Question about Refrigerators
My unit a thermo king sl400e shut down and displayed alarm code 15 CHECK GLOW PLUGS OR INTAKE HEATER how do i fix this
cadesertmax
  • 274 Answers
SOURCE: Have Endless Summer patio heater. I got the burner
It could be the thermocouple, but you have to take the head apart to replace it. If you got the main burner to fire, then the thermocouple is probably ok. Try changing the regulator, easy to do and not to expensive. If that doesn't work, try taking the head apart and cleaning the pilot and main burner orifices, do both while you are in there. If you are not comfortable doing this, hire someone.
Posted on Jan 11, 2010
prakas_3p
  • 107 Answers
SOURCE: master code setting couldn't do it (alarm system ADEMCO VISTA-10)
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Posted on May 08, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: how do I reset the
Hello
Found a usefull link to thrmo king.Shows how to reset alarm.
http://www.thermoking.co.nz/PDFFiles/OperatingTG-VI%20Microprocessor%202005%20CD.pdf
Posted on Apr 10, 2011
  • 1252 Answers
SOURCE: have 7.3 diesel motor hard
Fuel quality and moisture in certain diesel fuels may cause some vehicles to exhibit a no start, gradual loss of power, or a rough idle condition due to fuel gelling during extreme cold weather operation.
Posted on Jun 19, 2011
  • 560 Answers
SOURCE: What do I do to fix code 20 on my thermo king sb111 whisper edition refrigerated trailer
driver just call your local thermo king wherever you are and they will help you asap tell what the code 20 is and how to fix it.
Mike
Posted on Feb 12, 2016
Mike
Feb 12, 2016 | Refrigerators
When my unit won't start and has a code 20
If that refrig trailer is loaded then you need to call thermo king for help ASAP. You don't want to loose the load.
Retired VP OPerations Trucking. Mike
Feb 12, 2016 | Cars & Trucks
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
The pilot ignites without a problem. It will stay lit. However, when you try to kick the flame on, it will burn for about 15-20 seconds then the whole unit kicks off.
Sounds like a over heating or a thermostat problem. Is there a safety (high limit) thermo in that unit? Replace it or jumper it temporarily to see waht happens.
Before you do that, make sure the air flow is in no way restricted causing over heating in the unit and for the thermo to open, shutting down the unit.
Oct 26, 2013 | Kozy World World Marketing GWD208 20,000...
I have a thermo king tripac and I'm having issues
Hi there, do you have the diesel fired heater unit? have you checked the inline filter and also the injector nozzle inside the burner, we had one come in that was slightly blocked and wouldn't fire up! i have a brand new complete heater unit if you need any parts.
Dec 03, 2012 | Cars & Trucks
I have a JD X595 Diesel. This is what happens, say if I start it, then shut it down it will not start again right away. The first time it starts the glow plug light comes on. Shut it down and try to start...
Before you do anything grab a test light, remove the wire from your glow plug, put one end of test light on positive on your battery and the other end on the glow plug, if the light comes on than your glow plug is ok, if not replace, otherwise you need to locate the relay/sensor that tells the glow plug when to go off/on which is more than likely the problem, you may be able to locate it by tracking the wire from the glow plug or your local John Deere service provider may be able to tell you exactly where it is over the phone.
Jun 09, 2011 | John Deere 26HP Hydrostatic 54" Riding...
Viper 5901 Starting issues
i need to adjust the time that it waits to start for my glow plugs in my 2001 ford excursion diesel 7.3. I need it to wait another 10 - 12 sec.
Sep 12, 2009 | Viper Security and Remote Start System...
Qt9093 heater shuts off after approx 1 min.N
had one one time! lasted for about two years...yes there is a thermo switch, mine was same! heated for about one minute..then off....would come back on after cool down.to replace thermo was like as much as whole unit....crazy I just lived with it! I know this does not fix yours and i'm sorry ...your thermo could be cheaper! check it out
Mar 21, 2009 | Broan-NuTone NuTone - Vent Fan - QT9093WH
Refrigerators Logo
238 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
