Question about Ricoh Aficio 1035 Copier
Sc101 i got this code sc101. i cleaned the white band, the optic sistem, the lamp is flashing. donno what to do next. is there a way to reset the code (i tried entering in service mode and off and on the switch). pls help
I solved the problem month ago...it was the ccd...thx guyz anyway.
Posted on Sep 25, 2008
    Problem Solver:
  • 3 Answers
THANKS
I SOLVE THIS PROBLEM
SAM
Posted on Sep 24, 2008
  • 62 Answers
The lamp is only good for about 100k copies. How many copies does yours have?
Posted on Jul 07, 2008
CHCK YOUR OPTICS SECTION CLEAN THE WHITE PLATES INSIDE OR OUTSIDE
Posted on Jun 12, 2008
  • Ricoh Expert
  • 287 Answers
Hello Bardel,
Bantam sure seems on the right track as per the Ricoh service manual. Just a thought, flashing the fimware might not hurt.
Posted on May 27, 2008
  • 30 Answers
New lamp or lamp stabilzer pcb no service code to reset sc-101 usually switch on/off should do it!
Posted on May 26, 2008
How to check exposure lamp on ricoh sc101?
Clean the true white on the slit glass housing. Check for a dirty scanner mirror or that the scanner mirror is out of position. Also, check if the scanner is blocked or if the dirty white plate underneath the glass is obstructed. Try cleaning the glass with water. To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
Jul 15, 2014 | Ricoh Aficio 1013 All-In-One Laser Printer
Solution of sc101
clean white plate..
examine exposure lamp(replace when necessary)
check the railings..remove foriegn object found!
Jan 03, 2013 | Ricoh Aficio 450 Copier
Ricoh photocopier 1055 code sc101
for sc101
Exposure lamp error
The standard white level was not
detected properly when scanning the
white plate.
Dec 08, 2012 | Ricoh Aficio 1013F Copier
Probleme de fonctionnement du copieur,rapporter le code panne lors de votre appel technique. SC101
Le niveau blanc normal était not detected correctement en balayant
plaque blanche.
Lampe d'exposition défectueuse
Stabilisateur de lampe défectueux
Connecteur de lampe d'exposition défectueux
Plaque blanche normale encrassée
Miroir de balayeur ou lentille de balayeur hors de
position ou encrassé
SBU défectueux
Exposure lamp error
The standard white level was not detected properly when scanning the
white plate.
Exposure lamp defective
Lamp stabilizer defective
Exposure lamp connector defective
Standard white plate dirty
Scanner mirror or scanner lens out of
position or dirty
SBU defective
Sep 14, 2009 | Ricoh Aficio 450 Copier
Error SC101 on copier
No, you can't reset. You'll need a tech. Here's what the manual says: Symptom (SC101) - Exposure lamp error - The standard white level was not detected properly when scanning the white plate. Possible Cause: ? Exposure lamp defective ? Lamp stabilizer defective ? Exposure lamp connector defective ? Standard white plate dirty ? Scanner mirror or scanner lens out of position or dirty ? SBU defective
Jun 10, 2009 | Lanier Office Equipment & Supplies
Error code of sc101
Directly from service manual: Exposure Lamp Error: Insufficient white level detected when scanning the white plate. Possible cause: ? Exposure lamp defective ? SBU harness defective ? Bad connection ? Defect in optics system (dirty scanner mirror, mirror out of position, etc.) ? Lamp stabilizer board (or connector) defective ? Incorrect start position or length for white plate scanning (☛ SP4-015) ? Scanner HP sensor out of position
Jun 05, 2009 | Ricoh Aficio 1013F Copier
ERROR CODE SC101
SC101 indicates and exposure lamp problem. To try and correct, turn OFF the copier and then unplug from the wall. Wait 10 seconds and plug it back into the wall, then turn on the copier. Watch to see if the exposure lamp comes on - lift the document handler if you want. If the exposure lamp is working correctly, the scanner will briefly move to the right and the light will turn on then off after it moves to the left.
Jul 09, 2008 | Ricoh Aficio 1013F Copier
Message SC101 Functional Problems
If the lamp does come on, remove the left side that holds the glass in place. It usually has the markings for where to place your origonal. Under it you will find a white strip of plastic tape, clean this. that is how it sets its lamp reference.This will usually work for a weak lamp.
Jul 07, 2008 | Ricoh Aficio 1035 Copier
Error code Sc101
SC101 can be caused by a dirty WHITE LEADING EDGE STRIP. This is located under the left side plastic strip that holds down the exposure glass on the left side. Remove the screws, and flip over the glass holder. Clean the white strip with glass cleaner, and reassemble. If SC101 reappears, the scanner drive pulley screws are loose or broken off. A service technician is required for this repair.
Feb 20, 2008 | Lanier 1205 Copier
SC101 ERROR MESSAGE
I'm not familiar with your exact model but for small ricohs....Sc101 means that the standard white level was not detected. When you first turn on your machine the scanner scans a white plate (you will find this plate under the glass or frame near the park position of the scanner (facing down towards the scanner).The scanner will try to take a quick scan of this white plate so it knows the difference between white and black.
You will get this error if anything is preventing the scanner from seeing this plate (exposure lamp not working, Blocked scanner, or more likely a dirty white plate.
Remove the glass, get a mirror and try to find the plate and then clean it with windex. When you turn on machine the scanner will try to scan this white plate( make sure scanner is not getting hung up on anything.
For original size your machine may use paper size sensors that look like small black boxes with two black eyes (under the glass looking up towards the original) make sure these eyes are clean.
Regarding your doc feeder I need more info ( does it attempt to work, etc) describe what it does when you try to use it.
Jan 26, 2008 | Ricoh Aficio 1018D Copier
Ricoh Aficio 1035 Copier Logo
306 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
