Y Causes prompting to confirm you want to overwrite an
/Z Copies networked files in restartable mode.
/B Copies the Symbolic Link itself versus the target of the link.
/J Copies using unbuffered I/O. Recommended for very large files.
The switch /Y may be preset in the COPYCMD environment variable.
This may be overridden with /-Y on the command line.
Visit redbullet05.blogspot.com for more troubleshooting guides. ^^
on Jan 24, 2010 | Computers & Internet
Have files on a CD that are read only. How can I remove read only so I can make changes to the files. Thank you.
You can use the xcopy command to remove the read-only attribute while you are copying files from a CD-ROM. Xcopy.exe resets the read-only attributes unless you specify otherwise by using the /k switch (this switch copies attributes). To use this method:
  1. Click Start, and then click Run.
  2. In the Open box, type cmd, and then click OK.
  3. Type xcopy drive letter:\*.* destination /e /h, where drive letter is the CD-ROM drive letter and destination is the path to the destination for the files, and then press ENTER. For more information about command-line switches for Xcopy.exe, type xcopy /? at a command prompt.
Jul 20, 2011 | Computers & Internet
I have simply forgotten how to put stuff from my computer on to my external hard drive. I know it was pretty easy, but nothing cpomes up on my screen to go by. Thanks, Rochelle
The process is dependent upon whether you have an Apple Macintosh or Windows PC-branded computer. I will provide instructions for both.
Windows
Plug the hard drive into your computer. Then follow these steps.
1. Click the Windows logo button in the lower left corner of your screen to open the start menu. 2. If using Windows XP, click 'My Computer' on the right side of the menu that pops up. If using Windows Vista or Windows 7, click 'Computer'. 3. The window that opens will display all of the hard drives and other similar devices connected to your computer. Look for your external hard drive. Typically, the letter of the alphabet assigned to the drive will not be 'C:/' or 'D:/', but some other letter further down the line. 4. Double-click your external hard drive's name or icon. Another window will open. This is the contents of your external drive. 5. To copy files to the external hard drive, first locate the file you wish to copy wherever it might be on your computer. Then, click on the file you want to copy and while holding down the left mouse button, drag it into the window for your external hard drive. 6. The file is now copied. The same action can be taken if you also wish to copy whole folders.
Macintosh
Connect the hard drive to your computer, typically via a USB port.
1. The hard drive should show up as an orange icon on your desktop. Double-click this icon to access the contents of your hard drive. 2. To locate files, click on the smiling, rectangular face-shaped icon in the lower left corner. This is the Finder, and it allows you to find your files. 3. Once you've navigated to the file(s) you desire, (these are generally located in the folder along the left side of the window labeled with your name) click on the file names and drag them to the external hard drive icon, which is also located in the left sidebar of the finder window.
This will copy the files to the hard drive.
Hope this helps. If you would like more assistance, feel free to reply to this solution.
Thank you for using FixYa!
Mar 18, 2011 | Computers & Internet
How to repair windows 7 in asus x70a from healthy hard drive
Make the drive bootable xcopy the entire contents of your windows dvd drive to the hdd and select repair my pc when prompted.
Oct 24, 2010 | ASUS Computers & Internet
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
How to use cmd ?
to use the command prompt, press the "start" and "R" keys on the keyboard.
On the small, "Run" screen, type cmd.
click ok.
type help in the command prompt. This should print a list of commands that you can use with it.
This is what it puts on-screen:
For more information on a specific command, type HELP command-name
ASSOC Displays or modifies file extension associations.
AT Schedules commands and programs to run on a computer.
ATTRIB Displays or changes file attributes.
BREAK Sets or clears extended CTRL+C checking.
CACLS Displays or modifies access control lists (ACLs) of files.
CALL Calls one batch program from another.
CD Displays the name of or changes the current directory.
CHCP Displays or sets the active code page number.
CHDIR Displays the name of or changes the current directory.
CHKDSK Checks a disk and displays a status report.
CHKNTFS Displays or modifies the checking of disk at boot time.
CLS Clears the screen.
CMD Starts a new instance of the Windows command interpreter.
COLOR Sets the default console foreground and background colors.
COMP Compares the contents of two files or sets of files.
COMPACT Displays or alters the compression of files on NTFS partitions.
CONVERT Converts FAT volumes to NTFS. You cannot convert the
current drive.
COPY Copies one or more files to another location.
DATE Displays or sets the date.
DEL Deletes one or more files.
DIR Displays a list of files and subdirectories in a directory.
DISKCOMP Compares the contents of two floppy disks.
DISKCOPY Copies the contents of one floppy disk to another.
DOSKEY Edits command lines, recalls Windows commands, and creates macros.
ECHO Displays messages, or turns command echoing on or off.
ENDLOCAL Ends localization of environment changes in a batch file.
ERASE Deletes one or more files.
EXIT Quits the CMD.EXE program (command interpreter).
FC Compares two files or sets of files, and displays the differences
between them.
FIND Searches for a text string in a file or files.
FINDSTR Searches for strings in files.
FOR Runs a specified command for each file in a set of files.
FORMAT Formats a disk for use with Windows.
FTYPE Displays or modifies file types used in file extension associations.
GOTO Directs the Windows command interpreter to a labeled line in a
batch program.
GRAFTABL Enables Windows to display an extended character set in graphics
mode.
HELP Provides Help information for Windows commands.
IF Performs conditional processing in batch programs.
LABEL Creates, changes, or deletes the volume label of a disk.
MD Creates a directory.
MKDIR Creates a directory.
MODE Configures a system device.
MORE Displays output one screen at a time.
MOVE Moves one or more files from one directory to another directory.
PATH Displays or sets a search path for executable files.
PAUSE Suspends processing of a batch file and displays a message.
POPD Restores the previous value of the current directory saved by PUSHD.
PRINT Prints a text file.
PROMPT Changes the Windows command prompt.
PUSHD Saves the current directory then changes it.
RD Removes a directory.
RECOVER Recovers readable information from a bad or defective disk.
REM Records comments (remarks) in batch files or CONFIG.SYS.
REN Renames a file or files.
RENAME Renames a file or files.
REPLACE Replaces files.
RMDIR Removes a directory.
SET Displays, sets, or removes Windows environment variables.
SETLOCAL Begins localization of environment changes in a batch file.
SHIFT Shifts the position of replaceable parameters in batch files.
SORT Sorts input.
START Starts a separate window to run a specified program or command.
SUBST Associates a path with a drive letter.
TIME Displays or sets the system time.
TITLE Sets the window title for a CMD.EXE session.
TREE Graphically displays the directory structure of a drive or path.
TYPE Displays the contents of a text file.
VER Displays the Windows version.
VERIFY Tells Windows whether to verify that your files are written
correctly to a disk.
VOL Displays a disk volume label and serial number.
XCOPY Copies files and directory trees.
this window is used only when the desktop cannot be accessed.
For a user-friendly interface (easier to use), use My computer to do common tasks.
Aug 25, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
