Question about Mitsubishi WS-65809 65" Rear Projection Television
When we open the TV, the screen is sagging in the middle, top & bottom and intermitently becomes normal (no sagging) after a few seconds and will be normal the whole time it is opened. Our Mitsubishi Big screen TV 65 inch is about 9 years old since we bought it new. What's the problem?
Greenish colors, and sagging screen picture
Ur tv have a problem known as a "CONVERGENCE" problems.The convergence board the 2 STK covergence ICS and some or all it supporting resistors are dead.All these parts must be replaced to get the convergence to conform once again,to produce a solid good picture.The tv shop should charge u for this job,for $300-350 for parts and labors.
May 21, 2010 | Philips Magnavox 51MP392H Rear Projection...
Tv picture sags
Projection tvs have a white colored cloth drapped over the pastic screen on the inside for the image to be projected on. This white film may have become unattached on the insid causing the sag.
Jul 27, 2009 | Televison & Video
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
RCA 27F520 Shutdown after a few seconds
you have lost the vertical ic and maybe resistor or capacitor.
but you also maybe loosing the horizontal ic
you will also have to check the voltages on the flyback transformer that go to those circuit's to see if they drop or are correct
Dec 22, 2008 | RCA TruFlat 27F520T 27" TV
Powers off intermitantly
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv display black bar in the middle of the screen
I battled with this for a while before I realized that my 18 month year old had somehow turned on one of the less common closed caption modes. Since the mode was not supported, it just displays a black frame over most of the screen. Just turn it off and you are good to go.
Jun 19, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Pink lines only down the middle of the screen aprox. 12" wide for spit second.
Most likely will get worse as you are describing a failing control bd. The part # is 6871QCH038A and is a fairly complicated repair. A good deal of disassembly required, and I would take advantage of your service agreement.
Apr 13, 2008 | LG 50PX1D 50 in. Plasma Television
Picture moving from top to bottom
you have a defect in the vertical circuit. most likely the vertical chip ,caps,diode and supply voltage for the chip..john
May 28, 2007 | Toshiba 57H81 57" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
339 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
