Question about Watches
Hw do i change the date.. b.coz for a non-31 month like Sept.. the date displayed is 31 .. plz help
    Genius:
  • 1,970 Answers
Mcdevito75 Here, Press MODE until you get to the date, then press set and set new date, then press MODE again for time display.
Posted on Oct 01, 2010
I have an Armani watch ar6049. The date goes way past 31 to at least 35. I have never seen a watch go past 31, what gives??
There are Mondaine watches that do the same thing. I believe that it's because the date display is actually two separate disks, each reading 0-9. Most date watches only have a single large disk for 1-31. Although your watch is capable of displaying, for example, the 33rd of the month this doesn't happen in practice as the logic built into the watch prevents it.
I assume that using 2 smaller disks to display the date, rather that 1 large one, is for design purposes - possibly it would get in the way of additional hands or other features on the watch.
Hope this helps.
Sep 02, 2017 | The Watches
How do I know what month my Michael Kors watch is showing?
At the end of a month that is less than 31 days you must manually advance the date.
Aug 30, 2014 | Michael Kors MK5629 - Sport Bradshaw...
How do I change the month on an MK 5629?
At the end of a month with less than 31 days you must manually advance the date.
Aug 30, 2014 | Watches
Raymond Weil Jasmine losing date everytime I go to wear my watch which is really on special occasions i find that I have to wind the watch to get the date right would this be a simple battery issue?
the problem is some month's av 28 days and some month's av 31days, but on your watch the wheel that as the numbers on has 31 days so if there's a month with 28 days you'll need to change it manualy hope this helps you,,
Aug 01, 2013 | Raymond Weil Watches
I am unable to change the date on my Timex Indiglo. It currently reads (Sept.) 31, altho it is (Oct.) 1. How do I do change it without changing the time?
mcdevito75 here, If your watch is push button, simply push MODE and see the display flashing, then press mode again until you reach the date, then press set to set the correct date, then press mode again for steady display. If it"s a windup, simply go thru the 24 hour cycle for the correct date.
Oct 01, 2010 | Timex Watches
Date on watch?
mcdevito75 here, YES! that"s normal, all Date watches go up to 31, as some months have 31 days, watch makers haven"t come out with a mechanism that will automatically jump the 31 to the 1, well not that I know of, you simply turn the hands another 24 hours from 31 to 1 if the specific month ends with only 30 days.
Jul 03, 2010 | Watches
How do i adjust the date on my classic watch?? pull the pin and rotate cw or ccw no changes.i have an indigo classic watch. does date need to be adjusted every 30 day months? thanks
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
Jan 12, 2010 | Timex 5B841 Wristwatch
Day and date not synchronized with actual day and date
The watch does not have a "perpetual" clock so it does not know what month it is in. It will treat every month as a 31 day month, so you will have to re-set the date anytime a month is not 31 days.
If you appreciate me answering this for you then please rank this solution as "fixya" or at least "helpful" as what I have said will solve your problem. :-)
Jan 09, 2009 | Citizen 8700 BL8000-54L Wrist Watch
Luminox 8200 series dive watch date set issue
This movement has a really quirky thing going on, its one of the few movements that you can actually turn the hor hand to set the day forwards or backwards...so on a day that goes from the 31 to the 1st it will advance fine, if there is no 31 for that month you can turn the hour hand 2 cycles and it will advance through the 34, continue to the 1st and set time...date can also be set by turning the hour hand backwards thru the dates...go ahead it doesnt 'hurt' the movement a bit, its made for this...so in oither wiords, when you get a new cell and the date is lets say the 15th and your watch says its the 2nd, just advance the hour hand through until you hit 15 and yoiu are good to go...hopefuly this help and didnt confuse much...good luck:)
Dec 02, 2007 | Luminox Navy Seal 8202 Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
