Question about RCA WSP155 Main / Stereo Speaker
RCA Wireless Speakers WSP 155 - Transmitter light on sending transmitter is out - it flashes when I unplug and replug the power, but will not stay ona and does not trasmit.
  • rslashaway Oct 01, 2010
    volume is mid way up and it still does not come on. How do you check the power supply? I have a digital meter but I cannot get the prongs inside the plug.
  • rslashaway Oct 02, 2010
    I had the power supply checked and it is not working - tried a new one at Radio Shack but the transmitter still will not work. Now what do I do? any suggestions
  • 2,382 Answers
Hi, the following alternative may solve your problem:
Check to make sure the volume on the audio source is set to a normal volume.If the volume is too low, the transmitter will not turn on.
If it does not solve it, your system has a power problem in the power supply. Make checks on the regulator, it might have a open, if you are not a tech, let a tech take a look on your set to verify the damage component.
Posted on Oct 01, 2010
  • 734 Answers
You have a faulty connection plug. These are small and sensitive. Please take your unit to Radio Shack and insist they help with an actual test plug in. It should then be a cheap fix and you don't have to credit me any money. Just don't leave any rating less than 4 thumbs. Foget I was here. LOL
TheSelkie
Posted on Oct 02, 2010
    President:
  • 2,777 Answers
I have seen this exact problem a few times, it means the transmitter has failed. Do you think this unit may still be under warranty? If you happened to purchase the machine with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the unit.
Thanks Tim
I need a transmitter for a set of rca wsp150 WIRELESS SPEAKERS. CAN I SUBSTITUTE? Where can I buy one?
head phone set WHP141 will work with that set of speakers, look on Ebay
I have a set of the same speakers.... make sure that your transmitter is actually bad, it does not power up with the GREENLIGHT staying ON UNTIL the sound source is hooked up and has enough INCOMING volume to trigger the transmitter on.........
Oct 27, 2011 | RCA WSP150 Main / Stereo Speaker
Where can I get a replacement RCA WSP 150 transmitter? I think mine is bad.
The transmitter does not turn on unitl there is enough incoming volume from the sound source.......it does NOT turn on the green light simply because it is plugged in........the volume is critical.....
Mar 05, 2011 | RCA WSP150 Main / Stereo Speaker
No power light on transmitter. Measured correct voltage at power-in.
the light does NOT stay on .....because it was not designed to.....takes INCOMING SOUNDwith the transmitter plugged into the sound source to make the light stay on......
Oct 02, 2010 | RCA WSP150 Main / Stereo Speaker
Rca 155 Wireless Speaker transmitter not working. Power Led flashes then goes out???????
You probably have the polarity on your plug to the transmitter set on the wrong one. Set it to negative frequency, and it will probably work. I've had the same problem myself.
One other possibility: the Music has to be coming through for the light to go on, so if the music is too soft, you might not get any sound through. Good luck!
Jul 16, 2009 | RCA WSP155 Main / Stereo Speaker
Transmitter light does not come on
Just switch the polarity on your plug from positive to negative...it will work!
Dec 31, 2008 | RCA WSP155 Main / Stereo Speaker
Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Jul 19, 2008 | Audio Players & Recorders
Reception problem
Hello, Suse! One of my closest friends had the IDENTICAL system, and had to replace TWO transmitters before getting one that finally worked long-term. (A total of three - the original, plus the two replacements.) Before making the same assumption, however, there are two simple things to check: 1) Inspect the connection between your receiver and the WSP transmitter to make sure everything is secure. 2) IF you're using the speakers with batteries, try an AC adapter instead. Batteries - even brand new ones - aren't ideal for every application. There is NO QUESTION that the WSP system - at least, the one my friend uses - performs better when connected to AC power than it does when using batteries. Good luck!
Jul 17, 2007 | RCA WSP155 Main / Stereo Speaker
Wsp150 transmitter failure
The following alternative may solve your problem:
Check to make sure the volume on the audio source is set to a normal volume. If the volume is too low, the transmitter will not turn on.
Apr 01, 2007 | RCA WSP150 Main / Stereo Speaker
RCA WSP155 Main / Stereo Speaker Logo
575 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
