Question about RCA TruFlat 27F520T 27" TV
Television When I turn my tv on, it immediately turns itself off
  • 16 more comments
  • currier May 27, 2008
    unpluged for ten minutes pluged beck in did same thing
  • pbrown221 Jun 27, 2008
    My TV is an RCA 20F420T and will turn on and off by itself. Started right after the warranty ran out and slowly at first now is continuously off and on. Is there a simple solution/fix to try? We bought the RCA because it seemed to have a better picture, etc. not knowing it was junk - we've had a couple of Sanyo brands that have lasted for years with no problems (and more use!) I will NEVER buy another RCA.
  • Donna709 Oct 22, 2008
    I have the same problem. This TV isn't that old ... it may not even be one year. The TV keeps turning off when you are watching it ... every few minutes. It even turns on sometimes by itself.
  • Anonymous Nov 10, 2008
  • oorigin Nov 15, 2008
    I have installed a new flyback (power transformer) per the recommendation of this site and it didn't solve the problem. All the soldering was done properly and when I went to power it back up the green light turned on and the unit it just made a little clicking sound about three times and then just turned off. Puzzled! any other suggestions?
  • Anonymous Dec 05, 2008
    I have a a larger version of the same TV and it just today started turning itself on and off. If you turn it on, it turns off as well. It's three years old. This sucks.
    Tv is three years old. Turns itself on and off every 30 seconds or so. This blows.
  • Anonymous Dec 18, 2008
    My TV has recently started turning itself off (RCA TruFlat). It's nearly two years old. Keeping it turned off for an extended time seems to let it turn on, but only for a short while (~30-45 minutes).
    I can't really afford to buy a new TV right now, so a fix would be helpful.
  • kitti61k Dec 20, 2008
    We have the same problem as so many other people with the RCA Tru FLAT........turns itself off unannounced!!!!!!!!!!! We vacuumed the dust from the rear vent area seemed to help some,.....maybe a heat build up problem??? I thought I'd try taking it out side tomorrow and blowing it out with my compressor!!!
  • shyone98 Dec 21, 2008
    It takes a few seconds to turn on and is on for 1 and turns itself right back off.
  • mjod Jan 18, 2009
    I have an RCA TruFlat screen tv 27" model number 27f520t.It is about 3 years old. It's been a second tv so it has not been used that much. About a week ago the tv was turned on and it shut it off all by itself!!!!!! I turned it back on and it did the same. I took the back cover to look for dust ect. Everythink looked ok. Any ideas what the problem might be?
  • jkj917 Jan 22, 2009
    Wow...I had no idea that this on/off thing was relatively common. I just started experiencing this problem about three or four days ago. I initially blamed my 4 year old daughter for playing with the remote. I suspect that it could be getting ready to conk out. I'll try the blow dryer trick. Hopefully, that'll work. Thanx all.
  • Persephony Jan 29, 2009
    Model #20F420T here with same problem. Turns itself off after a few minutes. Someone mentioned a FTP......Will this solve the problem?
  • Anonymous Feb 09, 2009
    ditto as everyone else
  • damrca Feb 22, 2009
    I have the same problem, mine is about 3 years old still in great shape, never been dropped or hit or anything, turn on shuts off by it self.
  • sunterrie9 Feb 25, 2009
    my rca true flat does the same thing but it changes channels on its own..does the search channel on its own..turns off and on all on its own..i took the back off to check for dust..used a can of air to blow any dust out...held my breath..turned it on...ugh does the same thing...this tv is only about 3 years old. i bought it new at walmart...
  • rawdogs61 Mar 01, 2009
    i have the same problem, mine will turn off after running for about a half hour. I will never buy another RCA product. I've tried everything, they're pieces of c--p, if someone has a real solution to this problem please post it
  • donkeydung Mar 03, 2009
    I unfortunately have this tv and this problem, mine stays on for 10-20 minutes and then shuts off by itself, if I turn it on without waiting a while it immediately goes off. If I wait a long while I get another 10-20 minutes. I tried blowing condensed air through it, but this didn't fix anything. Problem started like four days ago out of the blue.
  • 3 Answers
I HAVE THIS RCA TRUFLAT 20F420T TV. IT WOULD STAY ON ABOUT A MINUTE THEN SHUT OFF. SOMETIMES SHORTER PERIOD OF TIME. THIS IS HOW I SOLVED MY PROBLEM.
FACING THE TV PUT A TWO INCH PIECE OF WOOD BOOK OR SOMETHING UNDER THE RIGHT FRONT SIDE OF TV ABOUT 5 INCHES FROM EDGE. NO PROBLEM CUTTING OFF NOW!]
WHEN I TAKE PIECE OF WOOD OUT AND LAY FLAT...IT WILL CUT OFF! SO I TILT MY HEAD TO ONE SIDE AND WATCH TV. NO KIDDING!
Posted on Dec 21, 2008
  • BCHESS Dec 21, 2008
    Just now placed a 1 inch board under the back right side of tv just kind of tilts tv not too bad.
I read on another web site that it might be dust inside your t.v. several people had this problem and used a blow dryer in the bottom left corner area......... for about 10 minutes on the hot setting, it worked for them maybe it will for you to.
Posted on Dec 10, 2008
  • 85 Answers
Maybe the power switch of your tv is loosen,if not you may coldsolder the components of board of your tv.
Posted on Jun 03, 2008
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
When I try to turn on the television it appears as though it will turn on by way of the green on light that populates, however, it immediately turns itself off again. This happens over and over. The...
it sounds like some of the capacitors have blown TV repair company will charge you a lot for this but its a cheep fix if you like to have a go. Go to youtubb and in the search type, how to replace capacitors
Sep 16, 2011 | Spectroniq PLTV-42HW68 42 in. LCD TV
Vizio light is on on the front of tv, but when you turn it on it says no signal and turns off. VX37L
Your TV may be in RGB mode. Immediately after turning your TV on, press the TV button on the 'input' section of the remote. Hopefully that works for you. Your TV is designed to turn itself of in RGB (monitor) mode if no signal is present.
Jan 02, 2010 | Vizio VX37L Television
No picture, no sound, turns on, but turns itself off immediately.
unplug 2 ribon cables they are white then plug them back in  should fix it
Jun 08, 2009 | RCA HD52W66 Projection Television
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WS 65513 turns itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 05, 2009 | Mitsubishi WT-42311 42" Rear Projection...
TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
Jun 22, 2008 | Televison & Video
RCA TruFlat  27F520T 27" TV Logo
464 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
