Question about Cycling
The resistance of 2 coils is 25 ohms when connected in parellel and 6 ohms when connected in series. determine the resistance of the 2 coils? (i nedd the working also)
  • 843 Answers
Equation for series R1 + R2 = 6 equation for parallel 1/R1 + 1/R2 = 1/25 substitute first equation for R2 in second equation: 1/R1 + 1/(6 - R1) = 1/25 I will leave the algebra solution to you.
Posted on Oct 01, 2010
  • Al Kupchella
    Al Kupchella Oct 01, 2010
    Ah, but this was a trick question, as you might have discovered there is no solution. This is because two resistors in series cannot have less resistance than those same two resistors in parallel.
I have 2 duel 12' 2ohm sub's and a blackmore bac m-50 2000 watt 4ohm amp and was wondering how to wire. Thanks!
boz word of caution is to be heeded. with 2x2 ohms per speaker, you can only use one, with the voice coils ran in series to increase the resistance to 4 ohm . take a single driver, and use the series wiring on with both of the 2 ohm voice coils.
wire positive from the amp into positive of one voice coil, then the negative of that voice coil to the positive of the second voice coil 9bridging with 6 gauge or so, as was also mentioned by a previous user), then lead the negative of the second voice coil back to the amp's negative terminal.
Jun 01, 2015 | Car Audio & Video
Firing order coil pack 2000 ford explore 5-0
Firing Order is 1 3 7 2 6 5 4 8
JF: Integrated Ignition Coil On Plug Coil 1 Through 10 Failure
2000 PCED On Board Diagnostics II
SECTION 5: Pinpoint Tests
Procedure revision date: 01/31/2001
? JF: Introduction
JF1 DETERMINE WHICH COIL IS NOT FIRING
    Note: Electronic ignition engine timing is entirely controlled by the PCM. Electronic ignition timing is NOT adjustable. Do not attempt to check base timing. You will receive false readings.
  • Determine which coil is not firing using information from Pinpoint Test JB or DTC and the table at the beginning of this pinpoint test.
  • Record cylinder, coil and PCM pin number from the table.
Have the cylinder number, coil driver and PCM pin number been recorded?
Yes
No
GO to JF2.
To obtain required information, GO to JF1 and REPEAT.
JF2 DTC P0351, P0356, P0357: CRANKSHAFT POSITION SENSOR FAILURE
Are any of the above listed DTCs present?
Yes
No
GO to JF3.
GO to JF4.
JF3 CHECK RESISTANCE OF CRANKSHAFT POSITION SENSOR
  • Measure resistance of crankshaft position sensor.
Is resistance between 290 and 390 ohms (for LS8 between 900 and 1300 ohms)?
Yes
No
GO to JF4.
REPLACE crankshaft position sensor. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF4 CHECK FUNCTIONALITY OF SUSPECT COIL DRIVER (CD) CIRCUIT
  • Disconnect suspect coil (determined from the table).
  • Connect incandescent test lamp between IGN START/RUN and suspect CD circuit (determined from the table) at the coil on plug harness connector.
  • Disable fuel pump by disconnecting inertia fuel shutoff switch.
  • Observe incandescent test lamp while cranking engine.
Is the test lamp blinking consistently?
Yes
No
KEY OFF. GO to JF5.
KEY OFF. GO to JF6.
JF5 CHECK FUNCTIONALITY OF SUSPECT COIL
  • Remove suspect coil (determined from the table) from spark plug.
  • Connect an air gap spark tester 303-D037 (D81P-6666-A) or equivalent to a suspect coil.
  • Reconnect suspect coil harness connector.
  • Observe spark tester while cranking engine.
Is the spark present?
Yes
No
KEY OFF. INSPECT spark plug, REPLACE if necessary. GO to Z1.
KEY OFF. REPLACE coil. INSPECT spark plug, REPLACE if necessary. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF6 CHECK IGN START/RUN VOLTAGE TO SUSPECT COIL
  • Key on, engine off.
  • Measure voltage between IGN START/RUN circuit at the coil on plug harness connector and ground.
Is voltage greater than 10.0 volts?
Yes
No
KEY OFF. GO toJF7.
KEY OFF. LS6 and LS8: GO to B5.
All others: IGN START/RUN circuit fault. CHECK condition of related fuses/fuse links. If OK, REPAIR open circuit. If fuse/fuse link is damaged, CHECK IGN START/RUN circuit for short to ground. REPAIR as necessary. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF7 CHECK SUSPECT CD CIRCUIT FOR OPEN IN HARNESS
  • Disconnect PCM.
  • Measure resistance of suspect CD circuit between PCM harness connector pin (determined from the table) and coil on plug harness connector.
Is resistance less than 5 ohms?
Yes
No
GO to JF8.
REPAIR open circuit. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF8 CHECK SUSPECT CD CIRCUIT FOR SHORT TO VPWR IN HARNESS
  • Measure voltage between suspect CD circuit at the PCM harness connector (determined from the table) and ground.
Is voltage less than 1.0 volt?
Yes
No
KEY OFF. GO to JF9.
KEY OFF. REPAIR short circuit. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF9 CHECK SUSPECT CD CIRCUIT FOR SHORT TO GROUND IN HARNESS
  • Disconnect scan tool.
  • Measure resistance between suspect CD circuit at the PCM harness connector (determined from the table) and ground.
Is resistance greater than 10,000 ohms?
Yes
No
GO toJF10.
REPAIR short circuit. If symptom or DTC is still present, GO to JF11 to check for damaged coil, otherwise COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF10 PERFORM INTERMITTENT TEST ON SUSPECT CD CIRCUIT HARNESS
  • Connect digital multimeter between suspect CD circuit at the PCM harness connector (determined from the table) and CD circuit at coil on plug harness connector.
  • Wiggle and bend CD harness from PCM harness connector to coil on plug harness connector.
Did resistance fluctuate during wiggle test?
Yes
No
REPAIR intermittent fault in harness. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
REPLACE PCM. (REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM)). If symptom or DTC is still present, GO to JF11 to check for damaged coil, otherwise COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF11 CHECK SUSPECT COIL FOR DAMAGE
Yes
No
Feb 14, 2015 | 2000 Ford Explorer
How do you check resistance through the heater coil?
To that defrost heater
set the meter to lowest ohms setting
follow wires that connect to heater up to the top of freezer coil
unplug the 2 wires for the defrost heater/or if on huge plug with all wires in unplug that plug
place meter leads on the the 2 wires for the heater
the meter display should be some where between 5-25 ohms of resistiance
if heater is good it will have contunuty with 5-25 ohms,if bad the meter display either wont change or display OL
if heater check good check defrost thermostat pictured below for ZERO ohms resistiance when cold and frost is built up on freezer coil MUST BE COLD to check. It too should have continuty with ZERO ohms resistiance
If both heater nand defrost thermostat check good the defrost control board will be the problem.
This is what the deforst thermostat looks,yours may be slightly different yet very similar and ina similar place(clipped to top of freezer coil usually on right side)oldtech2332_40.jpg
Aug 21, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I just bought two rockford fosgate t1 twelves duel voice coil 4ohm I'm running a old school alpine v12 1507 mrv 2channel. I want to bridge the amp to get the most out of these subs would it be better...
This amp should run comfortable at 2 ohms/channel. However, your dual voice coil subs are rated at 4 ohms. This means when you connect the 2 voice coils together in parellel (positive to positive and negative to negative both coils wired to one output) the amp will see 2 ohms. So if you connect both subs to one output then your amp will see 1 ohm (not good) If you run the voice coils in parellel but the subs in series then the 2 resistances (ohms) will be added together. So that way the amp will se 4 ohms. This is fine but the amp would push more power into 2 ohms. You can run one sub on each channel if you can split the head unit output to 2 outputs, problem is then you will be halving the amount of power to each channel. Personally I would probably be more inclined to run 1 sub on this amp and run another amp from the pre-outs on the first amp for the 2nd sub. Try to find another amp the same to run the second sub. Mind you, 2 of these amps will need some big power cable to run them but should shake your teeth out!
Hope this helps
May 08, 2011 | Alpine Car Audio & Video
2004 Saturn, "L" series, 3 liter V-6. po300,
300 is random misfire and 306 is cylinder #6, I would check the coil pack on #6. If it has separate coils per cyliner, swap the coil, see if the misfire goes to that cylinder. If it does replace the coil.
If it has three coil packs you can still swap the coils. If that doesn't fix your problem, then you will have to check the injector with an ohm meter. resistance between the prongs should be between 11 to 15 ohms. check another injector and they should be relatively close. Let me know
Good luck
Randy
Nov 09, 2010 | 2004 Saturn L-Series
Nedd to test coil on an 89 chevy 2500, dont know parameters
PICK-UP COIL (HEI)
1. Isolate 2 pick-up coil lead wires. Remove pick-up coil connector from module. Connect ohmmeter to either terminal and ground. See Fig. 4 . Connect pump and apply vacuum to test vacuum advance unit. Replace vacuum advance unit if inoperative. Connect ohmmeter to pickup coil terminals. Operate vacuum pump and observe ohmmeter throughout the vacuum range.
2. Attach ohmmeter to one pick-up coil terminal and distributor housing. Set ohmmeter to middle scale. Operate vacuum advance throughout vacuum range. Reading should be infinite at all times. If not, replace pick-up coil. See Meter "A" in Fig. 4 .
3. Connect ohmmeter leads to pick-up coil connector terminals. Operate vacuum pump to ensure proper operation throughout vacuum range. Flex terminal wires by hand to check for possible intermittent defects in wiring or connectors. Pick-up resistance should be 500-1500 ohms. If resistance is incorrect, replace pick-up coil. See Meter "B" in Fig. 4 .
NOTE: Activation of the vacuum advance may align trigger wheel tooth and pick-up coil pole piece causing ohmmeter pointer to deflect. This
deflection should not be diagnosed as a faulty pick-up coil.
Jan 20, 2010 | 1990 Chevrolet K2500
I need to know how to wire my 2 12' kenwood w3514 dvc sub woofers parellel
For parallel connections, simply wire posotive to positive and negative to negative. But beware! this lowers the impedence (ohms) by half. In other words if you have 4 ohm woofers, in parallel they would be two ohms. Make sure your amp can handle that. Otherwise connect them in series.
Apr 04, 2009 | Kenwood KFC-W3514DVC Car Subwoofer
How to hook up 2 10 inch speakers
For best results the output resistance of the amplifier must equal the combined resistance of the speakers. So if the amps says 8 ohms and you have two 4 ohm speakers you put them is series or if the amps says 4ohms and you have two 8 ohm speakers put them in series. If it says 4ohm and you have two 4 ohm speakers best to use only one. It Depends on the output resistance of the amps. It is usually written at the terminals where the speakers are connected.
Sep 08, 2008 | Boss IQ 3KD.1 Car Audio Amplifier
Wiring woofers
Well, you have the 4 ohm dvc kickers, and your amp being stable to 2 ohms doesn't go together very well. If you wire the voice coils in series, and hook the speakers to the amp in parallel, you get 4 ohms, which doesn't use all the power your amp is capable of. If you run the voice coils and the speakers in parallel, you'll drop the resistance to 1 ohm, and probably fry the amp, or at least deal with overheating issues. Better be safe than sorry. You need to run each speaker in series, which means running a positive and negative to each speaker, and a jumper from those terminals to the opposite colored terminals on the second voice coil. Diagram can be seen here: http://www.kicker.com/06/tech-support/manuals/manuals/02SoloBaricL7manual.pdf That puts two 4ohm voice coils in series, and raises the resistance of each speaker to 8 ohms. Then, you have to run both speakers in parallel to the amp. When you run two 8 ohm circuits in parallel, the total resistance of the circuit is 4 ohms. That means seperate positive and negative wires to each speaker. If it is a mono amp, connect both negatives to the negative output, both positives to the positive output. If it is a multi-channel bridgeable amp, You'll probably connect the negatives to one side output (right for example) then connect the positives to the opposite side output (left for example). If you need to bridge your amp, make sure it is bridgeable, and also that you have the speakers bridged to the proper amp outputs. If not sure, reply back here with the amp model number, and maybe I can help you further.Thanks, and I hope this solves your problem.
Nov 29, 2007 | Kicker 02S10L74 Car Subwoofer
Cycling Logo
100 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
