Question about Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover
I have a red blinking light with code 90 displayed. We were getting hot water this morning and all of a sudden it is just cold now. Wondering how we go about getting it fixed. Thanks.
    Scholar:
  • 73 Answers
The 90 code indicates poor combustion. It can typically be resolved by cleaning the unit with compressed air, performing a descale, or corrected an improperly sized gas line.
Posted on Oct 19, 2010
What does "EFO" stand for? It keeps blinking on my washer
EF0
displays due to washer over-sudsing or due to washer not filling with
Hot
water.
Causes for washer over-sudsing
Not using High Efficiency (HE) detergent.
Too much detergent was added.
Using too much 2X or 3X HE detergent
Solutions for over-sudsing
Always use HE detergent in an HE washer. It is formulated to be a low-sudsing detergent and made especially for HE washers.
Be sure to use the correct amount of detergent. HE washers require only a small amount of detergent.
Note
: This amount may need to be adjusted for water hardness, load size, and soil level.
If using a 2X or 3X concentrated HE detergent, much less detergent is needed. If suds are seen, reduce the amount used.
If using a water softener, less detergent.
Solutions for Hot water not entering the machine are
Make sure both Hot to Cold water hoses are connected properly at the faucets and at the washer.
Fill hoses are usually color coded, blue for cold and red for hot.
Verify that the hot water inlet hose is connected to the hot water faucet.
Verify that the cold water inlet hose is connected to the cold water faucet.
Verify that the hot water inlet hose is connected to the back of the washer into the hot water inlet port.
The inlet port is usually labeled with (H) or (HOT).
Verify that the cold water inlet hose is connected to the back of the washer into the cold water inlet port. This inlet port is usually labeled with (C) or(COLD).
hope this was some help,all the best.
Dec 16, 2016 | Washing Machines
Why won't the red blinking light go off on my primo water cooler?
If the cooler or the water are not getting cold I would check for a high pressure reset if they are getting cold the compressor would working fine, you could also try flushing it, is there a pattern to the flash that may indicate a code................good luck! mine has developed a leak and does not heat less that 6 mo old pretty disapointing.
Jul 20, 2014 | Unknown Primo Deluxe Stainless Steel...
I bought my g1 about 1 month ago and now its just slow, draining battery fast, and getting really hot. anyways one night i left my G1 on my desk next to a cold ice bottle of water and the next morning my...
the mobile requires a service with solution dipped in liquid, as few resisitors and capcitors might have been still corrosive, i think you please leave the phone without battery in room temp of 26-30 deg ... for a day or two...
Jun 16, 2011 | HTC G1
Cold water only does not work
check the hot solenoid valve, and replace. if the water is cold you should get a blinking hot water red light
Sep 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dream Maker Hot tub - Display is blank - no #'s - flashes 4 times
Hard to say without being there. Two things to check though. First be sure the new board is the correct one. Many times parts will change and replacements will have special instructions for retrofitting.
The other thing to check is be very sure the plug on the new board lines up with the receptor. On a multi pin plug if the pins don't line up you can get just the problem you describe. I hope this helps, sorry it can't be more.
Feb 28, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
DISPLAYS LF (LONG FILL) ERROR CODE WHEN HOT WATER is involved.
This is a faulty water valve Assembly. you can order this online and it is shipped with easy to read instructions on how to attach as well. it quite the novice job.
May 21, 2009 | Whirlpool Washing Machines
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Blinking red light,
It seams alot of people have this same problem All must get ahold of manufacturer and report this it must be there pump's thank you for useing fixya
Jan 14, 2009 | Noritz 6.3 Gallon Residential Tankless...
Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover Logo
242 people viewed this question
Top Noritz Plumbing Experts
Kyocera HP Expert
paulcarew
Muzammil Razzaq
Muzammil Razzaq
Are you a Noritz Plumbing Expert? Answer questions, earn points and help others
