Have a amana direct drive washer. It was in the rinse cycle and stoped. I can try to restart it and it humms and the clickes off. It will not do anything now. No agitate no pump in any cycle! Have any ideas?
  • davidgalb721 Oct 01, 2010
    Thank You for your time!
    I will check out what you said.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From the description you have provided these are the main reasons of the issue-
If lid switch is bad the washing machine doesn't spin or the motor coupler may be broken which is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails.
A belt may be broken or clutch may be worn. It may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or not at all.
The drive motor may be defective or the transmission may not be shifting properly.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub.
Water inlet valve has gone bad.
Please make sure that the water supply hoses are not kinked or clogged and filter screens are clean. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 01, 2010
Whirlpool cabrio washer
Looks like the motor is having a hard time starting. Try changing the motor capacitor, it jump starts the motor. It is cylindrical in shape aluminum color, sometimes black or may even be plastic white. Also, if it is not a direct drive, inspect the drive belt it could be worn out.
Aug 25, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Won't pump out water for rinse cycle.this happened a couple months ago also, and a repair tech simply put a zip tie on a loose wire. I want to check that, but cannot get the control panel off so that I can...
there are four screws on the back panel that need to come off.then the controll top lifts and or slide forward a bit and it can be removed.
the first thing i would do is use a wet dry shop vac and try and remove the water from the washer.
this particular model washer should have a direct drive drain pump and it is not electrical.
if the washer just kinda humms when it goes into the drain cycle then there is something blocking the pump.there may also be a problem with your lid switch.
Jan 31, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Stall in rinse cycle
loks as if its been amonth since this post, but i would chek your cold water supply, common problem
Sep 05, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Smoking washer Amana NAV8800AWW
Ok, that's a different scenario. Generally, when a washer is agitating and develops an overload that stalls or overheats the motor, the problem could be caused by:
1. Too many clothes for the amount of water level selected. If clothes don't have enough water to circulate in properly, it can put excess pressure on the agitator which transfers to the gearcase, drive belt, and finally the motor. The motor is thermally protected and stops running until it cools down, then it will try to restart. In the process the drive belt could burn slightly to completely,so you may want to inspect the drive belt for burned areas.
2. Transmission malfunction, where something inside the transmission breaks due to an overload and jams a gear. End results can be the same as above.
I suspect a clothes overload may have caused the problem and once the overload is alleviated, the washer should operate normlly if the belt didn't burn,
May 27, 2008 | Amana NAV8800E Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
