Question about Acer Aspire 5315-2713 Notebook
Hi i have an acer 5315 laptop and last night my friend accidently spilt a small glass of vodka and creamsoda all over it, we immediatly soaked up all that we could, and it continued to work for about 20 minutes then shut off and now wont turn on. weve tried to dry out any exess liquid and it seems to be dry now, however the green power light is on with the power pack and it will not switch on at all, could you advise me please? thanks Gill
    Habit-Forming:
  • 36 Answers
Put the laptop in sunlight and try to dry your laptop using hot air dryer so that internal moister can get removed and repeat it till atleast 2-3 days and till then do not turn on it and do not put it in charge.
Posted on Jun 29, 2017
    Top Expert:
  • Acer Master
  • 79,865 Answers
Open up the laptop and pour dry rice on it for a few days, if that doesn't restore function your friend owes you a new laptop.
fwadley
  • 482 Answers
SOURCE: Spilt Liquid on the key bord how Can i take out the Key bord?????
If you get water or anything on them they are gone. your best bet is to take it to a comptuer store and let them see if they can help. i dont know if you every have taken a key board a part, but i can tell you that its harder then you would think to put it back togther.
Posted on Apr 16, 2008
benwabnick
  • 2404 Answers
SOURCE: Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Posted on Jun 04, 2009
  • 37 Answers
SOURCE: Acer 5570 - Power switch is not working
Try removing the power supply (from the wall) and the battery pack. Hold down the power button for 30 seconds. Plug the mains power (from the wall) back in and then press the power button. It should work. Then you can replace your battery pack. Don't know why it works but it has worked for me in the past. Good luck!
Posted on Aug 01, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: My acer 5315 touch pad mouse has does not work, it
Hi there, Press FN+F7 key and use your mouse pad. Right now its on disable mode. Thanks.
Posted on Feb 08, 2010
Testimonial: "thanks, yes it was on disable."
  • 12 Answers
SOURCE: I accidently spilt some liquid
This is a risky solution but worked for me.With the batteries removed turn the key board face down. get a spray bottle filled with warm water. Now you are practically going to wash the keyboard.Spray the affected area with the warm water spray, allowing the water to drip down as you spray.Satisfied with the cleaning let the key board to dry but still in the face down position.Allow ample time and warmth to dry. Fix your batteries and test.
Posted on Aug 03, 2011
How much would it cost to buy a new Acer Aspire 5315. I borrowed my friend's loptop and it was just stolen. I appreciate hearing from you! Thanks!
This model is no longer available. The last price I have seen is $488.00. For that price you can purchase an updated and faster unit. I purchased a comparable HP laptop for $488 @ my local Wal-mart.
Nov 10, 2010 | Acer Aspire 5315-2940 Notebook
Does my Acer Aspire 5315-2290 have a system recovery? I wanted to restore it to its orignal start up progarams only.
If you have an Acer utility menu in the program list and one of the options is to restore your computer, then you do have that option.
If you have a CD or DVD that came with the computer, you can use that to restore it.
Otherwise, the answer is n"no"
You can then just go in and delete all the unwanted programs until you end up with just the ones that came with the machine.
Jul 15, 2009 | Acer Aspire 5315 Notebook
Acer 5315 Battery cHarging Problems
All rechargeable batteries have a limited life, and as they age their charge capacity reduces over time and you get shorter and shorter time between charges.
Recharage batteries have a finite number of charge and discharge cycles and batteries over 2 years old are considered nearly worn out. Worn out batteries won't charge up at all.
Jun 30, 2009 | Acer Aspire 5315 Notebook
Used restore to another date, still locked in this process,
Hi Linda,
It sounds like the restore failed , try powering the PC off by holding the power button down for at least 5 seconds. Then reboot.
Hopefully that will let you back into Windows, if you continue to have problems , try the following.
Make sure you have your data backed up.
Turn on the computer and when you see the white Acer screen fully loaded, press and hold Alt+F10 to do the reboot.
This should start the recovery process from the recovery partition on your PC.
If that fails , you will need the recovery disks, unfortunately , acer does not provide them and expects you to make them by going to Acer eRecovery Management's "System backup to optical disc" feature to burn a backup image to CD or DVD.
Since you cant get into Windows , if you havent already made them , you need to order them from Acer.
Yes they make you pay for them.
You can order them here.
https://secure3.tx.acer.com/RCD/Main.aspx
Good luck.
Mar 03, 2009 | Acer Aspire 5315 Notebook
How do you insret a sdcard into a acer aspire 5315
Left side toward front immediatly after PC card:
Jan 04, 2009 | Acer Aspire 5315 Notebook
ACER 5315-2326
Disconnect it and connect again.
Oct 27, 2008 | Acer Aspire 5315 Notebook
Unable to recognize my wireless networks
unplug the battery from the pc( no power ) for a while ,something is locking up in the IC chips , if this is an eternal device
Oct 18, 2008 | Acer Aspire 5315 Notebook
Touchpad won't work
Hi, i have an acer aspire 5315 on this model you have to press FN+F7 to toggle the touchpad on & off. hope this helps someone.
May 28, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315-2713 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
