Question about 2wire 2700HG-B Router (2700HGB)
I am having trouble connecting my 2700 2wire gateway router
    Sergeant:
  • 231 Answers
Here is a link to tell you how to setup good luck
http://answers.yahoo.com/question/index?qid=20070527092052AAxwS2V
Posted on Oct 01, 2010
Wifi connection problems on windows 7 64 bit and ios devices
You will need to be more specific if you want more specific advice.
Two totally different systems are having trouble connecting to your router/gateway device? Orient your antenna vertically and see if you can connect from a few feet away. If not restart your router and try again. Be sure you are using the appropriate protocols (WEP/WPA etc.) and credentials (passphrase/word, key, PIN) to link devices together.
Jan 08, 2013 | Gateway DX4860-UR14P DT.GD4AA.004 Desktop...
My Acer Aspire One D255-2256 netbook is having trouble connecting to the internet.
Start-Programs-Accessories-Command Prompt. Command prompt will open. Looks like a black screen. Type ipconfig then hit the enter key.
5th line down, you'll see something like this and so on.
IPv4 Address. . . . . . . . . .192.168.0.???
Subnet Mask. . . . . . . . . .255.255.255.0
Default Gateway . . . . . . . .192.168.0.1
These ip addresses may be different depending on what router or modem you're using. But if you're connected to the modem/router, you should get an ip address(IPv4 Address) and a default gateway that are the same except for the last set of numbers.See question marks above. If it's not the same then you are not connected to the router/modem. Check your wireless connection to see if it's on. Make sure you are connecting to your network. Make sure wireless signal is being transmitted from router.
See if you can hit the router if you have connectivity. Open your IE or Firefox and type only the IP address, meaning remove the http://www. Not needed. The IP address is the Default Gateway thst was listed in the Command Prompt. If you can hit the router/modem, then make sure that there is connectivity to the host. If you're DSL, you'll be using PPOE which is Username and Passwrd. Make sure you are connected by clicking connect under connection summary. If cable modem, make sure that the lights are on showing connectivity. Here's a starting point. I now need more info. If this doesn't help, tell me what you did find out and we'll go from there.
Jan 10, 2011 | Computers & Internet
Netopia Gateway has internet connection,can ping,but no web pages
Connect directly to your ISP by what ever method. Get Network Magic from Cisco. Download the free evaluation copy and run it. Reintroduce your router and let Network Magic help you solve the trouble. It may be that your firewall is too tight.
I hope this helps you
a
a
Sep 21, 2009 | Netopia 3347W-KIT ADSL Wireless Gateway,...
I am having trouble finding the WAP key for my computer. I just bought a laptop and it can detect the LAN connection but needs the WAP key. I am looking on our desktop but having trouble finding it. How do...
I guess you meant the Security Key for the wireless. You need to manually set the encryption type and key in order to connect.
When connected to the Wireless router with a cable, open up command prompt (Start->Run...->cmd [OK]), type ipconfig and note the IP address of the Gateway.
Copy paste this Gateway IP Address into IE and [Go]. you'll be prompted to logon. Try defaults if you don't know (Admin, Admin or Admin, password).
Then depends on the model of the Wireless router you need to locate settings for the wireless connection. Recommands WPA-PSK 2, AES.
Apr 16, 2009 | ASUS Eee PC 900 PC Notebook
I'm trying to connect an xbox 360 to the ethernet using a cable modem. We're having trouble. Is this possible? We connected the modem to the cable hook-up and connected the ethernet cable from the modem to...
Make sure your modem or router is compatible with XBOX. I think Microsoft has a lost of working modems and routers. If this is all clear, connect the eth.cable to the modem/router. Power up the modem FIRST then the xbox. All this without any cd/dvd in the tray.
Usually as simple as that...
Jan 12, 2009 | Arris SBG1000 Wireless Cable Modem Gateway...
Trouble connecting new laptop to the internet
when you put the mouse over the network icon in your taskbar, it will say access: Local & Internet or local only.
if Local & internet you have a connection to the internet, if local only then open internet explorer, tools, internet options, connections and check that there is no default connection, it should be never dial a conection thats ticked or greyed out.
Aug 31, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
D-link dwa-130 wirless
it happens to me also, always cutting off the signal, i just bought new one other brand and it works fine
Jan 27, 2008 | Computers & Internet
Router Troubles
1. Try turning off your computer,then your router and your modem
2. Then turn on first your modem, your router and your computer
3. If no internet connection still, try reseting the router for 10seconds.
4. Make sure that the local area connection of your computer is set to obtain
5. If still no internet. Access configuration page of your router by typing the gateway of router router in your address bar
> you can check your gateway by typing ipconfig on your command prompt. It is your DG there. (Usually 192.168.1.1 or 192.168.0.1)
6. Make sure that configuration type or connection type is set to DHCP. Then clone your computers mac address.
7. Check your status page.You should have ip address, default gateway and DNS there.
Jan 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Cannot connect
Assuming you are on Windows XP click on site below for router setup. http://support.gateway.com/s/NETWORK/7004809/7004809slWindowsXP.shtml The Nintendo 'Cloud' is just a network name so that when you are in a building that has supported wifi, you search for the network and use My Cloud as the password for connection on Nintendo DS. The settings you may require for the Nintendo Wii will probably be your routers IP address, Gateway and DNS address (just use same numbers). Apologies in advance if i'm incorrect as i have only setup a nintendo DS on my own wireless network and as Wii are not yet available i have no knowledge of it yet.
Nov 30, 2006 | Gateway Wireless-G WGR-200 Router...
2wire 2700HG-B Router (2700HGB) Logo
52 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
