Question about Maytag Refrigerators
Need help with icemaker - Maytag Refrigerators
    Brigadier General:
  • 3,513 Answers
Please check the bellow link related to your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting#Theicemakerhasaproblem
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 01, 2010
Ice forms under icemaker and stops fan. There is a leak somewhere related to the icemaker and sometime ice builds up below the icemaker bucket. I also have noticed big chunks of ice at left rear of bucket.
You need a new ice maker. The seal in the shaft is bad. The icemaker is a throw away no repair parts. Sears parts has them for 125-130 dollars. These icemaker only last about 2-5yrs. I hope this helps.
Aug 27, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker not getting water
look inside the ice maker and see if the shut off leaver is stuck.
maybe a chunk of ice stuck in it. thanks for rating ;-)
Aug 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
My Kenmore Elite Model #795.71053.010 3 door bottom freezer makes ice, but will not harvest. I can get water out of the door. Icemaker part # AEQ72910401. I have unplugged frigerator for 30 minutes. I...
I am sorry there is no replacement parts for this icemaker. You will need to replace Icemaker. Call sears if less that 1yr old. I have seen this icemaker go after only 14 months. I hope this helps
Aug 25, 2011 | Refrigerators
Have an LG icemaker that is not working and needs removing. Tech showed me how to do that if it happens to not work again. I have the screws removed but can't get it unplugged (icemaker only) is there a...
there are catches on the plug that secure it from accidentally unplugging,some you squeeze and some have tabs in the side of the plug that need pressing to release the plug
Mar 22, 2011 | LG LFC20740S
I have a u-line icemaker in my boat and it will make a tray of ice but will not dispense it without manual intervention. Is there a par that needs to be replaced? Thanks for your help
Have you used the ULine cleaner recently needs to be run through the icemaker every so often (good water every 6 months bad water as needed)
Nov 14, 2010 | U-Line Icemaker
I have a Jenn-Air refer model #JRTD226 with a built in icemaker. The icemaker makes ice fine except a small drip of water continually drops from an area just behind the front module and forms a large...
sounds like you have a crack in the mold of the icemaker. they do not make replacement parts for these icemakers. you will have to replace the whole icemaker. hope this helps.
Oct 21, 2009 | Refrigerators
My whirlpool ice maker makes ice but it builds an ice dam and ice cicles on the back of the unit.
there might be a crack in the mold of the icemaker. you can unplug the fridge and take out the icemaker. there should be three 1/4" screws holding it in place. visually inspect the icemaker mold the see if its cracked or flaking. if it is, the icemaker needs replacing. hope this helps.
Oct 21, 2009 | Whirlpool Refrigerators
Replacing icemaker in GE GSH25JSTE side by side refrigerator.
generally its very easy. for your model it looks like the icemaker goes across the rear of the freezer section. if you will look on the left hand wall on the icemaker you will see a philips head screw remove this screw and pull the icemaker towards you and it will come out then unplug the wiring harness (this is probably the hardest part) there are 2 clips that keep the harness connected securley and you sometimes have to use a small blade screw driver to release them. onec icemaker is removed you have to remove the fill cup and the end stop off of the icemaker and reinstall on the new icemaker. one done just reinstall and turn it on. youre done!! BTW the new icemaker mostlikely will not have the green light the old one did so dont think youve got the wrong icemaker.. let me know if you need any further help Thanks Peyton
Mar 16, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Icemaker stopped working
you likely need a new icemaker (part # 2198597) i would visit the following website to help determine this fact.  http://fixitnow.com/sbrvrs/icemakers.htm
Feb 05, 2009 | Whirlpool GD5SHAX Side by Side...
My maytag will not stop making ice I think I need to replace the switch in the icemaker
the problem is the icemaker module ,,,, thats the head of the icemaker and it is held in by 3 screws but 1st make sure the arm on the icemaker is still connected cause if it isnt it wont shut off.
if i can help you with a module just let me know / larry
Dec 01, 2008 | Maytag Refrigerators
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
