Question about SkyGolf SkyCaddie SGX GPS Receiver
SGX not picking up satellite signal. - SkyGolf SkyCaddie SGX GPS Receiver
Skycaddie won't boot on the course
Go back and sync your courses and check your yards settings.
May 18, 2014 | SkyGolf SkyCaddie SGX GPS Receiver
My tomtom is not receiving any satellite signal
You should use your computer to update the QuickFix positions of the Satellites (they do wander in the sky). To get signals you should be outside buildings with an unobstructed view to the sky.
Jan 18, 2014 | Tomtom One GPS
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
Nuvi 200w will not pick up sattalites
Make sure you are outside and as much in the open as possible. Staying stationary is the best way to insure a satellite signal. Give your GPS a few minutes if necessary to pick up a satellite signal. Also remember poor weather can effect a satellite signal reaching your GPS, just like it will satellite TV.
Mar 08, 2011 | Garmin nuvi 200W GPS Receiver
No satellite signal pick up
Yes ! 3 years is at the end of the expected lifespan of the battery
Jun 30, 2009 | Garmin Forerunner 205 GPS Receiver
My 1 year old tomtom will not pick up satellite signal
couple of things, battery not fully charged (AC)
No view of the sky
burned out SIIRF CHIP
Jun 18, 2009 | Tomtom ONE GPS Receiver
Cannot locate saltellite or Acquiring satellite
The error means it can't pick up valid GPS signals. In other words, bad reception.
Has the unit ever worked? Does the unit have an internal or external antenna? Are the batteries fully charged?
Try the unit outside with clear view of sky instead of in the car. This will give it the best chance of picking up a GPS signal.
If it still doesn't then suggest something broken inside.
May 20, 2009 | Garmin nuvi 200W GPS Receiver
Satellite won't pick up a signal
just keep moving the satellite dish untill its in a perfect position.
Dec 20, 2008 | RCA DIRECTV Satellite Remote Control
SkyGolf SkyCaddie SGX GPS Receiver Logo
226 people viewed this question
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
