Question about Dell NPS730AB 730Watt Power Supply
Power supply nps-730ab getting red light in middle flashing and bottom green light on constantly lite. however not functioning properly. have two power supply so this is a redundant system, but still need to repair power supply.
  • Dell Master
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Posted on Oct 01, 2010
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
When I power on the tv, the light goes to green and then a few seconds later goes to a red flashing light
When a set is powered up, there are internal checks that are performed. The initial green light indicates that power has been applied. The flashing red light indicates that a problem was found that is preventing the set from functioning properly and it has shutdown to prevent further damaeg. If you can supply the model number, I may be able to provide additional details. Also, check to see if the flashing red light has a pattern. Quite often the pattern will indicate what problem was detected.
Thanks,
Dan
Aug 07, 2009 | Panasonic Televison & Video
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Dell NPS-210AB power supply starts up then shuts off
hello bob, try putting a phanton loa on the other bars of the power supply, it seems tha the power supply is not starting, some switchin power supply require an apropiate load to start.
Jun 29, 2009 | Dell Power Supply 330 Watts nps-330cb...
Dell power supply NPS-210AB will not turn on
Try switching it with one that you are certain works just to make sure it didnt blow or that your computer is working alright. or, using a multimeter, try and check for any current flowing to any of the connectors...
Jun 21, 2009 | Dell 210W Optiplex GX270 NPS-210 AB Power...
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
My DPS-730AB A power supply made by delta for my server quit
I need the diagram of the output pins of the source (DELTA ELETRONICS) Model: DPS-730 ABA
Mar 21, 2009 | Delta Electronics DELTAELEC PLUG IN POWER...
Won't boot up
Can you give a little more information? Did the Laptop Fall? What Color is the light that blinks? Amber or Green?
So far it Sounds to me that you Power Supply is Dead or Bad and or not charging the Battery....
First Check the battery status light?
Is the Power Supply Light (Lite). you might want to try removing the battery and using only the Power supply!
Jan 15, 2008 | Dell Inspiron 4150 Notebook
Dell NPS730AB 730Watt Power Supply Logo
719 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
