Question about Zanussi Washing Machines
What does the code e20 mean - Zanussi Washing Machines
My machine comes up E20 towards end of program what does this mean
Really need the make and model of your machine as different manufacturers use the same code to mean diferent things. Hotpoint/Indesit/Creda generally use E20 to mean there is a problem with temperature sensing (Which generally indicated that the water heater element has failed. Zanissu/AEG Lavmat use E20 to indicate that the empty pump is blocked (Usually behind a kick plate at the bottom of the machine or a flip open door, you will find a cover that looks a little like a fuel cap). AEG also use E20 to indicate a door lock fault on some models. Personally, the fact that it is near the end of the cycle would indicate to me you have a blocked empty pump
Sep 26, 2015 | Washing Machines
E20 Error
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
Gltf2940es3
good day,
no idea for the E20 error coz all brand have diff error code?
call the service center what the exactly the E20 error?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Washing Machines
I have an e20 error code on my 1990 cadillac sedan deville. What does that mean?
E20 means open fuel pump circuit could be failed fuel pump relay
Aug 18, 2010 | 1990 Cadillac Deville
I have a 97 Buick Regal and I get a E20 error message:cd player
If the CD is over 60 minutes it will not play on domestic cars
May 29, 2009 | 1997 Buick.5 Regal
What does E20 code means on a delco cd player?
Hi E20 mean's
The CD player cannot focus on the disc or there is an internal focus problem.
try a known good CD and if it still displays E20 then you will have take it to a radio repair shop
May 10, 2009 | 1997 Pontiac Sunfire
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
