How to replace a combustion blower assembly on a nordyne and the part number is 903404
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: I need a replacement capasitor for Nordyne
The capacitor should have a MFD rating and a VAC rating stamped on it. That is all you need. Example 35+5 mfd. 370 volts. A 440 volt will work on all of them. The other 2 numbers must be the same.
Posted on Sep 10, 2009
  • 25 Answers
SOURCE: i have air handler nordyne the blower dont stop
check thermostat make sure fan is not set on on, if thermostat is right the fan relay may be stuck closed or thermostat wire can be touching
Posted on Oct 27, 2009
koolbreezes
  • 540 Answers
SOURCE: rebuilding mpi monitor 41 combustion blower assembly
Can you take the assebly to a goodman dealer to recomeends the fix? the law won,t permit a service tech. to dis-assemble these,
Posted on Dec 14, 2009
Nordine mgbb limit switch trips after blower comes on
I'm guessing that is the "mgbb" is short-hand
for a real number...
The SHORT-HAND answer is that TOP END limit switches
trip because things have gotten hotter than the design intent...
(or ... unlikely that switch is bad).
More likely... the switch that should have turned on the blower (sooner) is not turning on the blower soon enough to dissipate the heat from the exchanger (into the desired area)...
Some of the OLDER VERSION switches are adjustable...
I don't know about NORDYNE (see below, part type).
If you don't mind the risk of electrocution try to start the blower motor sooner... to see if you can avoid the high-temp situation I BELIEVE is causing your grief.
ELSE...
JUST replace the blower motor sensor...
If I'm wrong you have a SPARE sensor you always wanted anyway
$15 ( @ sears)
http://www.searspartsdirect.com/part-number/47-25349-03/0064/879.html?utm_source=bing&utm_medium=cse&utm_term=47-25349-03&sid=SPDxBING
Dec 24, 2016 | Heating & Cooling
Can i use a different blower relay
Yes. The coil voltage, number of poles must match. And if it fits a socket, the pin configuration also.
Apr 09, 2016 | Heating & Cooling
BLOWER NOT KICKININ ON A NORDYNE FURNACE
Do you have 120 volts applied to the motor? Try spinning the blower wheel by hand, if this getsbthe motor running the capacitor must be replaced. If there is power to the motor and does not start up, the motor will have to be replaced.
Dec 12, 2012 | AO Smith Nordyne Furnace Motor 1/8hp 1050...
Nordyne Split System Blower Won't Start
It's the fan motor. A relay problem would cause the motor not to run at all.
May 08, 2017 | Heating & Cooling
Richmond water heater goes into lockout condition, ignition failure and I have to turn the blower switch off then on to get the water heater to work. Its getting to be a everyday thing. Also would like to...
Start-point is to inspect and clean burner parts and combustion chamber, clean air intake, bleed air out of gas line, test gas pressure, test electronic gas control valve, check for venting issues.
As general rule, gas water heater manuals recommend professional service once a year that would cover most items listed above.
To see images, and for more reading and resources, look at your product manual and open following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Richmond/Rheem sells power vent blower assembly that cost about $300.
Your product manual shows part numbers.
http://www.monstermarketplace.com/heating-supplies/rheem-sp12562-blower-assembly-powervent-2
Replacement gas control valve costs $300
Aug 16, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a Payne, Gas heat/Electric cooling unit, model# PY1PJB____, and apparently I need to replace the combustion blower wheel. When I turned it on 1st time this season, it made a very loud noise, and...
Hi, you will need to replace the inducer/combustion motor as one assembly. If you know any contractors that have a c-20 or c-38 license, you could get it at any wholesales a/c & heating parts house. If not, you will need to buy one on the Internet, just enter the name, model, serial number of this unit, and you can order one. Or, take the assembly out and go to a appliance parts house, they may have it in stock. Very easy to replace.With the wheel broken that way, I am sure you have bearing problems that caused this problem, so I would get the complete assembly. You will be better off in the long run.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
PS, please rate me, and keep me posted on the out come. Thank you.
Nov 08, 2010 | Heating & Cooling
I have air handler nordyne the blower dont stop
Oct 27, 2009 | Heating & Cooling
Wiring NO, NC relay on Nordyne furnace
NORDYNE , GOODMAN, AND NUTONE ARE ALL BUILT BY SAME MFG SO IF YOU TRY ALL THESE MAYBE YOU CAN FIND THE HELP YOU NEED
Jan 12, 2009 | Electric Circuit Breaker Kit for Furnace
Rebuilding mpi monitor 41 combustion blower assembly
Dec 02, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
