Question about KitchenAid Washing Machines
Fixed the agitator on a Kitchenaid Washer model KAWE5778WHO, the agitator now works fine. However, when I turned on the machine I noticed it was leaking under the left side and when it went through the spin cycle it really spun out of whack. It sounded like it was imbalanced. I did loosen and retighten the bottom bolts on the motor assembly under the machine, but I retightened them. I also noticed a cotter pin, thick pin about 1.5 inches in length and a plastic cap with a male arrow-shaped (with a "made" split down the middle) flange had also come loose. What happened? It didn't spin out of control before, I believe I must have imbalanced the machine somehow.
  • gpb624 Oct 01, 2010
    I went back "under" the machine, repositioned the tub assembly, loosened and then retightened the bolts - no problem now.
    Thanks.
    President:
  • 1,554 Answers
Please accept my fellow expert's solution that addressed your problem to give justice to his efforts. You did not accept his solution and since he was not able to respond to your post, though unnecessary, the problem was unlocked from him and other experts can post a solution then he may lose the credit.
Posted on Oct 02, 2010
  • 2,272 Answers
Tighten the plastic cap flange.And check.But if any of the part mentioned in your question looks cracked then it has to be replaced.Most probably as per the problem it indicates that any of the nut or bearing is got loose and not connected properly or the tub assembly is not placed properly,its bit out of its alignment.It needs to be again disassembled and refitted then checked. If you require part by part disassembly for your washing machine.Please click the link directly. This will help you to disassemble and reassemble the washing machine to its actual settings. http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Washer-Parts/Model-KAWE577BWH0/0593/0153200?pathTaken= -------------- If you want agitator disassemble and assemble diagram click on this link:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Washer-Parts/Model-KAWE577BWH0/0593/0153200/O2021948/00005?blt=06&prst=&shdMod= ----------------
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 01, 2010
I have an older model top load washing machine made by Kitchenaid along with the dryer. The dryer will not get hot but runs fine. When I plugged in the washer it came on and filled up but no spin at all....
The washer sounds like it may be the switch for the door may not be working and for the dryer could be thermal protect sensor tripped or bad thermal sensor on gas valve
Sep 03, 2014 | Washing Machines
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
The agitator in the machine stopped working. I can spin it freely by hand in either direction
Sounds Like the agitator dogs are worn or broken. they are easy to change
  1. Remove the Fabric Softener Dispenser (#1 on diagram)
  2. Remove the Agitator Bolt. (#2 on diagram)
  3. Replace the Agitator Repair Kit
There are 3 Lengths of agitator cams
If you go to http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503228&diagram_id=28254127#d28254127
And Click on #20 on the Agitator, basket and tub Diagram
You can see pictures of the 3 lengths of cams order the one that matches your washer
Jun 25, 2011 | KitchenAid KAWS700L Top Load Washer
Agitator not moving, nor spinning out water
HI, can you relay you complete model number and brand name please?
May 01, 2009 | KitchenAid Washing Machines
Can this be fixed
You flip up the controls and remove the cabinet. The pump and motr come off easily. These web pages really give a good explanation:
http://repair2000.com/coupling.html
http://appliancejunk.com/motorcoupler.pdf
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
Jan 31, 2009 | Washing Machines
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
We have a kitchenaid model kaws850gq0 dont wash
dont reeally undserstand question, you can freely turn the agitator freely, in both directions??? with no resistance??? if so you need to replsce the agitator dogs, part number 80040, probly under $20, to replace youll need to remove the agitator form the tub( 7/16 bolt under the fabric softener cup "pop" it off with the palm of your hand!
Dec 08, 2008 | KitchenAid KAWS850L Top Load Washer
Kitchenaid top load wahing machine # YKAWE870BW1
You need to replace little gears called agitator dogs. Once agitator is removed pull top half of it off. Exposes the dog carrier.
Nov 28, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
90 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
